2008 porsche cup car.
Bericht door Andre » 01 dec 2007, 11:34
Porsche's 420 HP 911 GT3 Cup car
PRESS RELEASE
The new Porsche 911 GT3 Cup is entering the 2008 motorsport season with engine output increased to 420 bhp. The car will be raced in the Porsche Mobil1 Supercup, the world's fastest international brand trophy, and worldwide in national Porsche Carrera Cups and GT3 Cup Challenges. 265 units of this production-based racing car developed in Weissach will be built on Porsche's production line in Stuttgart-Zuffenhausen, marking a new record for a car of this category.
The most significant modification compared with last year's model is the new rear end following the design of the production model. Air venting slits ensure better dissipation of heat at the rear. The 3.6-litre six-cylinder boxer engine developed in Weissach is also based on the street-legal GT3 and develops maximum output of 420 bhp, 20 horsepower more than on the previous model. The sequential six-speed transmission with interruption of engine power enables the driver to shift up under full throttle without disengaging the clutch. The transmission itself has been optimised and the gear ratios adjusted to the characteristics of the engine. Weighing 1,150 kg in race trim, the new 911 GT3 Cup has a power-to-weight ratio of 2.7 kg per horsepower.
The 26 units of the 911 GT3 Cup built for the Porsche Mobil1 Supercup feature a special exhaust system with an even more striking sound pattern reminiscent of the Formula 1 racing scene as well as PCCB Porsche Ceramic Composite Brakes as exclusive highlights. Compared with conventional brake discs, PCCB reduces unsprung masses by 20 kg and sets new standards in terms of responsiveness, resistance to fading, and a long service life. The racing cars entered worldwide in the Carrera Cup feature a modified exhaust system and steel brake discs.
Porsche's Racing Department in Weissach is responsible for the fine-tuning and running in the 911 GT3 Cup cars. Deliveries will be directly from Weissach, depending on the country of destination and the schedules to be observed. While the cars for the Carrera Cup New Zealand have already been shipped, delivery of the racing cars for the Porsche Mobil1 Supercup and the Carrera Cup Germany is scheduled for early March 2008.
Specifications
Power Unit
Water-cooled six-cylinder boxer; 3,598 cc; stroke 76.4 mm (3.01"); bore 99.98 mm (3.94"); max output 420 bhp (309 kW); max torque 420 Nm (310 lb-ft); max engine speed 8,400 rpm; four-valve technology; dry sump lubrication; two-stage resonance intake distributor; central air intake; electronic MS 3.1 engine management; fuel injection (multi-point, sequential); fuel grade 98 RON premium plus unleaded; racing exhaust with fully controlled catalytic converter (400 cells); rear silencer with centrally mounted double tailpipe; special exhaust tailpipes for the Porsche Mobil1 Supercup.
Power Transmission
Six-speed gearbox with sequential jaw-type shift; compressed oil lubrication; oil/water heat exchanger; single-mass flywheel; hydraulic disengagement lever; 5.5-inch three-plate sintered metal clutch; limited-slip differential 40/60 %; rear-wheel drive.
Body
Monocoque body made of hot-galvanised steel; aerodynamically optimised front end with front spoiler; doors with side frames made of CFP and reinforced plastic door panels; rear lid with adjustable rear wing made of CFP; rear body panels made of CFP; air jack; welded-in rollcage; bucket-type racing seat (on driver's side only) with flame-resistant seat cover; six-point seat belt adapted for use of the HANS Head and Neck Support; electric fire-extinguishing system; 90-litre fuel tank; safety bar holding the battery in position.
Chassis and Suspension
Front: McPherson spring strut axle; Sachs gas pressure dampers; double coil springs (main and ancillary spring); front axle arms adjustable for camber; adjustable sword-type anti-roll bar; reinforced front axle crossbar with six-point fastening and double clamping; power steering with electrohydraulic pressure supply.
Rear: Multi-arm axle with rigidly mounted axle subframe; Sachs gas pressure dampers; double coil springs (main and ancillary spring); rear axle track arm adjustable for camber; rear axle tiebar reinforced and infinitely adjustable; adjustable sword-type anti-roll bar.
Complete suspension infinitely adjustable (height, camber, track).
Brakes
Brake system with balance bar control.
Front: Single-piece six-piston aluminium fixed callipers; Porsche Ceramic Composite Brakes (PCCB), inner-vented, 380 mm (14.96") in diameter; racing brake pads.
Rear: Single-piece four-piston aluminium fixed callipers; Porsche Ceramic Composite Brakes (PCCB), inner-vented, 350 mm (13.78") in diameter; racing brake pads.
Wheels/Tyres
Front: Three-piece BBS light-alloy wheels (9J x 18); ET 43 with central locking;
Michelin rain tyres (24/64-18).
Rear: Three-piece BBS light-alloy wheels (11J x 18); ET 30 with central locking;
Michelin rain tyres (27/68-18).
Electrical System
Motec display with integrated data recording; battery: 12 volt, 50 Ah, 90 Ah alternator.
Weight
Approx 1,150 kg (1,130 kg with PCCB).
[img:450:299]http://img509.imageshack.us/img509/984/ ... 0opdg0.jpg[/img]
RobS
Bericht door RobS » 01 dec 2007, 11:56
Bericht door GTRene » 01 dec 2007, 12:34
dat gewicht...en dat gekoppeld aan dat vermogen....... :twisted:
Dennis Cavallino
Bericht door Dennis Cavallino » 01 dec 2007, 21:47
Gave Cupracer. Na een jaartje cuppen ook in veel andere klassen goed inzetbaar.
Mike R32
Bericht door Mike R32 » 01 dec 2007, 21:57
Schitterende auto 8)
Wie dit vergelijkt met een plat geslagen kever ........ga je mond spoelen met zeewater :!:
Bericht door Bert ///M3 » 01 dec 2007, 22:00
Zal wel een aardig prijskaartje aan hangen :lol: Maar weinig ontwikkeling nodig, instappen en gas.
Vorige cup versie reed al 1.45~1.46 op CPZ volgens mij :)
Mark Nauta
Bericht door Mark Nauta » 01 dec 2007, 22:46
Zo!!! Dat is erg fijn zeg.
Niet wat voor over 2 jaar in de DSC André ;)
Dennis Cavallino
Bericht door Dennis Cavallino » 02 dec 2007, 00:07
Ik zie André liever in de GT3 Cup rijden dan DSC. Als opvolger van eeuwig kampioen Patrick Huisman.
Ok, nog liever zie ik mezelf daar rijden. 8)
Tom V
Bericht door Tom V » 02 dec 2007, 00:21
Ik hoop dat je de supercup bedoelt. Ik zie die Nederlandse Gt3 cup toendertijd als een van grootste aanfluitingen ooit in het nederlandse racetijdperk.
Dennis Cavallino
Bericht door Dennis Cavallino » 02 dec 2007, 00:46
Ja supercup inderdaad. :)
Bericht door Robin » 02 dec 2007, 13:37
[img:480:320]http://www.autoweek.nl/images/480/3/9d7 ... fe4ad3.jpg[/img]
topper, maar dan wel zonder die plakplaatjes.
Gebruikers op dit forum: Google [Bot] en 76 gasten
