Z4 m coupe Racer!!!
Z4 m coupe Racer!!!
Bericht door Andre » 28 feb 2006, 23:36
[img:1024:683]http://www.thecarconnection.com/images/ ... RLTCNQ.jpg[/img]
No BMW Without Racing
There'd likely be no BMW without motorsports, asserted the German maker's CEO, Helmut Panke, during a Geneva preview, Monday night. The automaker used the event to display its latest entry into the demanding Formula One series, as well as this version of the Z4 M Coupe. The track-ready version will make a whopping 400 horsepower out of its 3.4-liter in-line six. Expect the automaker to produce only a few hundred, according to company officials, with some expected to go to the U.S. when production begins mid-year. Whatever series it participates in, Panke said it is critical for the automaker to dominate. "BMW could not be the dynamic, most performance-focused car company if we weren't involved in motorsports," he insisted. "Step-by-step, we would lose our identity."
Bericht door Andre » 28 feb 2006, 23:39
[img:1000:600]http://i19.photobucket.com/albums/b165/ ... 005074.jpg[/img]
BMW Z4 M Coupé as motor racing kit.
Press release, 02/28/2006
The first BMW two-seater for Nordschleife fans and international customer teams.
Munich/Geneva, 27th February 2006. Unveiling in Geneva: On the occasion of the Automobilsalon, Prof Dr Burkhard Göschel, BMW Group Board Member Purchasing and Development, introduced a new racing car for customer motor racing. The Motorsport Version of the BMW Z4 M Coupé, which has already made a big impression as a production model, is the first two-seater BMW Motorsport offers for customer teams. When it came to the development, BMW faced a huge challenge: The car had to have what is needed to race successfully on the world's most demanding and spectacular racetrack, the Nürburgring's famous Nordschleife. The new motorsport coupé can be used by private BMW customer teams in the German Endurance Championship and in the Nürburgring 24-Hour Race.
The power unit of the beefy coupe is a BMW Motorsport designed 3.2-litre in-line 6-cylinder engine delivering about 400bhp, with the suspension area in particular benefiting from the knowledge gained from the successful BMW M3 GTR project.
With its varied component ranges, BMW Motorsport and BMW Racing Parts Distribution offer customer teams a new technology platform for use in many miscellaneous international racing and club sport series, with the Nordschleife enthusiasts not being the only interested party, as the brawny coupe also represents the perfect car for use in the Belgian Belcar series and other, non-European, endurance series.
The kit can be ordered from May 2006 at BMW Motorsport and will be available for an estimated € 250,000 (plus VAT).
Technical Data BMW Z4 M Coupé Motorsport Version
Length: 4415 mm
Width: 1880 mm
Wheelbase: 2493 mm
Front & Rear Overhang: 865 mm/774mm
Rear Wing Width: 1504 mm
Front & Rear Ground Clearance: 80 mm/90 mm
Front & Rear Tyres: Michelin 27/65-18, 28/71-18
Front Brake: Grey cast iron disc dia. 380 mm / 6 pot fixed calliper
Rear Brake: Grey cast iron disc dia. 320 mm / 4 pot fixed calliper
Drive Line: sequential 6-speed gearbox, sintered clutch
Engine Layout: six cylinder in line
Cylinder Capacity: 3246 cc
Bore x Stroke: 87 x 91 mm
Compression Ratio: 12,5:1
Max. Power: approx. 400 PS at 8200 rpm
Max. Torque: approx. 400 Nm at approx. 5750 rpm
Max. Revolutions per minute: 8400 rpm
Cylinder block: one-piece construction
Crankshaft: forged steel part
Piston: forged slipper skirt piston
Con-rod: Steel
Cylinder head: Aluminium, four valves per cylinder
Valve train: Two chain driven overhead camshafts with variable valve timing
Intake System: Six single throttle valves, Carbon fibre Air box with resonance induction optimised inlet pipes
Exhaust System: Multiple pipe manifold with silencer and catalytic converter
Lubricating System: Wet Sump Lubrication
Cooling System: Water / Air cooler
Flywheel: Steel
Fuel System: Inlet-Pipe Injection, one Injector per Cylinder, 5 bar injection pressure
Fuel: 5-star lead-free petrol, ROZ min=98
Fuel Tank Volume: 120 litres
Minimum Weight: 1200 kg in Nürburgring Specification
Engine Management System: BMW Motorsport ECU406 with two powerful microprocessors, Ethernet Interface and four CAN busses; Cylinder selective optimized Injection and Ignition; Pit-Speed-Limiter; Quick-Shift; Engine Log Book; Electronic Throttle Control; VANOS Control; Race ABS; Traction Control.
Energy Management: Distribution and Control of the electric energy through the BMW Motorsport POWER400 Control Unit; Networking of all Sensors and Actuators through a CAN Bus.
Electric loom: Weight optimised
Ignition coils: Six high performance pencil-type ignition coils with integrated ignition driver.
Sparkplugs: NGK high performance Sparkplugs
Instruments: Free programmable LCD Display with integrated shift lights
Steering-wheel: multiple function Steering-wheel with Quick-Release mechanism and display control
Michel P
Bericht door Michel P » 28 feb 2006, 23:39
Mooie cup klasse voor Hielke ;-)
Michel
Bericht door Knot » 01 mar 2006, 00:20
Dikke bak hoor, en nog ff opgeschroefd naar 400pk.
Wouter
Bericht door Wouter » 01 mar 2006, 00:33
wat een plaatje erg netjes gedaan
Dennis Cavallino
Bericht door Dennis Cavallino » 01 mar 2006, 10:23
By far de allergaafste fabrieks racer die ik de afgelopen jaren heb gezien!! Overtreft iedere Porsche, Ferrari, Maserati etc. als je het mij vraagt. Wat een mooie auto! [/i]
Martijn
Bericht door Martijn » 01 mar 2006, 11:11
Ben ik niet met je eens Dennis, de Aston DBR9 vind ik nog net ff iets gaver :D
Deze is wel erg cool, meteen ook in het nieuwe BMW Motorsport kleurenschema zo te zien. Sauber-BMW F1 team heeft hetzelfde.
Dennis Cavallino
Bericht door Dennis Cavallino » 01 mar 2006, 11:15
Mwaw, twijfelgevalletje :D
Maar die is ook extreem mooi ja.
Deze belijning/striping past perfect bij de bizarre Z4 vormen. Van die M3 GTR strepen zouden echt niet staan op deze auto.
Degene die voor de striping verantwoordelijk is snapt het wel.
Bericht door RVV » 01 mar 2006, 11:26
Wat een fantastisch mooi ding zeg, gelijk een nieuwe achtergrond op de PC !
Hielke
Bericht door Hielke » 01 mar 2006, 12:41
Michel Pol schreef:Mooie cup klasse voor Hielke ;-)
Michel
?? 250.000 voor de kit!
Maar als er een sponsor voor een miljoentje komt, dan heb ik er geen bezwaar tegen :D Mogen er ook nog wat andere forumbezoekers meerijden 8)
Bericht door Robin » 01 mar 2006, 13:24
Prachtig ding enzovoort enzovoort, maar ik zie liever de 320(s)i WTCC met speciale uitbouw of een E46 M3 GTR.
Lelijk is anders, maar een AM DBR9 staat (QUA LOOKS)mijlenver boven dit ding.
IMHO(over de looks dan he, de specs zijn 100 punten)
Bericht door Andre » 01 mar 2006, 13:25
Ik zie ook liever een wttc toerwagen of een m3 coupe gtr achtig ding robin.
Mari Oh Oh!
Bericht door Mari Oh Oh! » 01 mar 2006, 20:48
WOW! :shock:
Beter kan ik me even niet uitdrukken.
Gebruikers op dit forum: Bing [Bot], Google [Bot], wjt en 2 gasten
