LFS krijgt 2e BMW single seater
Miesjel
Auto: MX5 NA, MX5 NC, RAV4
Bericht door Miesjel » 07 dec 2007, 15:43
http://www.lfs.net/
scawen schreef:We are pleased to announce that there will be a new patch before Christmas. This patch will contain AI and physics improvements, updated Blackwood and South City tracks and... a new real car - The Formula BMW FB02!
The story behind the new car is that there is a new UK based company called V1 Championship whose aim is to discover a new racing driver through a series of tests resulting in a place in a team for the winning driver. V1 will be launched in 2008 and shown on TV in the UK. Live for Speed will be used as part of the selection process, before testing in real cars. V1 asked us to create a Formula BMW to make this test as realistic as possible. BMW Motorsport gave us permission to build the car in LFS, so we went ahead and built it.
The V1 car is owned by Fortec Motorsport where V1 is based. Thanks to V1 and Fortec, our programmer Scawen Roberts was able to get a test day driving the Formula BMW and that helped a lot with the realism of the LFS version of the car.
We can't give an exact date for the release yet but it will be before Christmas. Right now you can watch a video of Scawen's test day and footage of the car in LFS.
http://www.youtube.com/watch?v=b26HuguLwFI
Hi-res download : http://www.lfs.net/file_lfs.php?name=LFS_FBMW_HIRES.zip (69MB)
Elco
Bericht door Elco » 07 dec 2007, 18:21
Best grappig ook het verhaal erachter maar ik wil nieuwe banen zien! Niks updated south city en blackwood daar rijden wel al veel te lang op. S2 is vanaf juni 2005 en we krijgen patch na patch. Het word toch wel tijd dat ze eens hard aan het werk gaan voor S3 of maak wat nieuwe banen. Speel het nu eigenlijk nooit meer.
Bericht door MartijnGizmo » 07 dec 2007, 18:27
Doet u mij maar een FZ5 turbo en nieuwe banen.
Mustafa al-Sahaf
Bericht door Mustafa al-Sahaf » 07 dec 2007, 18:29
Ik ben anders wel benieuwd naar de updates van Blackwood. Zou het alleen om grafische dingen gaan of ook om nieuwe varianten?
En als ze toch bezig zijn, ik wil graag een paar BMW toerwagens!
Hubert D
Bericht door Hubert D » 07 dec 2007, 20:10
Ziet er goed uit.
Ik speel alleen ook nog maar zelden. Tijd voor echt nieuwe banen en toerwagens.
Bericht door MartijnGizmo » 23 dec 2007, 12:25
De patch is inmiddels uit:
Changes from X10 to Y :
Content :
New demo car : Formula BMW FB02
Removed XR GT Turbo car from demo
Chicane route added to South City
AI :
AI can now drive faster and can deal with changing car
AI can drive out of pit garage for qualify or practice
Can now make pit stops for fuel / damage / must pit rule
No longer stop and reset to repair their car (pit instead)
Save and load functions for start grid in single player
Physics :
Engine moment of inertia increased in all cars
Handbrake is now applied at the start in hotlap mode
Gear change auto throttle cut and blip options removed
Manual clutch is now fully manual and engines can stall
Improved simulation of sequential and h-pattern gearboxes
Live anti roll and brake balance only allowed on race cars
Redline rpm and rev limiter rpm point reduced in all cars
RB4 - reduced mass by 18 kg / FXO - reduced tyre width
FXO GTR - reduced mass by 20 kg to improve GTR balance
GTR class also balanced by engine / gearboxes changes
Racing tyres generate more heat and wear more quickly
Clutch overheating system and display in F9 / F10
FIX : Error in position of wind resistance centre
South City :
Many graphical updates and new configuration added
Kerb construction modified making wall collisions safer
JPG textures now used for adverts (data\pic\SO_ADSx.jpg)
Blackwood :
Modified chicane and section after main straight
Slightly narrower track and various graphical updates
JPG textures now used for adverts (data\pic\BL_ADSx.jpg)
Fern Bay :
Tyre stacks to stop cutting Rallycross Green Turn 1
Fixes / pit lane cameras / removed large bridge adverts
JPG textures now used for adverts (data\pic\FE_ADSx.jpg)
Graphics :
Minor updates to Formula V8
FIX : XRG / XRT / XRR side mirrors
Languages :
Translatable damage display in F10 mode
Added Lithuanian and Latvian translations
Adjustable cockpit view position for each car
Left / right one button look functions now 45 degrees
Left + right two button look functions now 90 degrees
One button look is now adjustable from 30 to 90 degrees
Look behind button in road cars - look back from centre
Look behind button in racing cars - show virtual mirror
FIX : Forced cockpit view now only affects your own car
FIX : Skid marks and rubber are now visible through screen
Multiplayer :
Maximum size of config file (setup.cfg) doubled to 4 KB
Command /spec X can be used by guests to remove AI drivers
Time between reset and race start increased by six seconds
Added "cruise" option and filter (allows wrong way driving)
FIX : Remote clutch was pressed while shift paddle was held
FIX : Lap timers did not work after /pitlane X or /pit_all
FIX : Vulnerabilities that allowed a server to be crashed
Interface :
Damage repair is now a selectable option
Pit stop damage repair takes twice as long
Engines are no longer repaired in pit stops
Pit stop still continues after car is nudged
Added some missing commands to the /help text
Updated LFS icon in LFS.exe - thanks to ORION
LFS icon appears at top left of an LFS window
Can now drive up to 1 km/h over the speed limit
Redline display on tacho now has maximum accuracy
Press 4 key to see a racing line for any viewed car
Show racing line is disallowed in hotlapping and FCV
Can Reset and Must Pit added as single player options
New command /entry - makes LFS return to entry screen
Fuel per lap estimate now shown in pits - info section
Added Bridgestone and Avon tyre manufacturers in setups
Speedo (both types) improved text size and aspect ratio
Dashboard fuel displays now shown as % instead of litres
Setup and colour config files now use three letter prefix
Autocross layouts can now be selected in the track screen
Removed digital speedo option - now depends on type of car
Pit Stop fuel is now the fuel amount to be added at pit stop
Best lap time is now shown at top right during a normal race
Downforce distribution now shown in pits - downforce section
Tips page updated to include a new tip and remove an old one
FIX : Virtual dash appeared when viewing a remote undrawn car
FIX : All pressed keys are now released when LFS loses focus
FIX : CTRL + SHIFT tried to show user names in single player
FIX : Sound and controller issues when changing screen mode
FIX : Codepage of rename and delete buttons in save dialog
FIX : Comma could not be used to enter interface scale
FIX : MPR with licensed track causeD LFS demo to crash
FIX : Recalibrate axes button set all axes to "X axis"
FIX : Buffer overflow issue in SPR and MPR files
Auto update system :
Auto updater checks to see if patch is already downloaded
LFS switches to window on entry if it does not have focus
Patch files are not deleted until user answers "Restart?"
FIX : InSim bind error on restart after auto update
Sound :
Included new default sounds for BF1 / FZ5 / FZR / FOX
Sound is now switched off while changing screen resolution
Training :
Included new full pack of lessons - thanks to GP4Flo
Racing line is drawn on ground in Test Drive lessons
No penalty for hitting objects in Test Drive lessons
Pressing ESC in test drive lessons results in a pass
Can now hit objects / cones after completing a lesson
Message is shown on screen if you hit a car overtaking
Enter key can now be used to press any green button
Removed countdown and info text at start of lesson
InSim :
FIX : Zero degrees FOV in CPP could cause LFS to crash
FIX : InSim - CCI_FIRST / CCI_LAST not set if player in pits
Changes from X to X10 :
Interface :
Available start grid size now shown in game setup screen
Results table now shows user names if you press CTRL+SHIFT
Improved positioning of 3d menu objects (drivers and cars)
Display positioning support in Options->Display->Interface
Added buttons to reset position and size of moved interface
Analogue steer smooth max raised to 0.95 (to help gamepads)
Faster downloading system for auto update and offline skins
FIX : Autocross timing info turned orange after any results
FIX : ALT+F4 and /exit command now exit from meeting room
Graphics :
Minor optimisation in 2d display system
Optimised wide screen effect by using a viewport
Optimised mirror draw by using a narrow viewport
Removed missing lines of 2d elements at screen edges
Graphics option : 32 bit sky (32 bit is now default)
Improved texture purging code (avoiding possible crash)
FIX : Shift light was invisible in single player replays
FIX : GetPlateHandle message could come up on a busy host
Multiplayer :
Added new multiplayer option : force cockpit view
Removed full hosts filter from List of Games screen
Moved cones and physics objects are restored more quickly
Added handicaps / start position / user name to MPR header
Show time and date of MPR by holding CTRL+SHIFT during replay
FIX : It was possible for any guest to cause a host to crash
FIX : A player is connecting stayed on after MPR finished
FIX : Command /end did not work if no players in race
FIX : Wrong way autokick did not work
InSim / Programmers :
Username is now saved in SP Replays
Driver model byte added to IS_NPL packet
Minimum MCI / NLP time interval reduced to 50 ms
New packet IS_AXO sent when an autocross object is hit
New packets IS_AXI and IS_AXC report layout information
FIX : Guests could not see ALWAYS_ON buttons in all screens
FIX : Guests sent corrupted data in a long IS_BTT packet
FIX : Dedicated host could not fill in split nodes info
FIX : Dedicated host did not report race positions
Het verwijderen van throttle-cut/throttle-blip is voor de mensen zonder G25 (inclusief ondergetekende) best wel een nadeel.
Gebruikers op dit forum: Geen geregistreerde gebruikers en 79 gasten
