Onthuld: F12 en F13 M6 (2012)
Bericht door Joop » 12 feb 2012, 01:59
De M6 toch maar even een eigen topic geven...
Daar is de sterkste uitvoering van de F12/F13/F14 6er, de M6:
BMW PressClub schreef:The new BMW M6. Coupe and Convertible.
12.02.2012
At a glance
• New edition of the BMW M6 in Coupe and Convertible body variants; generous dose of M feeling combined with alluring design aesthetics, a luxurious aura, seating for four and innovative equipment features; high-performance sports car with superior performance attributes and extremely exclusive character; BMW M6 Coupe and BMW M6 Convertible both occupy a unique position in the premium segment of the executive class thanks to their blend of outstanding dynamics, hallmark M conceptual harmony and everyday usability; further development of both concepts breaks new ground with significantly improved efficiency, optimised controls for individualising the car set-up and a wider variety of driver assistance systems and infotainment functions available from BMW ConnectedDrive.
• Visually imposing body design with dynamically elegant lines and hallmark M athleticism provides an accurate visual showcase for the car’s high-performance properties; BMW M6 Coupe with strikingly contoured roof made from carbon fibre-reinforced plastic (CFRP); BMW M6 Convertible with high-quality soft-top boasting distinctive “fin” architecture.
• High-revving 4.4-litre V8 engine with M TwinPower Turbo technology, consisting of Twin Scroll Twin Turbo technology, cross-bank exhaust manifold, High Precision Direct Petrol Injection and VALVETRONIC fully variable valve control; hallmark M power delivery headlined by instantaneous responsiveness and a sustained wave of thrust; highest output in the segment; 412 kW/560 hp at 6,000 – 7,000 rpm, maximum torque: 680 Newton metres (502 lb-ft) from 1,500 rpm; maximum engine speed: 7,200 rpm; engine output 10 per cent higher than predecessor models, maximum torque 30 per cent higher.
• Acceleration: 0–100 km/h (62 mph) in 4.2 seconds (BMW M6 Coupe) or 4.3 seconds (BMW M6 Convertible); 0–200 km/h (124 mph) in 12.6 (13.1) seconds; electronically governed top speed: 250 km/h (155 mph) or 305 km/h (189 mph) with M Driver’s Package.
• Extraordinarily fine balance between performance and fuel consumption represents major improvement on previous models; average fuel consumption in the EU test cycle: 9.9 litres per 100 km / 28.5 mpg imp (BMW M6 Coupe) and 10.3 litres per 100 km / 27.4 mpg imp (BMW M6 Convertible); Auto Start-Stop function and further Efficient Dynamics technology as standard; fuel consumption of the respective predecessor models cut by more than 30 per cent.
• Seven-speed M Double Clutch Transmission with Drivelogic; automatic gear selection tuned to deliver optimum traction, Launch Control and Low Speed Assistance; bespoke M gear selector; newly developed M leather steering wheel with gearshift paddles.
• Power sent to the rear wheels; Active M Differential ensures fully variable distribution of drive between the rear wheels. Result is optimised traction and directional stability during dynamic lane changes and when accelerating out of corners.
• High-performance characteristics with outstanding dynamics and precisely controllable handling, thanks to hallmark M harmony in the interplay of powertrain and chassis technology, aerodynamics and weight balance; weight-to-power ratio – BMW M6 Coupe: 3.3 kg/hp (7.3 lb/hp),
BMW M6 Convertible: 3.5 kg/hp (7.7 lb/hp).
• M-specific chassis with bespoke front and rear axle kinematics;
M-specific Dynamic Damper Control as standard; DSC stability control incl. M Dynamic Mode; M Servotronic steering; body strengthening using special panels; lightweight compound high-performance braking system; available as an option are newly developed, globally unique M carbon-ceramic brakes with optimum resistance to fade and wear, and lower weight.
• Engine responses, M Servotronic mapping, Drivelogic shift program,
DSC mode, damper characteristics and information shown on the Head-Up Display can be programmed individually; two M Drive buttons on the steering wheel can be used to store and call up individually configured
car set-up options.
• Body design with classical BMW Coupe/Convertible proportions, customary sporty yet elegant BMW 6 Series looks and typical M sporting edge; special M design features provide an accurate visual representation of the car’s technical profile and performance; three-section, strikingly modelled lower air intake with aerodynamically optimised flaps; new M kidney grille with black double slats; flared wheel arches; hallmark M gills with integrated direction indicator bars; aerodynamically optimised exterior mirrors and side skirts; BMW Individual High-gloss Shadow Line; exposed reflectors below the rear lights; aerodynamically optimised rear apron with diffuser between the right and left-hand pair of twin exhaust tailpipes; 19-inch (standard) or 20-inch (optional) forged M light-alloy wheels, each with a distinctive interpretation of the familiar M double-spoke design.
• Luxurious, elegantly sweeping interior design with special M controls and styling features; newly developed M double-spoke leather steering wheel; M gear selector and car set-up controls on the model-specific centre console; exclusive M sports seats with integrated belt system (optional: M multifunction seats); Merino leather upholstery with extended features; exclusive carbon-fibre interior trim strips; illuminated door sill finishers with model lettering; M-specific instrument cluster with black-panel technology; 2-zone automatic climate control with extended features, ambient lighting.
• Adaptive LED Headlights fitted as standard, extensive range of BMW ConnectedDrive features, some unmatched by any rival: BMW Head-Up Display with M-specific information, High Beam Assistant, BMW Night Vision with pedestrian recognition, Lane Change Warning, Lane Departure Warning, rear-view camera, Surround View, Speed Limit Info, internet access, extended integration of smartphones and music players, Real-Time Traffic Information and apps for receiving web radio and using Facebook and Twitter.
• Almost all BMW 6 Series equipment options available, including Comfort Access, active seats, heated steering wheel, doors with Soft Close Automatic function, Navigation system Professional, Bang & Olufsen High- End Surround Sound System.
Performance, fuel consumption and emissions data:
BMW M6 Coupe:
Acceleration [0 – 100 km/h (62 mph)]: 4.2 seconds,
acceleration [0 – 200 km/h (124 mph)]: 12.6 seconds,
top speed: 250 km/h (155 mph), 305 km/h (189 mph) with
M Driver’s Package,
average fuel consumption: 9.9 litres/100 kilometres (28.5 mpg imp),
CO2 emissions: 232 g/km, exhaust standard: EU5.
BMW M6 Convertible:
Acceleration [0 – 100 km/h (62 mph)]: 4.3 seconds,
acceleration [0 – 200 km/h (mph)]: 13.1 seconds,
top speed: 250 km/h (155 mph), 305 km/h (189 mph) with M Driver’s Package),
average fuel consumption: 10.3 litres/100 kilometres (27.4 mpg imp),
CO2 emissions: 239 g/km, exhaust standard: EU5.
BMW V8 Twin Scroll Twin Turbo (S63Tu) Engine
Displacement: 4,395cc
560hp (at 6,000-7,000rpm)
502 lb-ft torque (max torque from just 1500rpm)
Weight (coupe), unladen (DIN/EU) - 1850kg / 1925kg (4,078 / 4,243lb)
Weight (convertible), unladen (DIN/EU) - 1980kg / 2055 (4,364 / 4,530lb)
7-speed DCT transmission (manual transmission for US also likely)
Coupe average fuel consumption: 9.9 liters/100 km (28.5 mpg imperial / 23.5 US MPG)
Convertible average fuel consumption: 10.3 liters/100km (27.4 mpg imperial)
CFRP roof (carbon fiber reinforced plastic) for M6 coupe
Optional M carbon-ceramic brakes reduce weight by 19.4 kg (42.8 lb) and increase fade resistance - calipers gold-colored
Weight-to-power ratio - Coupe (3.3kg/hp, 7.3lb/hp); Convertible (3.5kg/hp, 7.7lb/hp)
Pictured colors: Sakhir Orange (coupe), San Marino Blue (convertible)
Performance:
Coupe: 0-100km (0-62mph) in 4.2 seconds (F10 M5 takes 4.4 seconds); 0-200km (0-124mph) in 12.6 seconds
Convertible: 0-100km (0-62mph) in 4.3 seconds; 0-200km (0-124mph) in 13.1 seconds
Top speed: 250kmh (155mph)
M-Drivers-Package increases top speed from 250km/h to 305km/h (155mph to 189mph)
Volledig persbericht: F13 M6 Persmap
Re: Onthult: F12 en F13 M6 (2012)
F13 M6 Coupe:
F12 M6 Cabrio:
ErikMartijn
Bericht door ErikMartijn » 12 feb 2012, 02:27
Wow! Echt mooi. Double bubble dak is ook een leuk detail. :)
markk
Re: Onthuld: F12 en F13 M6 (2012)
Bericht door markk » 12 feb 2012, 08:56
Mooi, mooi, mooi.
Nou bring it on die huisselectie carbon zwarte m6 coupe V10 voor onder de 30k...
Mark.
Niels v/d burgh
Auto: Zweedse diesel
Bericht door Niels v/d burgh » 12 feb 2012, 09:04
Prachtige auto's, dak van de coupé is echt subliem !!
Bericht door romo » 12 feb 2012, 09:51
Mooie kar, front subliem, hoewel dat asymetrische stijltje voor de camera voor mij dan weer onzin is.........M6 embleem grille hadden ze altijd al moeten doen, maar goed, het is weer terug...............
Zijprofiel staat me tegen.....de kar is veel te l..........................a.............................n....................................g
Bericht door MartijnGizmo » 12 feb 2012, 09:56
Wanneer komt de ///M650d? :P Ohnee, er komt al een 640d Xdrive...
Bericht door RVV » 12 feb 2012, 10:36
Prachtige auto om te zien.
Bericht door Macboy » 12 feb 2012, 11:25
Coupe in blauw aub met dat witte interieur :love:
Kasteel
Bericht door Kasteel » 12 feb 2012, 11:27
markk schreef:Mooi, mooi, mooi.
Mark.
Leeftijd issues voor de huisselectie; 2 jaar terug stond er bij De Beier een op randje huisselectie met 90k km voor rond de 50k, echter ging toen net niet in de huisselectie weg (leeftijdscriteria).
Vind de nieuwe m6 (en de 'gewone' 6) gewoon echt top :).
Nutkees
Auto: Dodge Viper
Bericht door Nutkees » 12 feb 2012, 11:58
Prachtige lijnen!!
Rivanov
Bericht door Rivanov » 12 feb 2012, 11:59
Geweldige kar!
Snipe
Bericht door Snipe » 12 feb 2012, 12:01
Jammer dat dit ding ook weer een gaziljoen kilo weegt. Ik verwacht echt geen karretje van 1.200 kilo, maar 2.055 (Cabrio) is weer het andere uiterste.
Sperdy
Bericht door Sperdy » 12 feb 2012, 12:30
Veel liever dit dan de nieuwe M5. Dit is wel een échte special voor een sjeik dan.
Auto ook zonder humor. Maar goed, ik zou nooit een nieuwe M kopen in deze boot-klasse.
Alleen de 1M is leuk, de rest kan met het afvalwater het putje door.
Als je 'm ooit ziet rijden, zal die wel een imposante indruk maken, dat is dan weer wel gaaf. Maar dat is dan ook alles.
Gijs.
Bericht door Gijs. » 12 feb 2012, 12:58
Schitterende wagen! Ik vond de gewone nieuwe 6 al indrukwekkend om te zien in het verkeer, maar deze wordt echt top. Enige minpuntje: het M6 logo in de grille. Ziet er een beetje uit alsof ze niet wisten wat ze daarmee aan moesten en het dus maar in een hoekje hebben gepropt. Jammer!
Snipe
Bericht door Snipe » 12 feb 2012, 16:52
Nog een setje foto's met onder meer de keramische remmen die als optie leverbaar zijn: http://www.driving-fun.com/2845/home/ne ... etail.aspx
Rivanov
Bericht door Rivanov » 12 feb 2012, 16:58
Gijs. schreef:Schitterende wagen! Ik vond de gewone nieuwe 6 al indrukwekkend om te zien in het verkeer, maar deze wordt echt top. Enige minpuntje: het M6 logo in de grille. Ziet er een beetje uit alsof ze niet wisten wat ze daarmee aan moesten en het dus maar in een hoekje hebben gepropt. Jammer!
Vind het juist wel mooi! :)
Bericht door romo » 12 feb 2012, 19:03
Embleem in de grille is perfect IMO.................juist een detail waar ik enorm van kan genieten, niet te opvallend niet te schreeuwerig, maar juist klein en fijn, maar wel even laten eten dat het iets apart is........heerlijk......
Verder is het natuurlijk een verwijzing naar het verleden, heritage revived.......history alive.......
Uiterlijk is erg fraai, maar terecht commentaar op 1940 kg en de lengte van een intercity.............elegant is ie, maar het oogt a-sportief.......
Die remmen wil ik wel, niet omdat ze beter remmen dan de stalen, maakt geen donder uit, maar omdat er geen lelijke roestrand om de schijf komt.................dat vind ik apert lelijk, op alle auto`s that is..........
johann3s
Bericht door johann3s » 12 feb 2012, 19:16
Mooie wagen, hoewel ik het lijnenspel vanuit sommige hoeken wat druk vind. Tof detail vind ik de blauwe M-remklauwen!
En als ik bijvoorbeeld het achteraanzicht zie zou ik zeggen dat hij nog wel wat lager mag liggen?
Fedmas
Auto: G21 330e
Bericht door Fedmas » 12 feb 2012, 19:31
Wat een héérlijke auto! :wave:. Ik hoop over 5-10 jaar zo'n 6 serie te hebben, lijkt me heerlijk.
Kasteel
Bericht door Kasteel » 12 feb 2012, 21:49
romo schreef: Die remmen wil ik wel, niet omdat ze beter remmen dan de stalen, maakt geen donder uit, maar omdat er geen lelijke roestrand om de schijf komt.................dat vind ik apert lelijk, op alle auto`s that is..........
Ben ik de enige die die blauwe en gele klauwen afschuwelijk vind?
Bericht door Xave30 » 12 feb 2012, 21:59
^ You are not alone.
Bericht door GTRene » 12 feb 2012, 22:08
het gebruikte blauw vind ik niet mooi, dat performance blauw wat ze hadden voor bv de 1 serie vond ik wel mooi...
en dit geel ook wel
en dit ook wel
Bericht door romo » 13 feb 2012, 21:18
Als ze de nieuwe 3er coupe nu ook zo doen.......................maar dan flink ingekort, dus veel meer gedrongen, dan wordt het nog wel wat...............
Ron4S
Bericht door Ron4S » 13 feb 2012, 22:21
M6 coupe of 991 Carrera S? Zullen elkaar nauwelijks in prijs ontlopen....
