STILLEN ADJUSTABLE UPPER CONTROL ARMS 300zx z32
Frank280zx
Locatie: Amsterdam of e36 GTR v8, 280ZXR v8, Range Rover tuinhuiseditie
Bericht door Frank280zx » 11 mei 2012, 16:27
SOLD
Te koop gloed nieuwe STILLEN ADJUSTABLE UPPER CONTROL ARMS voor de z32 300zx (front)
Dit geeft je de mogelijk camber te corrigeren
Stillen Part#: 308050
Stillen price: $408 (ext verzenden etc)
DF Prijs 180 (Marktplaats 180)
Beschrijving:
Necessary to adjust camber on car that have been lowered or are competition driven, the STILLEN built Adjustable Upper Arms allow you plus or minus 3 degrees of precise adjustment. The unique rack and pinion design allows for a quick change in setup. Adjusting your car's suspension with more negative camber will increase the vehicle's cornering ability as the rite is able to maintain a wider patch (contact are) through the turns. A four wheel alignment is recommended. Urethane bushings have been designed to retain lubricant for quiet operation and re-lubing is easy with the built in Zerk fittings.
Dingen zijn nieuw en niet veel verkrijgbaar, prijs is dus weinig flexibel
