0-60 in 2.9 sec: The production 1018-HP CCXR is here
Roman
Bericht door Roman » 26 nov 2007, 14:48
Koenigsegg has released some full-on shots of the production CCXR -- probably a new one, and not the 1-of-a-kind CCXR crashed by Top Gear. The biofuel-powered car has a twin supercharged 4.8-liter V8, and will put out 1,018-HP at 7,200 RPM, and you'll get 740 lb-ft of torque out of it.
And if you want to break those numbers down, you'll get from the stoplight to 60 in 2.9 seconds, and the good Swedes claim you can take it past 248 MPH. However, in order to make any use of those numbers you need to first get past this one: €1,575,000, plus taxes and fees, to take it home. Check out the gallery of pics below, and check out the full specs on the car after the jump.
[Source: Autoblog NL via Motor Authority]
[img:640:391]http://www.blogsmithmedia.com/www.autob ... cxr_01.jpg[/img]
[img:640:396]http://www.blogsmithmedia.com/www.autob ... cxr_03.jpg[/img]
[img:640:400]http://www.blogsmithmedia.com/www.autob ... cxr_05.jpg[/img]
[img:640:398]http://www.blogsmithmedia.com/www.autob ... cxr_07.jpg[/img]
[img:640:399]http://www.blogsmithmedia.com/www.autob ... cxr_09.jpg[/img]
Roman
Bericht door Roman » 26 nov 2007, 14:50
Koenigsegg CCXR Technical Specifications
Koenigsegg CCXR Special Edition is a Two-door, two-seater with removable hardtop stowable under the front hood lid.
The visible body is carbonfibre.
High performance carbonfibre rear wing
Engine Type: Koenigsegg V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Sequential, multipoint fuel injection. Twin Rotrex centrifugal superchargers with response system 1.5 bar boost pressure.
Displacement: 4.700 cm3.
Compression: 8.2:1
Lubrication system: Dry sump with oil spray piston cooling, and oil cooler.
Fuel: 98 octane / E85 (biofuel)
Power output: 1018 Bhp at 7.200 rpm.
Maximum torque: 1060 Nm (740ftlb) at 6.100 rpm.
Acceleration: 0-100 km/h (0–62 mph) 2.9 seconds.
Top speed: 400+ km/h (250+ mph).
Braking distance: 31m (100–0 km/h)
Lateral G-force: 1.4 G
Fuel consumption: Highway travel: 18 l/100 km Combined: 22 l/100 km
Bericht door Arthur » 26 nov 2007, 14:52
Netjes :D
Bericht door GTRene » 26 nov 2007, 14:58
wow wat een bak zeg, nog verder verbeterd en gepolijst...hij wordt bijna te gladjes...
wel interessante specs, zoals 1.4 G das aardig wat en 31 meter om van 100km te stoppen very impressing...mag je wel zorgen dat je geen gewone auto achter je hebt rijden die redden dat nooit, hebben vaak 10 mtr meer nodig...
ow en Roman, die avator lijd wel een beetje veel af....(storend) als je wil lezen wat er staat omdat het beweegt...
RS
Hendrik Kinderman
Bericht door Hendrik Kinderman » 26 nov 2007, 15:02
Koenigsegg is weer aardig bezig. De ene na de andere nog snellere versie. dit jaar ook al één op bio-ethanol met nóg meer pk's voor milieuvriendelijk hardrijden! en nu dit bruut apparaat!
Tom V
Bericht door Tom V » 26 nov 2007, 15:07
Ik heb toch een grote zwak voor dit merk. Het straalt voor mij echt supercar uit. Erg mooie cijfers ook!
Roman
Bericht door Roman » 26 nov 2007, 15:26
GTRene schreef:ow en Roman, die avator lijd wel een beetje veel af....(storend) als je wil lezen wat er staat omdat het beweegt...
RS
Deze beter?
funnyname
Bericht door funnyname » 26 nov 2007, 15:31
Schitterende auto, helemaal af!
Bericht door GTRene » 26 nov 2007, 17:05
RS
Deze beter?
stuk rustiger en minder afleidend voor waar het hier omgaat, die wat je nu gebruikt is ook erg goed 8)
Trouwens ze hebben bij K'égg nu wel echt werk gemaakt van een achterspoiler...
Erik K.
Bericht door Erik K. » 26 nov 2007, 18:29
Pascal
Bericht door Pascal » 26 nov 2007, 19:29
Deze Koenigsegg ziet er 100 keer beter uit dan een Veyron imo;gewicht is denk ik ook een aardig stuk minder 8) .
Simoni
Bericht door Simoni » 26 nov 2007, 23:46
Dat is echter wel een pak geld!
Als je denkt wat je daarvoor nog allemaal kan kopen... (Ascari KZ1 is sneller rechtuit en wss ook in de bochten, en is de helft vd prijs!)
volvoc30
Bericht door volvoc30 » 26 nov 2007, 23:50
Pascal schreef:Deze Koenigsegg ziet er 100 keer beter uit dan een Veyron imo;gewicht is denk ik ook een aardig stuk minder 8) .
denk alleen dat de betrouwbaarheid een heel stuk minder is!
Bericht door Niels » 27 nov 2007, 00:28
8)
Daniel
Bericht door Daniel » 27 nov 2007, 08:16
Hij's ook nog eens drie hele Gallardo's duurder dan een Veyron. Die kost in NL 1,8 miljoen incl. belastingen, de Koenigsegg is 1.575.000 excl. dus die komt op een ongelofelijke 2,6 miljoen euro. Alleen van de BPM al (ruim 7 ton) koop je een RR Phantom én een 997 GT3.
Hij's inderdaad wel mooier, maar da's ook niet zo moeilijk :)
TR6ME
Bericht door TR6ME » 27 nov 2007, 10:25
Echt een gigantisch mooie supercar. Wat mij betreft de mooiste ter wereld. Aanschafprijs maakt voor dit soort droomkarren niet uit, toch onbereikbaar :(
Het wordt ondertussen tijd dat 'The STIG' deze nieuwe Königsegg en eindelijk de Veyron (desnoods een occazie) na elkaar even laat spinnen met Waterloo van ABBA op de achtergrond :wink:
Gebruikers op dit forum: Baidu [Spider], Bombadil, EvdP, Google [Bot], Will F. en 30 gasten
