BMW M2, M3, M4 Performance remblokken set compleet
Gesloten
jacobt
Bericht door jacobt » 17 aug 2019, 07:43
Heb nog een complete set remblokken ongebruikt liggen, gaat alleen om de Performance remblokken.
Uit een Bmw M4 van okt. 2018. Remmen ziet niet gebruikt
OEM BMW nummers
34112284969 Voorremblokken' (nieuwprijs circa €281 euro)
34212284989 achteremblokken (nieuwprijs circa €170 euro)
Voor de hele set vraag ik €300,-
Repair kit, brake pads
Part 34112284969 was found on the following vehicles:
•2' F87 M2   (11/2014 — 06/2017)
•2' F87 M2 LCI   (09/2016 — 03/2019)
•3' F80 M3   (04/2012 — 06/2015)
•3' F80 M3 LCI   (01/2015 — 10/2018)
•4' F82 M4   (02/2013 — 02/2017)
•4' F82 M4 LCI   (05/2016 — 03/2019)
•4' F83 M4   (06/2013 — 02/2017)
•4' F83 M4 LCI   (05/2016 — 03/2019)
Will racing pads again be available for the M compound brakes of the new BMW M3 and BMW M4?
Yes, a new sport pad will be available under the name of ‘M Performance Sport Brake Pad’; this was developed directly alongside the new brakes.
What are the advantages and disadvantages of these sport pads?
The life expectancy of these pads is considerably longer at the kinds of high temperatures that typically occur on the racetrack. While the standard pad can display a drop in friction coefficient at high temperatures, known as fading, the friction coefficient value of sport pads is far more stable.
In general, operational noise can be generated with any high-performance brake under certain driving conditions. However, with sport pads, we do without any form of comfort factor in the car components, which means that considerable braking noise is simply a fact of life for people who choose to use them.
Sport pads are more expensive and act considerably more fiercely on the brake discs. Disc wear is several times higher than that of standard brake pads. Which is why we require that every time a set of sport pads is fitted, new discs also have to be installed. For this reason, we will be offering sport pad kits, consisting of the actual pads plus the required brake discs.
Re: BMW M2, M3, M4 Performance remblokken set compleet
Bericht door matthyssie » 27 aug 2019, 08:48
Passen als t goed is ook in de M sportremmen van de normale modellen.
jacobt
Bericht door jacobt » 27 aug 2019, 16:31
Klopt, past in de niet ///M modellen met performance brakes.
Bedankt voor de aanvulling
Megator
Auto: BMW M2C
Bericht door Megator » 25 sep 2019, 14:33
Iets klopt hier niet, de onderdeel numers zijn voor de "normale" remblokken en niet de "m performane" of pagid remblokken.
zie hier https://www.motorsportparts.nl/bmw/bmw- ... n-set-voor
Dus om welke gaat het? de OEM M blokken of de "m performance" blokken?
jacobt
Bericht door jacobt » 25 sep 2019, 19:02
Welke wil je hebben?
Megator
Auto: BMW M2C
Bericht door Megator » 26 sep 2019, 15:25
Deze part #s 34112284765 en 34212284766 dat zijn de M performace remblokken en niet de standard M blokken.
jacobt
Bericht door jacobt » 26 sep 2019, 20:57
Verkocht
Gesloten
Gebruikers op dit forum: Pfhmulder en 50 gasten
