2013 RS6
2013 RS6
Bericht door indobesar » 05 dec 2012, 14:38
The new third-generation Audi RS 6 demonstrates all that’s wrong with the latest RS 4 – a car which was launched less than six months ago. Like its smaller sibling the RS 6 comes as an Avant version only, they both come with a V8 TFSI engine, but that’s about where the similarities end.
You see, whereas the RS 6 makes its entrance at the top of its class, the RS 4 appears out-of-date before it even goes on sale. Let me explain.
Audi engineers have been able to reduce the weight of the new Audi RS 6 Avant by approximately 100 kilograms compared with its 2,025kg predecessor – making it around 130kg more than the RS 4.
Unlike the 442bhp/317lb-ft naturally-aspirated 4.2-litre V8 TFSI engine in the RS 4, the new RS 6 is powered by a twin-turbo 4.0-litre V8 TFSI engine with 552bhp and 516lb-ft (700Nm) of torque. That’s 20bhp less than the outgoing V10 RS 6, but with 37lb-ft (50Nm) more torque available between 1,750 and 5,500 rpm.
Despite the slight drop in power, with nearly 8% more torque and less weight, the new RS 6 is actually quicker than its predecessor – covering the 0-62mph increment in 3.9 seconds compared to the outgoing car’s 4.6 seconds.
Top speed is electronically governed to 155mph, but this increases to 174mph when the optional Dynamic package is specified. Opt for the Dynamic plus package and the RS 6 is let off the leash to achieve 189mph.
Perhaps the biggest surprise though, comes from the new engine’s efficiency – while the V10 RS 6 was capable of 20.4 mpg and 333 g/km of CO2 emissions, the new car offers a quite astounding 28.8mpg with CO2 emissions of 229 g/km. To put my earlier point in perspective, that’s 2.4mpg better than the latest RS 4 and 17 g/km kinder to the environment. From a model produced by the same manufacturer but with 63% more torque.. Go figure.
This time around, there’s more to the RS 6 than its engine. Whereas its predecessor felt like a blunt heavy instrument, there’s hope that the third-gen RS 6 has acquired some newfound subtlety.
At the heart of the quattro permanent all-wheel drive system with torque vectoring is a self-locking centre differential with an elevated locking value. There’s also a sport differential fitted on the rear axle, which distributes its power steplessly between the rear wheels for greater agility and stability.
Adaptive air suspension is fitted as standard, although this can be replaced by sports suspension plus with Dynamic Ride Control (DRC) as an option. Whereas the air suspension lowers the car by 20mm, the sports suspension plus system employs steel springs and three-way adjustable shock absorbers, interconnected diagonally by means of oil lines and a central valve control unit.
This is the same principle used on the previous RS 6, which proved either too firm (in sport mode) or too soft (in normal), so it might be worth waiting for the road tests before finalising your order.
Another new system being offered on the RS 6 is Dynamic steering, which allows the driver to steplessly vary the ratio and boost of the steering, via Audi’s drive select panel.
Brakes receive an upgrade with a choice of ventilated steel discs in 390mm diameter or 420mm diameter carbon fibre-ceramic discs. Six-piston calipers are fitted, in either black (for the standard discs) or red (for the carbon ceramic options).
High-gloss, 20-inch, forged alloy wheels come fitted as standard in a seven twin-spoke design, while a choice of three 21-inch cast alloy wheels with either high-gloss silver, polished black or polished titanium-look finish will be available at extra cost.
Along with the usual RS-styling features that you can see in the pictures, Audi are offering two optional exterior design packages – Matte Aluminium or Carbon. The Carbon appearance package, in addition to offering a more stealthy look, exaggerates the styling of the front splitter and rear diffuser.
There’s a new feature to play with in the RS menu of the DIS (Driver Information System) which uses a shift-system, illuminated by green lights which glow brightly as the engine’s revs increase.
As the driver approaches the red line, the lights turn red and then start to ‘blink’ – a gimmick perhaps, but a useful one, given how quickly the RS 6 is likely to hit that red line in the lower gears.
Despite the improvements made to the latest RS 6, Audi has chosen to price the new model around £800 cheaper than its predecessor – at £77,000. That’s still £3,900 more than the identically-powered BMW M5 (which incidentally offers 28.5 mpg and 232g/km of CO2), but well ahead of Porsche’s £123,776 542bhp Panamera Turbo S which also falls behind with its 24.6mpg and 270g/km CO2 performance.
If that’s not enough of a clincher, then you might like to know there’s switchable flaps in the RS 6′s exhaust system, which make its spine-tingling V8 howl even louder at the touch of a button. Order books open in January, with first deliveries in the summer of 2013.
The Enigma that is the latest RS 4 Avant..
When we asked Audi UK back in June why the RS 4 hadn’t made a significant step forward in engine performance, the answer we received was as follows, “We introduced turbocharging back in 1980 with the Audi quattro – we now have turbocharging, supercharging and high rev concepts, each application chosen to suit the character of the car. Clearly each has its own engineering challenges, but the decision was made for the RS4 to go for ‘high revs’.”
I’ll leave you to draw your own conclusions on Audi’s RS product strategy – historically Audi’s RS models have been turbocharged. And are produced as Avant models only.
The second generation B7 RS4 broke this trend and was a great all-rounder (I owned one myself), but Audi enthusiasts have been undeniably outspoken in voicing their preference for turbocharged RS’ models.
The latest RS 6 would appear to prove why that’s the smart decision for a company that likes to express its brand with the slogan, Vorsprung durch Technik (Advancement through technology). I see the progress in Audi’s third-generation RS 6, so forgive me for not ‘getting’ its slightly-smaller sibling.
The enigma will be further brought into contrast next year when BMW launches its turbocharged straight-six M3. By 2013 the brand which invented the high-revving sports saloon will have completed its ‘M’ migration over to forced-induction, ironically the ground that Audi used to own.
http://skiddmark.com/2012/12/all-new-au ... storms-in/
Re: 2013 RS6
Bericht door Tristan » 05 dec 2012, 14:44
100kg lichter gelukkig. Ziet er bruut uit al is het weer moeilijk te herkennen tussen de RS4 en RS6.
Re: 2013 RS6
Bericht door Robin » 05 dec 2012, 14:47
Prachtkar, veel mooier dan ANY BMW(serieus incl M5 etc) maar cdit snap ik niet?
RS4 is toch atmo inderdaad?
Ze wegen wel vreselijk teveel net als alle concurrenten.
Die RS4 met z'n CO2 uitstoot tov z'n 100 pk en 6000NM sterkere broer. Turbo it is!
Of 't nou 1800 of 1900 kg weegt dan maar de RS6 graag!
Re: 2013 RS6
Bericht door Macboy » 05 dec 2012, 15:08
:love:
Sperdy
Re: 2013 RS6
Bericht door Sperdy » 05 dec 2012, 17:05
Laatste foto: geeneens een zonnekleppie voor dat geld?
Voor de rest: lekkere rechtuitbrander. Dat is leuk. Voor de rest smakeloze hokken.
Re: 2013 RS6
Bericht door GTRene » 05 dec 2012, 18:56
interieur hebben ze vaak wel goed voor elkaar bij Audi
Re: 2013 RS6
Bericht door Robin » 05 dec 2012, 19:16
Da's 'n 10 voor interieur, en voor exterieur geef ik 'm 'n 9 terwijl ik niet van stationwagons houdt.
Jongens, de intapversies van Audi zijn netjes en boring maar verder niks negatiefs op aan te merken qua designflaws( uitzondering A5/7 heb ik moeite met 't schijtende hond model a la Panamera', maar de dikkere en dikste versies zijn oogstrelend in ´t kwadraat. Rijden doet ´t vanaf ´n S4-RS4 blijkbaar wél goed, daaronder knudde.
Rebel
Re: 2013 RS6
Bericht door Rebel » 05 dec 2012, 19:24
Robin schreef:Da's 'n 10 voor interieur, en voor exterieur geef ik 'm 'n 9 terwijl ik niet van stationwagons houdt.
Sprak de koning van het circuit.... die dagelijks 37 minuten in een auto zit.....Humor! :D ;-)
Re: 2013 RS6
Bericht door Robin » 05 dec 2012, 19:31
Re: 2013 RS6
Bericht door Robin » 05 dec 2012, 19:41
david.
Re: 2013 RS6
Bericht door david. » 05 dec 2012, 19:56
damm deze doet me meer dan de vorige...
chroom eraf,minder in oog springend kleur en kom maar door. aja...met een beetje chip zit dit ding op 700 pk..
prima gezins karretje. zal eens kijken waar ie over pak'm beet 4/5 jaar voor gaat ;-)
Rebel
Re: 2013 RS6
Bericht door Rebel » 05 dec 2012, 21:30
Sorry Robin, ik zal mijn commentaar even toelichten.
Je hebt mensen die zitten dagelijks meerdere uren in hun auto en je hebt mensen die zitten dagelijks achter een bureau/werkbank.
Als je dagelijks meerdere uren in een auto zit, verkies je een standaard ("knudde") 5-serie/A6 ten alle tijden boven een kleine 1-serie. Zelfs al ligt hier een 5 liter blok in met 600 pk.
Niet iedereen heeft behoefte om in zo'n kleine auto ieder weekend de hooligan uit te hangen op een klaverblad cq industrieterrein.
En aangezien jij ook geen regelmatige bezoeker bent van de Zandvoort/Ring/Spa-dagen, wilde ik de "knudde" term enigzins nuanceren. Niks meer niks minder ;-)
Re: 2013 RS6
Bericht door Robin » 05 dec 2012, 21:39
In 'n file staan met 'n 600pk RS3 DCT of 'n 520d/A6 Automaat. Dan liever de RS3 als de weg weer vrij is. DOH.
Ik ken tig vertegenwoordigers met 60/80k per jaar in Polos/Golfs/Volvootjes/Passats. Allemaal rijervaring ten top ofzo(60k km per jaar) totdat ze op 'n slipcursus de pylonen het IJsselmeer in schieten. want tjemig dat viel nog niet mee. :D
Re: 2013 RS6
Bericht door Luco » 05 dec 2012, 21:50
Onderstuurd de pion in :lol:
Rebel
Re: 2013 RS6
Bericht door Rebel » 05 dec 2012, 22:14
Nu verwissel je rijervaring/bedrevenheid met rijplezier. Je hoeft geen coureur te zijn om het verschil te voelen tussen een stugge 1-serie en een comfy 5 -serie. Ongeacht of die 1-serie een pimp/power pakket heeft.
Sja en die pylonnen.....die moet je toch juist omver kegelen??
Re: 2013 RS6
Bericht door tomgtr » 06 dec 2012, 11:13
Schitterende auto zeg. Me want!!!!!!
Re: 2013 RS6
Bericht door Richardt. » 06 dec 2012, 11:17
Prachtige auto en net als de vorige in Avant vorm op z'n mooist.
Klein minpuntje is in mijn ogen toch dat de V10 verdwenen is, dat had toch wat extra's :)
Petrolhead Tom
Re: 2013 RS6
Bericht door Petrolhead Tom » 06 dec 2012, 11:18
Indrukwekkend is hij zeker. Prima rechtuitbrander.
Re: 2013 RS6
Bericht door Luco » 06 dec 2012, 11:20
Petrolhead Tom schreef:Indrukwekkend is hij zeker. Prima rechtuitbrander.
Ik hoorde dat bmw tegenwoordig ook mooie rechtuitbranders maakt met slappe besturing :popcorn:
Dennis Cavallino
Re: 2013 RS6
Bericht door Dennis Cavallino » 06 dec 2012, 11:45
Ondanks dat ik echt geen moeite meer doe om de A4, A6 en A8 van elkaar te onderscheiden, ik vind dat verspilde energie, vind ik dit wel een beter smoelende variatie op de vorige RS6. Specs zijn dik in orde. Rijplezier is misschien niet spannend, maar net als in de A7 Quattro verwacht ik een RWD Bias van het Quattro systeem.
Dus storend is het allerminst, al moet je er niet een circuit mee op gaan als je op de limiet wil rijden, want net als in de RS5 is dat na een paar rondjes op 't saaie af. Het verschil tussen de RS5 en de RS6 zit hem in de praktische bruikbaarheid. De RS5 vind ik zelf een zinloze auto, want het is niet per sé leuker dan een S5 of volle A5 met Quattro, maar het is al helemaal geen sportwagen zoals ik het begrip sportwagen interpreteer. De RS6 snap ik als allround auto wel. Hij is niet bedoeld voor snelle rondetijden, maar in de Ardennen of Eifel is 't best leuk sturen met zo'n kar. Aan de andere kant weten we allemaal hoe Leonard op de sliphoek voorbij kon denderen met zijn RS Avant op Zandvoort.
Als ik in deze prijsklasse mocht shoppen voor een familiehok, dan stond deze RS6 op mijn shortlist.
Re: 2013 RS6
Bericht door GTRene » 06 dec 2012, 11:49
ik mis die V10 niet, V8 is genoeg, helemaal met 2 turbo's wat bij dat type auto wel past als nm kanon.
bovendien betekent dat 2 cilinders minder over de voor-as dus wellicht iets beter in de bochten?
Petrolhead Tom
Re: 2013 RS6
Bericht door Petrolhead Tom » 06 dec 2012, 11:51
Als je een snelle familie bak zoekt is dit prima denk ik. Hij zou niet op mijn short list komen omdat ik een E63 en een M5 gewoon veel gaver vind.
Ik denk dat hij minder slecht is in de bochten Rene. Een echte stuurmansauto zal het nooit worden maar dat maakt niet uit want daar zijn de kopers van dit soort auto's niet naar op zoek en zo is hij niet bedoelt.
Re: 2013 RS6
Bericht door Richardt. » 06 dec 2012, 12:06
Tja, zo'n auto koop je ook niet voor het circuit. Zoveel vermogen daar hoort een sportief rijgedrag bij en dat zit er wel in, af en toe wat bochtjes en afritjes pakken lukt prima met dat ding.
Verder is elke auto in dat segment gewoon niet geschikt voor het circuit.
Dat ding wordt niet voor niks ook als Avant geleverd (net als Mercedes en BMW dat ook doet/deed). Hup gezin er in, bagagen en/of hond in de kofferbak en volle polle over de Autobahn blazen. Daar zijn dit soort auto's voor.
Als je geld genoeg hebt, een gezin hebt en ruimte nodig bent zijn dit gewoon de gezinsauto's bij uitstek lijkt mij.
Petrolhead Tom
Re: 2013 RS6
Bericht door Petrolhead Tom » 06 dec 2012, 12:32
Precies en dan heeft de echte rijder er nog wel een 911 of R8 naast staan voor als hij echt bochtjes wil rijden.
Re: 2013 RS6
Bericht door Robin Hartog » 06 dec 2012, 19:57
Petrolhead Tom schreef:Precies en dan heeft de echte rijder er nog wel een 911 of R8 naast staan voor als hij echt bochtjes wil rijden.
Wat een bullshit. Waarom zou je twee van die auto's hebben? Met een M135i ben je gewoon klaar... :coffee:
Heb er (weer) niks mee, met deze RS6. Maar hij zal waarschijnlijk wel godsgloeiende snel zijn. :)
Gebruikers op dit forum: Geen geregistreerde gebruikers en 71 gasten
