Sperdif Team MFactory BMW 130i
StefanW
Bericht door StefanW » 06 sep 2017, 20:15
Een sper dif voor de BMW 130i!
Dit torsen sper is een sper wat gebruik maakt van wormvormige tandwielen die in elkaar grijpen, het duurt even voordat er sper optreed en als 1 van de wielen vrijwel geen grip heeft dan zal deze ook niet sperren. Verder is dit altijd beter dan een open differentieel, is er geen extra onderhoud nodig in vergelijking met een open differentieel.. Een Quaife of wavetrack gebruikt dezelfde techniek.
The best way to gain a prominent advantage over the competition is to do it with the MFactory Helical Limited Slip Differential. The smooth consistent distribution of power to the wheels with the MFactory Helical LSD puts the power-to-the-ground and maximises your vehicle's traction. A must for any car be it stree, strip, or track.
What exactly does an LSD do you ask? well without an LSD your car is actually 1 wheel drive, in that it can't supply torque to both wheels at the same time and will only supply torque to the wheel with less grip, which is what the shortfall is to an open differential (what most vehicles have).
An LSD only lets the wheels spin at different speeds by a limited amount (typically this is a percentage difference) which is when the differential locks and both wheels get power. This is not how locked differentials work such as in off road trucks which supply equal torque and rotational speed to both rear wheels at the same time, which can cause issues with handling.
Features:
Industry first, 30-day Feel the Torque™ money back guarantee, and a Limited-Lifetime Warranty!
Forged and Cryo-tempered
Advanced Shot Peening technology for increased surface hardness
Designed to withstand the extreme shock loads of competition-level drag racing
Maintenance-free gears eliminate the need for special fluid or rebuilds associate with typical plate LSDs.
Lock-free operation ensures no adverse steering response.
As a break-in procedure, we recommend changing the fluid after the first 3-400 miles of use
Nieuw in doos: 799 euro
AfbeeldingUntitled by
Meer info:
http://store.teammfactory.com/e8x-128i- ... atio-3-15/
StefanW
Re: Sperdif Team MFactory BMW 130i
Bericht door StefanW » 07 sep 2017, 11:21
Gereserveerd!
Bericht door Martijn_bmw » 07 sep 2017, 16:24
zo dat ging snel :)
StefanW
Bericht door StefanW » 11 sep 2017, 22:35
Zkers! Verkocht!
Bericht door indobesar » 11 sep 2017, 22:43
Toch jammer als je blijkt de 130i te houden! ;)
StefanW
Bericht door StefanW » 11 sep 2017, 23:05
Ja komt volgend jaar wel weer :)
Bericht door matthyssie » 11 sep 2017, 23:37
Ik regel niet nog 1 met zoveel korting voor je..
Bericht door MParallel » 11 sep 2017, 23:43
"..is er geen extra onderhoud nodig in vergelijking met een open differentieel."
Welk extra onderhoud? Aan een open diff heb je helemaal geen onderhoud, laat staan extra.
Bericht door Tim N » 17 sep 2017, 20:25
MParallel schreef: 11 sep 2017, 23:43 "..is er geen extra onderhoud nodig in vergelijking met een open differentieel."
Dat staat er toch?
Bericht door MParallel » 18 sep 2017, 00:27
Tim N schreef: 17 sep 2017, 20:25
Dat staat er toch?
Dat staat er niet.
Er staat geen extra onderhoud Tim. Sleutelwoord hier: extra. Wat impliceert dat er onderhoud nodig is, alleen geen extra onderhoud.
Aangezien in mijn ogen een open diff helemaal geen onderhoud nodig heeft, dus al helemaal geen extra, was ik benieuwd welk niet-extra onderhoud hier bedoelt wordt.
FreudeamFahren
Bericht door FreudeamFahren » 18 sep 2017, 08:41
Wat Stefan denk ik bedoelt is dat een torsen diff minder onderhoud behoeft dan een platensper, omdat er geen platen in zitten die kunnen verslijten. En dat een SMG een automaat is. Dat bedoelt ie ook.
Bericht door Arthur » 18 sep 2017, 11:48
StefanW
Bericht door StefanW » 18 sep 2017, 18:44
haha was gewoon een copy paste :P
http://www.motorsportparts.nl/bmw-e60/a ... m240i-545i
maar bedankt voor het meedenken :mrgreen:
Bericht door Tim N » 19 sep 2017, 16:24
Weet iemand waarvoor die twee pluggen in het Diff zitten??
MParallel schreef: 18 sep 2017, 00:27 Aangezien in mijn ogen een open diff helemaal geen onderhoud nodig heeft, dus al helemaal geen extra, was ik benieuwd welk niet-extra onderhoud hier bedoelt wordt.
Bericht door Downforce Hans » 19 sep 2017, 16:41
Ik zie goed gereedschap........ :thumbup:
FreudeamFahren
Bericht door FreudeamFahren » 19 sep 2017, 17:15
Een om de olie eraf te laten lopen en een om hem bij te vullen?
Bericht door Tim N » 24 sep 2017, 20:46
Bericht door matthyssie » 24 sep 2017, 21:23
Een 130i diff heeft alleen een vulplug ;-).
Als je hem leeg wil laten lopen moet je het deksel eraf halen.
Bericht door ///Joost » 24 sep 2017, 22:40
FreudeamFahren schreef: 18 sep 2017, 08:41 Wat Stefan denk ik bedoelt is dat een torsen diff minder onderhoud behoeft dan een platensper, omdat er geen platen in zitten die kunnen verslijten. En dat een SMG een automaat is. Dat bedoelt ie ook.
ik moest lachen. :tooth:
FreudeamFahren schreef: 19 sep 2017, 17:15 Een om de olie eraf te laten lopen en een om hem bij te vullen?
anti-climax... :? ;)
TLRS
Bericht door TLRS » 26 sep 2017, 18:24
Grote, plastic uitjectiespuit met een slangetje..
Gebruikers op dit forum: Geen geregistreerde gebruikers en 64 gasten
