Harman Kardon AVR 2550 S audio versterker/receiver
mark123
Bericht door mark123 » 05 nov 2013, 13:54
In verband met overbodig te koop:
Audio
Surround System Class 5.1 channel
Amplifier Output Details 40.0 Watt - 8.0 Ohm - 20 - 20000 Hz - THD 0.07 % - 2.0 channel(s) ( Center ),
40.0 Watt - 8.0 Ohm - 20 - 20000 Hz - THD 0.07 % - 1.0 channel(s) ( Front ),
40.0 Watt - 8.0 Ohm - 20 - 20000 Hz - THD 0.07 % - 2.0 channel(s) ( Main ),
50.0 Watt - 8.0 Ohm - 20 - 20000 Hz - THD 0.07 % - 2.0 channel(s) ( Rear )
Sound Output Mode Surround Sound
Audio D/A Converter 24bit / 192kHz
Built-in Decoders DTS decoder,
Dolby Pro Logic II,
Dolby Digital
Surround Sound Effects VMAx virtual surround sound
Digital Sound Processor (DSP) Yes
DSP Presets VMAx,
Logic 7
Input Impedance 47.0 KOhm
Input Sensitivity 200.0 mV
Response Bandwidth 10 - 100000 Hz
Signal-To-Noise Ratio 95.0 dB
Output Channel Qty 5.0
Bass Control Yes
Treble Control Yes
Additional Features Midnight Mode
Tuner
Tuner Type Radio tuner - AM/FM - Digital
Tuner Frequency Range AM: 520 - 1720 kHz,
FM: 87.5 - 108 MHz
Preset Station Qty 30.0
Antenna Form Factor Loop AM / wire FM
Signal-To-Noise Ratio 70.0 dB
Supported RDS Functions PTY,
RT,
CT
Inputs & Outputs
Headphone Jack Yes
Coaxial Digital Input Yes
Coaxial Digital Output Yes
Optical Digital Input Yes
Optical Digital Output Yes
Display
Display dimmer Yes
Prijs: € 75,-
Op te halen in Helmond of Nijmegen.
