BMW M3 CSL-RS Road Car
Bericht door RVV » 27 jun 2007, 16:34
In 2005 met Andre mee geweest naar Spa (toen de eerste rit gemaakt in de M3 CS die
Andre net een paar dagen had), daar was een Engelse M3 (CSL) meeting van het BM3W forum. Dexter was er ook voor een paar machtige foto's. Daar Tony ontmoet. Bekende van Andre. Tony reed in een Ferrari F430 stradale maar hij had ook zijn speciaal opgebouwde race CSL GTR conversie bij zich.
Deze auto.
[img:700:525]http://www.simpsonmotorsport.com/netima ... _image.jpg[/img]
http://www.simpsonmotorsport.com/defaul ... Race%20Car
BMW M3 CSL-GT Race Car
This race car is quite unlike any other race E46 M3 in that it was not built from a BMW Motorsport shell. Having looked at the shell, we decided that overall it was compromised in design in ways we would not accept, and also dictated the use of more expensive BMW Motorsport only parts. We wanted to produce a very fast E46 M3 that was cost-effective to run and for significantly less than the typical M3 GTR build, which can be incredibly expensive.
We started with a road car - but not any road car! We actually took an M3 CSL road car and stripped it entirely. These are readily available now for not much more money than a normal M3 coupe, and have expensive items such as the carbon roof and carbon airbox already in place. The entire shell was reworked heavily with a full welded roll cage and many body sections drastically changed to save weight. Every body panel is made from carbon fibre, with all the windows in Lexan, except for the windscreen which is lightwight glass. Even the bottom of the car is flat bodied, ending a carbon underbody diffuser at the rear. The massive front splitter and rear wing add real downforce to the car.
The fuel system uses 2 submerged Bosch Motorsport fuel pumps in a custom Fuel-Safe bag tank which is situated where the rear passenger seat wells used to be, central and low in the car.
The engine itself is a totally standard M3 CSL engine, with Motec ignition pack and a Motec M800 ECU. Power is 380bhp engine dyno tested which is impressive for a totally stock engine! It is very economical to use and lasts for almost 2 seasons with no work. The clutch is a standard Tilton triple plate item with a lightened flywheel which mates to the Drenth 6 speed fully sequential gearbox. This wonderful unit features full throttle up-shifts courteosy of the Motec. A customised propshaft carries drive to a 4.1 Drexxler diff rebuilt by us to our specification, which in turn feeds uprated driveshafts with stronger inboard and outboard joints. The front wheels are 10x18" and the rears are 11.5x18". These 3 piece split rim wheels are designed and manufactured by us and are of the centre lock variety. This when coupled with the 4 built-in air jacks, allow the wheels to be changed in no time in the pitlane.
The brakes system is AP 6 Pot calipers upfront on 356mm discs with AP 4 Pot calipers on stock CSL discs at the rear, with no servo or ABS, and running Mintex FR2 pads.
Exhaust system has no cats, two centre silencers and two rear silencers exiting to two single exhaust pipes. It is relatively quiet at 104db. The interior features a Sparco Superlight carbon race seat, a Pro-drive carbon steering column and a Pro-drive pedal box. All the information is fed to the driver via the Motec ADL dash logger.
The chassis features Intrax 4-way dampers, H&R front and rear anti-roll bars, Simpson bushes all round and Simpson rear adjustable camber arms. The rear diff assembly is very modified to provide the maximum in rigidity.
Weighing in at 1120kgs and packing 380bhp it is significantly faster than the road car it was born from (nearly 9 seconds a lap quicker around Donington for example). Performance puts it up with Porsche GT3 cup cars and Ferrari 360 Challenge cars. It really punches above its weight thanks to great aerodynamics and a very friendly chassis.
Maar nu is er ook een speciale road legal uitvoering gemaakt.
[img:700:467]http://www.simpsonmotorsport.com/netima ... _image.jpg[/img]
We have in development right now an extreme version of the M3 CSL for road use! Whilst we loved the basic CSL as a road car, we feel that it sits a little uncomfortably between a track car and road car. It is a bit too harsh as a general road car, and compromised as a track car. In our opinion, BMW really should have made something more akin to the Porsche GT3 clubsport or even the GT3-RS.
So, we decided to do it, using everything we had learned from building our CSL-GT race car. The care is now in its first stage of build with more to come over the next few months.
Current Specification:-
Blueprinted M3 CSL 3.2 litre Straight Six Engine
Uprated Valve Springs
Special Camshafts
Uprated Rod Bolts
Vanos Removed
Lightweight Engine Pulleys
Supersprint Lightweight Race Exhaust
Supersprint Race Cats
Supersprint Centre Pipe
Uprated Clutch And Lightened Flywheel
3.9:1 Drexler Plated Rear Differential
Simpson Solid Bushes All Round
Simpson Centre Lock Hubs
Simpson 10x18 Split Rim Front Wheels with 265 Tyres
Simpson 11.5x18 Split Rim Rear Wheels with 315 Tyres
Fully Welded Roll Cage
Full CSL Interior Modified To Suit Cage
Intrax 4-Way Adjustable Suspension
Turner Carbon Front Strut Brace
DL1 Datalogger
Recaro SPG Seats
Luke Harnesses
Simpson Custom GTR Bodywork
Simpson Custom Aero Fuel Filler
Simpson Carbon GT Rear Wing
AP Racing 6 Pot Front Calipers
Performance Friction Floating Front Discs
AP Racing 4 Pot Rear Calipers
AP Racing Rear Discs
Mintex FR6 Pads All Round
Road Legal!
The car will be treated to the latest ESS Supercharger some time in September 07
Re: BMW M3 CSL-RS Road Car
Bericht door Tom » 27 jun 2007, 16:39
Rico v Velzen schreef:Tony reed in een Ferrari F430 stradale
Een gewone F430 of een F430 Challenge? De Challange Stradale moet nog uitkomen.
Bericht door RVV » 27 jun 2007, 16:44
Challenge bedoel ik :oops:
Roman
Bericht door Roman » 27 jun 2007, 16:53
Wat een beest!
Mark Nauta
Bericht door Mark Nauta » 27 jun 2007, 16:58
Wat een brute bak, zo voor op straat.
Wat doet ie in pk's straks met die supercharger erop???
Aernoudt
Bericht door Aernoudt » 27 jun 2007, 18:06
Serieus leuk speelgoed :D
Sander S.
Bericht door Sander S. » 27 jun 2007, 20:58
leuk hoor, alleen oppassen dat je je er niet aan open haalt als je er langs loopt.
Fucking lelijk natuurlijk, maar het zal wel prima rijden :wink:
Gebruikers op dit forum: Geen geregistreerde gebruikers en 52 gasten
