Autoambulance/Trailer Ifor Williams CT177 Kipbaar
Ar
Auto: Prius
Bericht door Ar » 10 aug 2012, 04:56
Over 6 weken is deze kipbare autotrailer beschikbaar. Tegen die tijd zal ik foto's plaatsen.
Vaste prijs: 2700 ex BTW.
http://www.iwt.co.uk/products/car-transporter/ct177
A versatile transporter, wide enough for most light commercials and narrow enough for the smaller car, the CT177 is the ideal trailer for the motor trade or hire professional. Its tilt bed action combined with pull out mini-skids allows for quick and efficient loading of vehicles either under their own power or using one of the winch options available.
The combination of optimum engineering design and high strength materials has produced a trailer with an excellent strength to weight ratio. Wheel arch tops are only 10cm (4") from the bed to give ample door clearance and feature high grip treads for safe entry and exit from the vehicle being carried. The optional heavy duty wheel straps feature a soft-link that will not damage expensive alloy wheels and can be stowed away in the built-in toolbox.
Mini-skids, to give improved ground clearance, can be quickly and easily slid into position. Fully retained at all times they cannot be lost or stolen and once the vehicle is loaded they simply slide back in place within the rear deck.
The removable winch arm is fully adjustable from side to side allowing alignment with off-centre vehicle recovery eyes.
Model Tyres Internal Length Internal Width Overall Length
CT177 155/70R12C 5.00m 1.91m 6.70m
GrossWeight Unladen Weight
3500kg 805kg
Overall Width
2.30m
Ar
Auto: Prius
Re: Autoambulance/Trailer Ifor Williams CT177 Kipbaar
Bericht door Ar » 09 okt 2012, 22:43
Alle lampjes doen het. Een aantal reflectors heb ik vervangen. De gele striping reflecteert zoals je vaak op vrachtwagens ziet.
Je kunt met gemak met een S erop stabiel 100km/uur(of meer..) rijden met deze aanhanger.
Ar
Auto: Prius
Bericht door Ar » 09 okt 2012, 22:57
Google:
Ar
Auto: Prius
Bericht door Ar » 26 nov 2012, 20:31
Via het forum ook eens een keer wat verkocht. Ik was vergeten dat die hier te koop stond....
Het is een perfecte aanhanger en onderweg naar Turkije was die superstabiel op de slechte Bulgaarse wegen. Ik kon deze niet kwijt door de breedte afmetingen en ik ben daarom nu op zoek naar een Fitzel of Algema.
Kan op slot.
Gebruikers op dit forum: ron36 en 2 gasten
