BMW 1600ti “upgraden”
Fintelman
Auto: BMW 1600 touring
Bericht door Fintelman » 18 jan 2025, 12:54
Redelijk nieuw hier en in bezit van 1600 touring uit 1972. Heb alles liggen om er een 1600ti van te maken. Tips om er wat meer PK’s uit te halen zijn van harte welkom.
Vr gr
Eric
Re: BMW 1600ti “upgraden”
Bericht door Robin » 18 jan 2025, 13:55
Welkom, heb je foto's? Oom van me had ook zoiets toendertijd herinner ik me.
Bericht door Joy » 18 jan 2025, 14:59
The best thing you can do is leave it stock.
I've tried bolting on all types of things on to my 1600s over the past 41 years, But, in the end I came to the conclusion that the stock single barrel carb works best with this motor. Side drafts are a big headache. Alpina made bolt-on kits with properly jetted Weber DCOE side draft carbs for the stock motor. But, it just yielded an additional 10hp. And, good luck finding one of these kits unless you want to duplicate one by ordering the Aplina prescribed jets and other components for the 40DCOE carbs. The factory 1600ti had side draft Solexes with 9.5/ 1 compression ratio pistons which yielded an additional 20hp. Both, the standard 1600-2 and 1600ti use the same cam. Bolting on larger carburation on a stock motor doesn't help much. Fuel mileage suffers significantly, less 5-10MPG with side drafts.  I've also tried the two barrel 32/36 Weber, but its only advantage is at full throttle. Your bottom end torque will suffer and you will loose 5mpg. Adding a header will also kill low end torque and decrease mileage. And, the same applies to free flow exhaust. You can use a sport resonator, but you got to use a stock muffler to maintain back pressure. The only bolt on item that helps and increases torque is the factory non-smog exhaust manifold. I've noticed a difference immediately. You can only source it in the US from the 1967 1600-2, which had no smog equipment. The 1600 motor produces less torque in comparison to the 2.0L, but it is much smoother and revier, mainly due to the short stroke crank and lighter components. If you got the smog air pump installed, get rid of it. It robs a lot of power.
De fiscalist
Auto: Polestar 2, Ex Alpina B5, B3
Bericht door De fiscalist » 18 jan 2025, 17:45
Leuk nog een 02 rijder..;)
Als het echt krachtiger moet, dan is het beste om er een 2 liter in te hangen, daar kunnen je carbs ook op. Samen met een goede uitlaat en een sneller nokkenas, gaat dat je een stuk levendiger autootje opleveren…;)
Bericht door Martijn_bmw » 18 jan 2025, 20:00
Foto’s graag :) leuk die 02 serie!
Bericht door Philipoo » 19 jan 2025, 13:31
LS swappen zorgt voor veel extra vermogen :)
HSR
Bericht door HSR » 19 jan 2025, 14:11
Door dit topic realiseer ik me opeens dat ik nog een 2 liter kop heb liggen met BMW motorsport 300gr nokkenas. Kopen?
Fintelman
Bericht door Fintelman » 23 jan 2025, 10:03
Bestanden foto’s te groot om te uploaden. Zal eens zien hoe ik dit moet doen. NB; dank voor de tips. Ga er zaterdag mee aan de slag. Heb een 2.0ltr blok liggen. Wat wil je voor die kop HSR?
Bericht door Martijn_bmw » 23 jan 2025, 19:51
https://postimages.org/
Hier kan je foto’s uploaden en dan de link voor fora in je post plakken :)
Fintelman
Bericht door Fintelman » 13 feb 2025, 22:57
Fintelman
Bericht door Fintelman » 22 feb 2025, 18:03
Fintelman
Bericht door Fintelman » 22 feb 2025, 18:04
Kan iemand mij wellicht helpen aan een RVS uitlaatspruitstuk voor M10 blok? Heb 2.0 ltr liggen. Hoe lang dat gaat duren voordat hij erin hangt weet ik nog niet. Gr en fijne avond, Eric
De fiscalist
Bericht door De fiscalist » 23 feb 2025, 09:13
Zoiets??
Hiermee loopt een standaard 2 liter al een heel stuk beter is mijn ervaring
https://www.wallothnesch.com/faecherkru ... 01-00.html
Fintelman
Bericht door Fintelman » 04 mar 2025, 22:25
Zoiets bedoel ik idd, maar had gehoopt op iets goedkoper….😉
Milka
Bericht door Milka » 05 mar 2025, 13:55
Spaghetti rvs en goedkoop gaat helaas niet samen.
1.6 klimt wat sneller in de toeren dan een 2.0
Maar zoals fiscalist zegt wil je meer
Ga voor een 2.0 en die koop je ook niet meer voor klein geld helaas. Boeit originaliteit je niet zo pak dan een e36 blokje.
In beide gevallen. Ook voor een 5 bak gaan, geeft je een stuk meer rust op de snelweg.
Gebruikers op dit forum: Majestic-12 [Bot], Robbert92, Semrush [Bot], Spinazie en 53 gasten
