router vraagje
router vraagje
Bericht door Fabian » 15 mar 2011, 21:02
Zie net in mn securityblog van mn router het volgende:
Moet ik me zorgen maken :?: Heb mn netwerk beveiligd en alleen bekende MAC-adressen hebben toegang.
Tue Mar 15 20:50:10 2011 : Blocked access attempt from 222.187.221.7
Tue Mar 15 20:48:09 2011 : Blocked access attempt from 74.138.247.153
Tue Mar 15 20:45:31 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 20:44:54 2011 : Blocked access attempt from 218.17.181.236
Tue Mar 15 20:36:41 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 20:30:23 2011 : Blocked access attempt from 221.1.220.163
Tue Mar 15 19:37:58 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 19:15:56 2011 : Blocked access attempt from 212.117.4.65
Tue Mar 15 19:14:23 2011 : Blocked access attempt from 58.218.199.147
Tue Mar 15 19:05:10 2011 : Blocked access attempt from 211.103.156.226
Tue Mar 15 18:55:50 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 18:55:49 2011 : Blocked access attempt from 212.117.4.65
Tue Mar 15 18:55:08 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 18:52:04 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 18:36:05 2011 : Blocked access attempt from 212.117.4.65
Tue Mar 15 18:30:04 2011 : Blocked access attempt from 67.149.132.217
Tue Mar 15 18:28:24 2011 : System time synchronized with 192.43.244.18
Tue Mar 15 18:18:05 2011 : Blocked access attempt from 82.239.140.191
Tue Mar 15 18:14:25 2011 : Blocked access attempt from 210.245.83.74
Tue Mar 15 18:13:11 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 18:12:25 2011 : Blocked access attempt from 80.254.108.124
Tue Mar 15 18:11:19 2011 : Blocked access attempt from 216.114.35.130
Tue Mar 15 18:06:57 2011 : Blocked access attempt from 212.117.4.65
Tue Mar 15 18:05:27 2011 : Blocked access attempt from 98.164.117.94
Tue Mar 15 18:03:08 2011 : Blocked access attempt from 208.109.162.142
Tue Mar 15 18:01:27 2011 : Blocked access attempt from 178.162.148.46
Tue Mar 15 17:58:40 2011 : Blocked access attempt from 58.218.204.110
Tue Mar 15 17:52:54 2011 : Blocked access attempt from 219.134.242.67
Tue Mar 15 17:36:20 2011 : Blocked access attempt from 85.25.4.11
Tue Mar 15 17:26:26 2011 : Blocked access attempt from 85.187.37.108
Tue Mar 15 17:26:22 2011 : Blocked access attempt from 221.1.220.163
Tue Mar 15 17:16:15 2011 : Blocked access attempt from 118.109.139.253
Tue Mar 15 17:12:14 2011 : Blocked access attempt from 109.77.213.58
Tue Mar 15 17:07:20 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 16:56:13 2011 : Blocked access attempt from 118.109.139.253
Tue Mar 15 16:52:59 2011 : Blocked access attempt from 188.163.250.106
Tue Mar 15 16:51:14 2011 : Blocked access attempt from 109.77.213.58
Tue Mar 15 16:47:50 2011 : Blocked access attempt from 74.138.247.153
Tue Mar 15 16:43:05 2011 : Blocked access attempt from 58.218.199.147
Tue Mar 15 16:36:40 2011 : Blocked access attempt from 118.109.139.253
Tue Mar 15 16:31:05 2011 : Blocked access attempt from 109.77.213.58
Tue Mar 15 16:16:01 2011 : Blocked access attempt from 118.109.139.253
Tue Mar 15 16:11:01 2011 : Blocked access attempt from 109.77.213.58
Tue Mar 15 15:55:58 2011 : Blocked access attempt from 118.109.139.253
Tue Mar 15 15:50:59 2011 : Blocked access attempt from 109.77.213.58
Tue Mar 15 15:49:16 2011 : Blocked access attempt from 203.186.211.55
Tue Mar 15 15:36:11 2011 : Blocked access attempt from 118.109.139.253
Tue Mar 15 15:29:48 2011 : Blocked access attempt from 209.190.36.50
Tue Mar 15 15:29:09 2011 : Blocked access attempt from 89.79.115.88
Tue Mar 15 15:23:01 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 15:16:56 2011 : Blocked access attempt from 121.166.92.16
Tue Mar 15 15:07:11 2011 : Blocked access attempt from 114.26.167.168
Tue Mar 15 15:01:02 2011 : Blocked access attempt from 222.46.20.215
Tue Mar 15 14:50:46 2011 : Blocked access attempt from 109.77.213.58
Tue Mar 15 14:27:41 2011 : Blocked access attempt from 114.26.167.168
Tue Mar 15 14:23:41 2011 : Blocked access attempt from 221.1.220.163
Tue Mar 15 14:13:35 2011 : Blocked access attempt from 58.218.199.147
Tue Mar 15 14:07:45 2011 : Blocked access attempt from 114.26.167.168
Tue Mar 15 13:50:23 2011 : Blocked access attempt from 58.218.204.110
Tue Mar 15 13:47:29 2011 : Blocked access attempt from 114.26.167.168
Tue Mar 15 13:40:22 2011 : Blocked access attempt from 74.117.63.178
Tue Mar 15 13:39:06 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 13:00:02 2011 : Blocked access attempt from 89.79.115.88
Tue Mar 15 12:47:45 2011 : Blocked access attempt from 74.138.247.153
Tue Mar 15 11:59:31 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 11:55:23 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 11:45:37 2011 : Blocked access attempt from 202.10.67.144
Tue Mar 15 11:43:08 2011 : Blocked access attempt from 58.218.199.147
Tue Mar 15 11:20:27 2011 : Blocked access attempt from 221.1.220.163
Tue Mar 15 11:17:00 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 11:12:48 2011 : Blocked access attempt from 193.95.221.209
Tue Mar 15 10:34:27 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 10:19:21 2011 : Blocked access attempt from 82.120.128.66
Tue Mar 15 10:15:41 2011 : Blocked access attempt from 221.181.28.61
Tue Mar 15 10:11:34 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 09:51:50 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 09:42:01 2011 : Blocked access attempt from 58.218.204.110
Tue Mar 15 09:13:56 2011 : Blocked access attempt from 58.218.199.147
Tue Mar 15 09:08:56 2011 : Blocked access attempt from 83.84.115.31
Tue Mar 15 08:47:51 2011 : Blocked access attempt from 74.138.247.153
Tue Mar 15 08:41:38 2011 : Blocked access attempt from 59.183.170.67
Tue Mar 15 08:27:37 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 08:16:18 2011 : Blocked access attempt from 221.1.220.163
Tue Mar 15 06:44:22 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 06:44:11 2011 : Blocked access attempt from 58.218.199.147
Tue Mar 15 06:21:43 2011 : Blocked access attempt from 123.120.26.15
Tue Mar 15 06:17:20 2011 : Blocked access attempt from 208.69.59.148
Tue Mar 15 05:33:53 2011 : Blocked access attempt from 58.218.204.110
Tue Mar 15 05:13:37 2011 : Blocked access attempt from 221.1.220.163
Tue Mar 15 05:01:01 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 04:48:01 2011 : Blocked access attempt from 74.138.247.153
Tue Mar 15 04:40:11 2011 : Blocked access attempt from 8.20.136.232
Tue Mar 15 04:36:49 2011 : Blocked access attempt from 114.31.4.83
Tue Mar 15 04:21:29 2011 : Blocked access attempt from 124.232.130.2
Tue Mar 15 04:15:11 2011 : Blocked access attempt from 58.218.199.147
Tue Mar 15 03:55:50 2011 : Blocked access attempt from 61.136.121.115
Tue Mar 15 03:19:28 2011 : Blocked access attempt from 114.51.141.21
Tue Mar 15 03:17:46 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 02:39:18 2011 : Blocked access attempt from 114.51.141.21
Tue Mar 15 02:21:56 2011 : Blocked access attempt from 95.225.103.218
Tue Mar 15 02:19:15 2011 : Blocked access attempt from 114.51.141.21
Tue Mar 15 02:09:59 2011 : Blocked access attempt from 221.1.220.163
Tue Mar 15 01:59:29 2011 : Blocked access attempt from 114.51.141.21
Tue Mar 15 01:49:52 2011 : Blocked access attempt from 189.126.109.137
Tue Mar 15 01:45:45 2011 : Blocked access attempt from 58.218.199.147
Tue Mar 15 01:34:28 2011 : Blocked access attempt from 221.192.199.49
Tue Mar 15 01:26:33 2011 : Blocked access attempt from 58.218.204.110
Tue Mar 15 01:08:09 2011 : Blocked access attempt from 184.82.147.35
Tue Mar 15 00:47:57 2011 : Blocked access attempt from 74.138.247.153
Tue Mar 15 00:18:03 2011 : Blocked access attempt from 58.246.229.194
Mon Mar 14 23:54:28 2011 : Blocked access attempt from 88.171.32.16
Mon Mar 14 23:49:54 2011 : Blocked access attempt from 221.192.199.49
Mon Mar 14 23:41:03 2011 : Blocked access attempt from 98.214.45.198
Mon Mar 14 23:34:25 2011 : Blocked access attempt from 88.171.32.16
Mon Mar 14 23:33:09 2011 : Blocked access attempt from 195.251.70.13
Mon Mar 14 23:31:20 2011 : Blocked access attempt from 95.19.93.112
Mon Mar 14 23:17:11 2011 : Blocked access attempt from 76.75.117.133
Mon Mar 14 23:16:21 2011 : Blocked access attempt from 58.218.199.147
Mon Mar 14 23:14:37 2011 : Blocked access attempt from 88.171.32.16
Mon Mar 14 23:11:55 2011 : Blocked access attempt from 95.19.93.112
Mon Mar 14 23:07:55 2011 : Blocked access attempt from 76.75.117.133
Mon Mar 14 23:07:34 2011 : Blocked access attempt from 221.1.220.163
Mon Mar 14 23:06:42 2011 : Blocked access attempt from 83.34.166.205
Mon Mar 14 22:54:14 2011 : Blocked access attempt from 88.171.32.16
Mon Mar 14 22:51:10 2011 : Blocked access attempt from 95.19.93.112
Mon Mar 14 22:49:30 2011 : Blocked access attempt from 76.75.117.133
Re: router vraagje
Bericht door Wouter81 » 15 mar 2011, 21:14
Niks om je zorgen over te maken. Gebeurt continue op internet, dat men digitaal even aan de deur klopt. Ze scannen gewoon een hele reeks IP (internet) adressen (waaronder dat van jou in dit geval) in de hoop dat er ergens iets openstaat waardoor ze naar binnen kunnen. Veel routers registreren dit soort 'aanvallen' en dan krijg je dit soort logs.
Joost H.
Re: router vraagje
Bericht door Joost H. » 15 mar 2011, 21:19
Geen probleem wat Wouter zegt.
Re: router vraagje
Bericht door Fabian » 15 mar 2011, 21:21
Okidoki, thnx, had al een beetje zo'n idee maar ben er niet helemaal in thuis :)
Emiel
Re: router vraagje
Bericht door Emiel » 15 mar 2011, 21:23
Wat je wel in de gaten moet houden is of je router het niet te moeilijk krijgt met het continue blocken/denial etc. Daar kunnen huis/tuin/keuken routers van over de emmer gaan.
FrankS
Re: router vraagje
Bericht door FrankS » 15 mar 2011, 21:33
Joa, maar in dit tempo valt het wel mee :)
Emiel
Re: router vraagje
Bericht door Emiel » 15 mar 2011, 21:38
Bij mij was het om de 3 seconden, continue, met af en toe een half uur pauze..... dat trok de goedkope router niet. Gelukkig ging die stuk :bag:
Re: router vraagje
Bericht door Tom » 15 mar 2011, 23:16
En zorgen voor de nieuwste firmware op je router :)
Gebruikers op dit forum: Baidu [Spider], Berry1000RR, Bing [Bot], CRZ, RS-Ron, vester86, WJ en 3 gasten
