SLK with SLR engine 620pk
Bericht door GTRene » 21 jan 2008, 19:24
[img:640:483]http://www.mbfanatics.org/forum/uploads ... 510857.jpg[/img]
[img:275:219]http://www.mbfanatics.org/forum/uploads ... 510898.jpg[/img]
The transmission is indeed a 7 speed, modified to survive happily to 1200Nm [885 lbs/ft -- ed]. The Engine is an SLR unit, the 55 series engines are virtually identical in exterior appearance, internal components vary to suit requirements
[img:395:296]http://www.mbfanatics.org/forum/uploads ... 510930.jpg[/img]
The engine fitted is pure SLR with one exception. The SLK flexplate and SLR crankshaft run different bolt patterns, so the crankshaft fitted to this engine is a prototype that has now gone into production for various models. The SLR Kompressor configuration is unique. The black units on top of the engine are water cooled intercooler assemblies, no air filters as somebody advised earlier. As anyone will know who has driven an SLR hard in high ambient temperatures, the SLR intercooler water system is not capable of an adequately cool water supply and performance suffers because of it, so a large amount of the installation and design of this project was dedicated to intercooler temperature control.
[img:640:480]http://www.mbfanatics.org/forum/uploads ... 510957.jpg[/img]
We have used a full sized E55 engine radiator with hand fabricated end tanks and placed it in front of the air conditioning condensor. A 10 litre water catch / swirl tank supplys cooled water to the 2 AMG intercooler water pumps and these pump water through the intercoolers and back to the intercooler radiator. Intercooler water temps have never risen more than 12 degrees over ambient.
[img:395:296]http://www.mbfanatics.org/forum/uploads ... 510988.jpg[/img]
The airbox is now mounted above the battery for 2 reasons, The highest air pressure point on the vehicle is at the base of the windscreen and it also happens to be a good source of the coolest air possible.The SLR engine sump is larger than the SLK and runs a slightly different layout configuration, hence the need to change the front anti roll bar. We fabricated and adjustable chrome moly unit which is clearly visible on the under car shots. The SLK and SLR Motronic control units and wiring are very different in CAN addressing and pinouts, for this reason an E55 engine ECU and wiring loom was used and reprogrammed to suit. E throttle control, ESP, Engine fan control, injector sizing, ignition and fuel tables plus much more.
[img:640:480]http://www.mbfanatics.org/forum/uploads ... 511015.jpg[/img]
The exhaust modifications visible in the pictures were a temporary fix to establish noise levels prior to exhaust system development, this has now been updated and as anyone who has heard the car in anger will tell you, the sound is breathtaking. The only way I can truely explain it is every time I hear it, I am reminded of a summers evening in Pamona several years ago, watching Pro Stock qualifying. I honestly hope it comes through clearly on the video. Our ambient air temperature during summer can exceed 50deg C, this is the reason for the summer bonnet, during winter the covered bonnet will be fitted. Anytime under bonnet temperatures can be decreased, power will increase.
Speaking of power, I beleive the standard SLR engine is rated at 625hp? Please be assured that with our 98 premium octane, an intercooler system that exceeds requirements, additional supercharger pressure via drive upgrades and some serious dyno time, the SLR engine is capable of well more than this consistantly. Power in this car? Adequate!
[img:640:480]http://www.mbfanatics.org/forum/uploads ... 511102.jpg[/img]
Additional weight over the front wheels is approximately half the weight of a passenger, weight balance is unchanged as the SLR engine and SLK engine sit in the same position. The front and rear suspension have been changed with uprated springs and shocks in the rear to better control the squat this power level produces and of course the front shocks needed changing because as one might expect, the front wheels almost lift under hard acceleration.
Why an SLR engine?
[img:640:480]http://www.mbfanatics.org/forum/uploads ... 511157.jpg[/img]
Simple, the completed car is a quarter the cost of an SLR, its faster than an SLR because its approx 400Kg lighter, and the car is relatively inconspicuous. A personalised SLR has been ordered and will arrive when finished, but sometimes its good not to wave a huge flag.
This car has something that the majority of engine transplants do not. It can, will and has been parked outside the front door of the Royal Palace and acknowledged with a smile that it matches the style synonomous with the name Mohammed Ben Sulayem.
[img:800:600]http://www.mbfanatics.org/forum/uploads ... 511178.jpg[/img]
to see this thing against an ENZO
http://www.youtube.com/watch?v=OVDlx9qsq0w
Hendrik Kinderman
Bericht door Hendrik Kinderman » 21 jan 2008, 19:28
Moest altijd al mogelijk zijn. Het blok van de SLR McLaren is namelijk gebaseerd op het 55 AMG blok
Bericht door MartijnGizmo » 21 jan 2008, 20:06
Het filmpje kende ik al, dit verhaal niet.
Behalve dan twee huge-ass gaten in je motorkap. :lol: Maak daar dan in godsnaam gewoon twee powerbulges overheen.
Had die E55 op deze foto niet ook een SLR-motor?
Wint
Bericht door Wint » 21 jan 2008, 20:47
Echt geweldig dit! :lol:
Je moet toch wat met je zonnesteek?
Shakes
Bericht door Shakes » 21 jan 2008, 21:14
Jammer van het uiterlijk.
De rest is natuurlijk te stoer!
N.
Bericht door GTRene » 21 jan 2008, 21:57
Tis wel een monster :twisted: tja en die motorkap, wel knap uitgesneden, en kijk eens wat ik onder de kap heb en misschien wat extra koeling :roll: maar inderdaad gezien de zijkant die gewoon best gaaf is valt het daar teveel op...2 dikke power bulten had denk ik mooier gestaan, gewoon zelfde kleur als de rest, verders uiterst gaaf 8)
Steven N.
Bericht door Steven N. » 21 jan 2008, 23:22
Martijn Koevoets schreef:Het filmpje kende ik al, dit verhaal niet.
Klopt, E klasse ook met SLR motor.
Beetje simpele oplossing die gaten. Komt er alleen maar woestijn in :roll:
Pescatore
Bericht door Pescatore » 21 jan 2008, 23:27
Dr loopt daar vast wel 1 of ander Pakistaantje rond die dat eruit wil halen voor 3 euro per dag :P
Wel lekker hoor, die wegen daarzo. Op de verlaten stukken kun je knallen tot je zonder benzine komt te staan. En dan die rotondes; 5 baans is niet ongebruikelijk. Leuk om te leren driften op snelheid :wink:
Jurriaan
Bericht door Jurriaan » 21 jan 2008, 23:34
Gaaf zeg!
Mooi moment ook om die motorkap eens een restyle te geven zodat die rare verwijzing naar de F1 verdwijnt.
Bericht door Macboy » 22 jan 2008, 09:59
Vind het project geweldig, de motor geweldig en de binnenkant helemaal.
Topauto voor rechtuitbranden. WOOW !
Style
Bericht door Style » 22 jan 2008, 20:32
zoiets rijdt natuurlijk alleen maar in Dubai rond :D
moet daar toch echt eens heen 8)
Gebruikers op dit forum: Geen geregistreerde gebruikers en 75 gasten
