Hello electric car fans,
I would like to present you a small survey and would be very pleased if you take 10 minutes and answer it.
It's about plug-in hybrids, these vehicles have besides the electric motor also a gasoline engine to cover longer distances. They are preferred for tax purposes, especially if they are used as a company car. Unfortunately, they are often criticized because they are often not used as intended. The charging rate that is too low and a consumption higher than expected, are noted. Fraunhofer ISI, together with ICCT, is currently investigating the real-world use of these vehicles. (something similar from last year: SPAM).
For this purpose, a survey has been launched to investigate the real-world use of plug-in hybrid. If there are any questions about the survey, you can find contact information and the survey at the following link:
SPAM
Best regards,
Marc
Survey on plug-in hybrids
electriccars_ISI
- Auto: BMW i3
- Fabian
Re: Survey on plug-in hybrids
Flikker toch op met die rommel
- Luco
ja ga naar het bomenknuffelforum.
Onlinesmiley
Zed240
EVs ≠ Driving-Fun
I think the dealer can lease out the boordcomputer en seen how much times you byloaded over the amount of driven kilomieters. Then you know they only used the burningengine in stead of the batteries…
Gebruikers op dit forum: Google [Bot] en 45 gasten
