Lotus Elan
Een eigen hoekje voor alle klassiekers!
Dennis Cavallino
Lotus Elan
Bericht door Dennis Cavallino » 26 sep 2012, 10:36
Octane heeft de good old Lotus Elan getest. Verschillende uitvoeringen hebben ze aan de tand gevoeld in Hethel, met hulp van Roger Becker. Prachtig!
http://www.classicandperformancecar.com ... ethel.html
Re: Lotus Elan
Bericht door GTRene » 26 sep 2012, 13:32
leuke auto's, dit viel me op>>
These were the cars when drivers were drivers. You can feel there’s a major lack of torsional stiffness here – the Elise is much stiffer.
‘The angle of roll used to break the doughnuts. We used to break them there… [slides through the hairpin again] …so we devised a series of tests. We could snap them just like that! We could foresee when they were about to fail because the rubber started to peel.’
Was it fixed in the end? ‘No. We tried stiffening the suspension, but even doubling the spring rate only reduced roll by a quarter. We put the chassis on a twist rig, and it got to the point where stiffer springs made no more difference. It made the chassis twist instead.’
Aha! So that’s the untold reason for the Elan’s legendary suppleness.
It was to stop the chassis twisting.
‘There’s none of the base stiffness of cars today, none of the ability to lean on the car in a corner. It’s always in the transient region where you feel the grip building up and its relationship to lateral acceleration. But we used to drift round the steering pad all the time, a nudge of oversteer to register where the grip is, then jerk the car and feed back the throttle.’
chassis van die dingen zijn dus niet erg stijf...en als je dan stuggere veren gebruikt gaat ie in het chassis meer buigen :shock: enz...conclusie van hen, de standaard soepele vering van destijds, was de juiste voor het chassis :ongeveer als:
zou het chassis van de Elans S +2 hetzelfde soort zijn qua stijfheid?
en dat andere chassis van de oude Europa...backbone oid? zou die wel "beter" zijn?
Re: Lotus Elan
Bericht door Rupie » 26 sep 2012, 14:34
De klassieker to have, althans, in mijn ogen :D
Re: Lotus Elan
Bericht door GTRene » 26 sep 2012, 14:45
als het een Elan zou zijn/worden, dan graag een coupe 26R
Petrolhead Tom
Re: Lotus Elan
Bericht door Petrolhead Tom » 26 sep 2012, 14:46
Echt een prachtig model!
HJ2
Re: Lotus Elan
Bericht door HJ2 » 27 sep 2012, 21:07
Vette ouwe meuk! :wave:
En heeeeel anders dan mijn Elan, wat juist een benchmark is qua stijfheid voor cabrio's!
Ze hadden wel wat bijgeleerd in de tussentijd ;-)
Doet u mij maar een Elan +2 trouwens. Net even iets mooiere, tijdloze lijnen.
Deze Elan is natuurlijk wel DE klassieker :df:
Re: Lotus Elan
Bericht door GTRene » 07 jan 2014, 15:04
dit dan...goed gebruik makende van de Honda S2000 motor in een lightweight body waar dan de niet zo'n dikke torque motor erg goed tot z'n recht komt :df:
Re: Lotus Elan
Bericht door GTRene » 05 feb 2014, 00:55
kwam net deze tegen :df: I like...zoiets lijkt me ook wel een keer leuk, lichtgewicht en klassiek en toch veel nieuw/modern zodat die aardig betrouwbaar is e.d.
just came across this Lotus Elan S4, I like it :D
it has a 2.0 tuned Ford engine and some stronger chassis etc, would be a lovely car, its light and pretty fast me thinks?
Lotus Elan S4 New Frame-off Restoration
[quote=] No more special ordering and waiting weeks for those engine parts. It has a SPYDER spaceframe chassis. The SPYDER chassis eliminates chassis flex that's common with the original sheet metal chassis. The rear suspension has many upgrades. It has been upgraded from the MacPherson strut to double A-Arms. The race inspired SPYDER made A-Arms have adjustable heim joints. The Quaife limited slip differential has been upgraded with Porsche CV Joints and Half Shafts. No more crazy half shaft rubber donuts as on the original cars. The front suspension has also been upgraded with similar race inspired SPYDER made A-Arms with adjustable heim joints. An upgraded sway bar was also added. There are adjustable SPAX shocks on all four corners. New adjustable coil over springs can also be used to set the ride height to your driving style. The massive wheels are high dollar 3-piece construction with polished aluminum outers and inners with Magnesium centers. [/quote]
http://car-from-uk.com/sale.php?id=37963" onclick="window.open(this.href);return false;
Gebruikers op dit forum: Geen geregistreerde gebruikers en 59 gasten
