New BMW 5 Series Prototype
Starred
Just in case you couldn't get enough of the new BMW 5 Series spy photos from last week, here are some fresh new ones. Also included is a new rendering, which, as a reminder, is speculative. The purpose of all of the renderings/artist illustrations that we publish is to give you an idea of the general design direction based on the latest spy photos. So don't get bent out of shape, if you think its going to look different because it most likely will.
Following the same path as the next generation 7 Series, the new BMW 5 Series will be less adventurous in its design compared to the current model. Using a new internal codename system, BMW has replaced the “E” designation (i.e. E60 for current 5 Series plartform) with “F” for the next generation 5-Series. Known internally as the “F10”, the new mid-size luxury sedan is the second new BMW model to receive the new code after the F01 BMW 7 Series which arrives in 2009.
The F10 5 Series will be equipped with a new 8-speed electronic automatic transmission, optional all-wheel-drive and engine ranging from six petrol engines, 2.5-liter 218hp to 4.4 liter V8 twin-turbo with 408hp and four diesels ranging from 2.0 liter 175hp to 3.0 liter 300hp.
With the current E60 5-Series on the market since 2004, the arrival of the F10 replacement is still three years away with an expected launch in spring 2010 as a 2011 model.
[img:800:533]http://images.worldcarfans.com/articles ... 001.1L.jpg[/img]
- Mark Nauta
Hansv (Hans van Velzen)
- Femme
X3 lampen zijn het.Hansv (Hans van Velzen) schreef:Ha, die Fappers;
Een E60 met E90 lampen erin gerfotosoept, denk?
In het verleden hebben we vaker slecht soeps gezien met X3-lampen erin. BMW heeft die stijl lampen echter nooit in een andere auto dan een X3 gebruikt.
BMW neemt gelukkig de moeite om bij een nieuwe auto nieuwe koplampen te ontwerpen. Al die plakwerk impressies zijn daardoor al bij voorbaat nutteloos.
Dit moet wel een van de meest inspiratieloze impressies ooit zijn geweest, gewoon een bestaande 5-serie nemen en dan een grotere grille en andere koplampen erop...
- Mark Nauta
Re: New BMW 5 Series Prototype
Hier nog een gelekte foto van de BMW F10
- RVV
F10 is de codenaam voor de nieuwe 5 serie ?
Ziet er wel heel erg stoer uit
- Mark Nauta
Ja, De E-nummers zijn opRico schreef:F10 is de codenaam voor de nieuwe 5 serie ?
De nieuwste 7 is trouwens de F01.
- Mark Nauta
Een fotoshop op basis van de GT concept, die denk ik wel heel goed laat zien hoe de F10 eruit komt te zien.
- Max V
Die is vet!
- Joop
Heb nog een plaatje gevonden; onder andere op basis van (mogelijk) gelekte voorbumper...
Behoorlijk dynamisch ontwerp zo te zien (aan de andere kant blijft nog maar een impressie / PS, dus kan nog alle kanten op).
http://carscoop.blogspot.com/2009/03/ar ... eries.html
- Artist Impression F10 5er
- BMW-5-2010-2.jpg (81.08 KiB) 1272 keer bekeken
- romo
Kan er wel bij door.......................
Punt van kritiek; het bovenste deel van de koplampen, das dus glas, daar had ik liever een doorgetrooken motorkap gehad. Bovenstaande geeft mij een dejavu van koplampen van een oude Opel Astra....................
- Tom V
De nieren wordt weer even wennen maar goed, dat heb ik bij bijna alle BMW modellen dus waarschijnlijk weet ik straks niet anders meer.
- Femme
De nieren zijn gelukkig beter in verhouding dan bij de 7-serie, hoewel ik moet zeggen dat de nieuwe 7 zeker als je er voorrijdt een hoog uberholungsprestige heeft. De stance heeft veel weg van de CS Concept.
Waar ik wel voor vrees is dat BMW weer ontwerpen gaat maken die met behulp van de verkleiningsfuncties van een kopieermachine tot stand zijn gekomen. Hopelijk krijgt de nieuwe 5 wat originele designelementen mee waarmee het model zich kan onderscheiden van de 7.
Gebruikers op dit forum: Bakker, Edwin de Haas, MarcF, Paul76 en 55 gasten
