Olie filter remote
Ruby
Olie filter remote
Bericht door Ruby » 13 mei 2017, 18:29
mocal-remote-oil-filter-head-right-to-left-3-4-unf-filter-thread-3-8-bsp-temp-sender-572-rfh1h-3182-p.jpg
mocal-remote-oil-filter-head-right-to-left-3-4-unf-filter-thread-3-8-bsp-temp-sender-572-rfh1h-3182-p.jpg (67.46 KiB) 487 keer bekeken
Heb een mocal oil remote over van mijn project, dus ongebruikt.
Stroomt van rechts naar links, zie pijl op foto.
Remote Filter Head
Deze is geschikt voor auto's met een 3/4 UNF aansluiting op de oliefilter.
Mocal Remote filter heads are designed to relocate the engine oil filter if there is a limited amount of space in the original position. A remote filter head is perfect for when an engine conversion or other modifications are in place.
Supplied with a shorter mounting bracket which only allows for an 80mm oil filter with a 3/4 UNF thread to be used. Most Ford filters will fit.
The remote filters head are designed such that they will flow left to right or right to left. They are also available with an option of a take off, this means fitment of a temperature or pressure gauge or switch is possible.
1/2 inch BSP female inlet, oulets and adaptors are available separately to suit various plumbing options.
25 euro
cbubeneck@ziggo.nl
