S2000 Club Racer
Jan Visser
S2000 Club Racer
Bericht door Jan Visser » 05 apr 2007, 00:54
[img:1280:853]http://www.blogsmithmedia.com/www.autob ... 280_13.jpg[/img]
[img:1280:853]http://www.blogsmithmedia.com/www.autob ... 280_02.jpg[/img]
Honda decided to make our roving band of blogger's lives easier by not holding a press conference and instead just plopping the Club Racer version of the S2000 onto a stand for all to see.
The "track-worthy" variant of the S2K gets enough structural and body mods to make any time-attack junky weep, beginning with a quicker steering rack, stiffer springs and dampers and larger sway bars. Newly designed wider rear rollers gets shod in the finest Bridgestone Potenza RE070s and the new aero bits, comprised of a redesigned front clip, side skirts, rear bumper and spoiler, have been wind tested and racer approved.
In an effort to drop the pounds and low the center or gravity, Honda decided to nix the folding roof altogether and instead, replaced it with an aluminum hard top. The former home of the soft top gets remodeled with plenty of bracing to increase the S2K's chassis rigidity.
Sales of the S2000 CR will begin this fall and no production numbers were mentioned.
bron Autoblog
Tja.......die voorbumper :?
Morgen maar even zoeken naar de technische info. Die heb ik nog niet kunnen vinden.
Stéphane
Bericht door Stéphane » 05 apr 2007, 09:59
...quicker steering rack, stiffer springs and dampers and larger sway bars...
Ik denk dat het technisch hierbij blijft en dan nog wat plastic.
Bericht door Knot » 05 apr 2007, 10:55
Wel een gave foto!
Roman
Bericht door Roman » 05 apr 2007, 11:03
wat photoshopjes
[img:1280:853]http://home.comcast.net/~dackkwan/GPWCRa.jpg[/img]
[img:1280:853]http://home.comcast.net/~dackkwan/GPWCRb.jpg[/img]
[img:1280:853]http://home.comcast.net/~dackkwan/GPWCRc.jpg[/img]
[img:1021:671]http://img108.imageshack.us/img108/8624/crcepf1.jpg[/img]
En wat meer info
Honda builds a track toy as a retirement gift to its most revered engineer, and you can buy a copy.
BY MIKE DUSHANE, PHOTOGRAPHY BY JARED HOLSTEIN
April 2007
What’s your idea of retirement planning? At Car and Driver, our scribblers spend their golden years counting their air miles and grousing about the web interns. If you’re Shigeru Uehara, Honda R&D’s Executive Chief Engineer, you spend your last year on the job building a track-ready special-edition version of the S2000.
Lots of engineers build track toys, but not many get their cars approved for production. Uehara isn’t just any engineer, though; he’s credited as the father of the Honda S2000 and the Acura NSX and Integra Type R, the trio that convinced a generation of American tuners and enthusiasts that Honda is a legitimate performance car company. Uehara’s legacy is solid, so he doesn’t need to work on the NSX’s successor—he said through an interpreter that he’s leaving that to the next generation. Instead, his final gift to the enthusiast world is the S2000 CR.
Suspension and steering modifications
The S2000 CR has the same 237-hp, 2.2-liter engine as other S2000s, but don’t let that fool you into thinking it’s just a dress-up job. The most dramatic changes involve springs and shocks that Honda calls “significantly stiffer.” Although no figures are available, our experience with Uehara’s other creations like the Acura Integra Type R tells us that he knows the meaning of “significant.” Thicker anti-roll bars round out the suspension changes. A quicker steering ratio will allow drivers to avoid shuffling hands in tight corners. A limited slip differential and defeatable electronic stability control carry over from the regular S2000.
Tires
The S2000 CR’s biggest handling gain over the regular S2000 may come from gumball Bridgestone Potenza RE070 tires similar to those used on the former Japanese-market NSX-R. The 215/45R-17 front and 255/40R-17 rear tires have a treadwear rating of 140, which means they’re barely able to be called conventional street tires.
Front and rear spoilers
A ludicrously large body kit and a rear cowl fairing behind the seats are claimed to smooth airflow over the S2000 CR. But the most over-the-top aerodynamic modification is the massive rear spoiler. The wing has three distinct horizontal surfaces: the upturned outside sections produce downforce while a flatter center section smoothes airflow over the car. The whole affair is affixed with black supports that look more like a back yard racer’s weekend concoction than factory pieces, but who are we to argue if it works? Honda claims overall downforce on the rear axle at speed, a rare trait for a street car.
Weight savings and chassis
Air conditioning and the sound system are jettisoned in the name of weight savings, but you can add them back in as options. The S2000 CR also loses its power folding softtop to shed a few pounds, and in its place it gains a beefy rear strut tower brace with four mounting points. This is said to enhance the already stellar rigidity of the S2000’s shell so it won’t flex when cornering. A removable aluminum hardtop provides shelter from the elements and admission to tracks where open-top cars aren’t allowed. With the top off, the S2000 CR will weigh approximately 2765 pounds, almost 90 pounds less than the regular S2000.
It’s significantly faster on a track, according to Honda
The result of these changes is a claimed two-second reduction in the S2000 CR’s lap time around Honda’s Tochigi test track. That’s a huge difference; you could add 50 horsepower to a regular S2000 and you might not see your lap time drop that much.
Interior modifications
Every special edition needs to look unique, so the S2000 CR has a bunch of dress up features that distinguish it. The most obvious is the Apex Blue paint, which is a pearlescent bright blue evocative of Audi’s Sprint Blue. Black badges and gunmetal gray five-spoke wheels round out the exterior mods. Abundant yellow stitching on the doors, steering wheel, seats, and shifter (which has shorter throws than the already insanely short ones in the regular S2000) complements yellow woven seat inserts. Faux-suede seat bolsters and door panels replace the leather items on the regular S2000 in the name of grip, and they’ll also broaden the S2000 CR’s appeal to PETA members. Faux carbon fiber trim is a slavishly trendy addition, but we can forgive anything in a car this raw.
Pricing
The S2000 CR goes on sale in the fall of 2007 as a 2008 model. The car shown at the New York show isn’t 100 percent production correct, but the body kit, spoiler, and wheels are accurate renditions of what you’ll see in dealers. Pricing isn’t confirmed, but it will certainly be more than the regular S2000’s $35k base price and probably less than $40k. Given the expected production volume of less than 2000 units (no limit was confirmed), Honda will lose money on the deal, a fact that company representatives actually admit. Such corporate honesty is rare, but Honda can afford it. The S2000 CR is a fitting tribute to the man who put “Honda” and “performance” together in the popular lexicon. Let’s hope it’s a harbinger of more great things to come and not a last hurrah.
Kasteel
Bericht door Kasteel » 05 apr 2007, 11:56
De optische aanpassingen zijn echt afschuwelijk!! Hoe groot is eigenlijk de kans dat dit model de Europese bodem haalt?
Roman
Bericht door Roman » 05 apr 2007, 14:42
Autoweek zegt dit:
Honda zet de S2000 nog eens even in het zonnetje met een speciale variant: de Club Racer. Meer pk’s en minder gewicht zijn de twee belangrijkste prioriteiten geweest bij het ontwikkelen van de auto.
Het lijkt nauwelijks mogelijk, maar de ingenieurs van Honda hebben nog wat extra vermogen uit de hoogtoerige viercilinder weten te persen. Het vermogen bedraagt nu 257 pk, 17 pk meer dan de gewone S2000. Wel moet hierbij worden vermeld dat dit vermogen komt uit de grotere, Amerikaanse motor van de S2000: een 2,2-liter viercilinder.
Honda heeft de softtop verwijderd om gewicht te besparen. Wie per se zonder een nat pak thuis wil komen, heeft geen andere optie dan het monteren van een optionele hardtop voor het vertrek.
We hebben het nog over een prototype, maar het is al duidelijk dat Honda de lichtgewicht in september in productie neemt. Of de auto in Amerika blijft of dat Honda ook geïnteresseerde Europeanen in hun behoefte voorziet, is nog niet bekend.
Bericht door Tom » 05 apr 2007, 16:08
257 pk op een lager gewicht (weegt nu 1220kg) is dikke prima!!
Roman
Bericht door Roman » 05 apr 2007, 16:30
Tom schreef:257 pk op een lager gewicht (weegt nu 1220kg) is dikke prima!!
Ben toch alleen niet onder de indruk, 240 pk uit een 2 liter. Maar 257pk uit een 2.2 liter. Daar had toch wel wat meer uit kunnen komen? En waarom niet 257 pk uit die ouwe vertrouwde 2 liter?
Misschien die 257pk versie pakken en nog even langs Spoon gaan?
In ieder geval zal 257pk inderdaad wel lekker gaan in die s2000. Altijd al een echte pure rijders auto gevonden. Zou er graag een voor de deur hebben. Zeker met het weer hierzo.
Bericht door Tom » 05 apr 2007, 16:33
De 2.2 liter heeft in Amerika een iets lagere redline als de 2.0 die ze hier leveren. Als die redline zo blijft, dan vind ik 257pk nog steeds erg netjes.
257pk uit een 2.0 zal wel erg krap aan worden :)
Bericht door RVV » 05 apr 2007, 20:08
Vind hem ergens wel stoer !
Stéphane
Bericht door Stéphane » 05 apr 2007, 20:45
@Roman: De S2000 zit al redelijk aan zijn maximum. Ik heb gelezen dat voor deze motor toch wel wat speciale dingen zijn gedaan, in tegenstelling tot b.v. de blokken voor de CTR/ITR.
Ik denk dat de aanpassingen ook wel verbeteringen zullen zijn, alhoewel het optische deel voor mij niet helemaal nodig is. Sterker nog: ik vind het gewoon lelijk. Een Spoon S2000 doet mij dan iets meer, alhoewel die ook redelijk wat werk er aan heeft gehad:
[img:1280:1024]http://www.spoon.jp/journal/wallpaper/d ... 024_03.jpg[/img]
[img:1280:1024]http://www.spoon.jp/journal/wallpaper/d ... 024_02.jpg[/img]
[img:1280:1024]http://www.spoon.jp/journal/wallpaper/d ... 024_04.jpg[/img]
Jan Visser
Bericht door Jan Visser » 05 apr 2007, 21:34
Tom schreef:De 2.2 liter heeft in Amerika een iets lagere redline als de 2.0 die ze hier leveren. Als die redline zo blijft, dan vind ik 257pk nog steeds erg netjes.
En toch valt dat nog wel mee Tom. Met een iets ruimer bemeten uitlaat lijn,nog scherpere nokkenassen, itb's en een andere chip ben je er al. Je gaat er zelfs overheen want de Japanse versie van de S2K heeft standaard al 250 pk's.
Zoiets had Honda van mij wel mogen doen. Ik vind de specs van de S2k CR toch niet iets wat ik verwacht had van Honda. Het is het allemaal net niet. Het is mij nog niet hardcore genoeg. Het had wat mij betreft wel een Spoon of Amuse tegenhanger mogen worden. Ze noemen het toch niks voor niks een club racer? Als ze een beetje in de buurt waren gekomen had ik het knap gevonden. Ik vind dit tegenvallen in iedergeval.
Bericht door Tom » 05 apr 2007, 22:35
Bah ik blijf echt verliefd op dat ding..die spoilers hoeven van mij niet maar de rest is echt goed. meer mensen zouden er eens in moeten rijden om overtuigd te raken :D
Stéphane
Bericht door Stéphane » 05 apr 2007, 22:39
Tom schreef:Bah ik blijf echt verliefd op dat ding..die spoilers hoeven van mij niet maar de rest is echt goed. meer mensen zouden er eens in moeten rijden om overtuigd te raken :D
Ik heb er in gereden, Tom. En ik was ook al overtuigd :D
Briljante auto. Collega van me had er eentje trouwens.
Damir Vukovic
Bericht door Damir Vukovic » 07 apr 2007, 08:57
Vind het ook niet zo mooi..maar wel geweldig dat ze gewoon zo'n auto gaan bouwen!
Softtop verwijderd en vervangen door bracings, andere ophangingsgeometrie en hardware, stuggere rubbers...dat ding raken ze aan de straatstenen niet kwijt denk ik...+/-200 stuks is qua verkoop echt wel de max.
Gebruikers op dit forum: Amazon [Bot] en 7 gasten
