E61 G-POWER M5 HURRICANE RS Touring
Bericht door GTRene » 19 feb 2011, 11:26
Now, a limited run of only 1,025 BMW M5 Touring models are being equipped with the stunning 750 hp/551 kW V10 twin-supercharged power plant from the G-POWER M5 HURRICANE RS. As a consequence, the G-POWER M5 HURRICANE RS Touring now takes its place in the record books as the world’s fastest estate car. With a top speed of 360 km/h (limited), it beats the existing record of 344.2 km/h (MTM RS6 R) from 2009 by 15.8 km/h, and the record of 320 km/h (Brabus T V12) from 1997 by a whopping 40 km/h. Use the following link to see video footage of the G-POWER M5 HURRICANE RS Touring reaching its electronically limited top speed of 360 km/h
On the inside, the ten-cylinder four-valve engine is optimized by lightweight, precisely balanced Mahle high-performance forged pistons with lower compression and increased stiffness. And because the standard con-rods and piston pins are not capable of withstanding the significantly increased forces, they, too, have been replaced by specialist parts. Optimized mapping for the engine electronics also contributes to the peak power output of 750 hp/551 kW between 7,500 and 8,000 r/min. The maximum torque of 750 Nm is reached at 5,000 revs.
It goes without saying that the stunning performance of the G-POWER HURRICANE RS Touring is not limited to top speed alone. The approximately 2-tonne estate sets equally impressive standards with a 0-100 km/h time of less than 4.5 seconds, as well as 9.7 seconds to 200 km/h and 26 seconds to the 300 km/h mark.
meer interieur en buiten foto's via de link....wat een luxe kanon.
http://www.g-power.de/315.html?&L=1" onclick="window.open(this.href);return false;
Re: E61 G-POWER M5 HURRICANE RS Touring
Bericht door Xave30 » 19 feb 2011, 12:26
Bij het zien van de eerste foto dacht ik "ah, verfrissend; gelukkig niet over-the-top"...........
Velen zijn van mening dat hout niet in een 'sportieve' auto thuishoort maar rvs/alu past, imho, totaal niet bij deze kleur bekleding.
JWD
Bericht door JWD » 19 feb 2011, 12:32
Xave30 schreef:Bij het zien van de eerste foto dacht ik "ah, verfrissend; gelukkig niet over-the-top"...........
Dat was ook mijn idee, hebben ze elk hoekje en gaatje aangepast van de auto laten ze het IMHO goedkope alu gewoon zitten, had dan bruin carbon of iets dergelijks gebruikt.
Het idee was leuk maar een beetje te ver doorgeslagen als je het mij vraagt.
Bericht door Bram » 19 feb 2011, 12:40
Mmmh, los daarvan, ze tikken die 360 km p/u aan op een 2 baans autoweg 's avonds in het donker. Passeren met 340 km p/u ff een vrachtwaggel
Vind dit nou niet echt heel erg slim :hmmm:
Bericht door GTRene » 19 feb 2011, 12:51
ik vind hem van buiten super stoer (voor het soort)
maar van binnen over the top, natuurlijk mooi vakwerk en blabla maar te veel van het goede, afijn het zal ook een show model van kunnen zijn, je eigen auto kan je natuurlijk zo bestellen bij hen zo jij dat wenst.
rekening man :shocking:
de kleur van buiten samen met die G-power wielen design ook gaaf, stoere touring.
gaat wel ereug hard, en dan nog iets gelimiteerd ook. (almost to fast)
Marc R
Bericht door Marc R » 19 feb 2011, 12:56
Dikke kneiter hoor,alleen die kleuren van de binnenkant.... :banaan:
david.
Bericht door david. » 19 feb 2011, 13:14
mooi van buiten, al hou ik niet van die getinte ramen
oer oer lelijk van binnen, absolute wansmaak!
specs, snelheid meer dan bizar.. een hond achterin de bak houd daar zeker niet van ;-)
Brava
Bericht door Brava » 19 feb 2011, 19:56
Interieur is net een boudoir.
Is een aantal van 1025 niet heel erg veel? Dat is een significant percentage van de totale productie volgens mij, die bovendien allang gestopt is.
Bericht door GTRene » 19 feb 2011, 20:03
Brava schreef:Interieur is net een boudoir.
nee, ze maken er niet zoveel, zoveel M5 in dat model zijn er gemaakt?
daarvan maken ze een paar G-power monsters (van die 1025 originele M5 toering dan)
staat er wel wat raar :wink:
Bericht door romo » 19 feb 2011, 20:10
Interieur is idd het betere bordelen werk…………….misschien een bak voor Theo Heuft?……….. :lol:
Of is het broddelwerk……………. :hmmm: ?
Brava
Bericht door Brava » 19 feb 2011, 20:22
Dat is niet wat er staat. Er staat dat er 1025 met deze motor uitgerust gaan worden.
Bericht door GTRene » 19 feb 2011, 20:47
ligt er aan hoe je het leest :wink:
Now, a limited run.........................
of only 1,025 BMW M5 Touring models,
snappy? :wink:
Bericht door Joop » 19 feb 2011, 22:29
Als je het letterlijk leest dan staat er dat er 1025 M5 touring's worden voorzien van dat 750PK sterke blokje...
...alleen zal dat een schrijffout van de heren van G-Power zijn; dat zullen er dan wellicht maximaal 1025 kunnen zijn...
Maar goed; leuke exercitie, maar dit kenden we al van de sedan versie... Interieur is natuurlijk heerlijk voor een showcar, maar wel zwaar over de top. Getuigd overigens wel van vakmanschap (even los van de gekozen kleuren).
Bericht door GTRene » 19 feb 2011, 22:38
als je even adem haalt daar waar ik de stippen zette en logisch nadenkt over de aantallen en dan weer eens lezen begrijp je het vast :mrgreen:
hier hun Duitste van hetzelfde stukje, het Engels hadden ze wat duidelijker kunnen neerzetten, maar met wat logish nadenken kom je er wel :mrgreen:
Jetzt wurde auch der nur 1.025-mal gebaute BMW M5 Touring mit dem aus dem G-POWER M5 HURRICANE RS bekannten 750 PS/551 kW starken V10 Bi-Kompressortriebwerk ausgerüstet
Bericht door Joop » 19 feb 2011, 22:41
...a ha; im Deutsch stimmt es... :thumbup:
Brava
Bericht door Brava » 19 feb 2011, 23:02
GTRene schreef:ligt er aan hoe je het leest :wink:
snappy? :wink:
Ikke snappe, Engels mijn beroep zijn. "Are being equipped" betekent dat ze bezig zijn deze 1025 auto's uit te rusten met deze motor. DAT is wat er staat en niets anders.
Gebruikers op dit forum: BartMS, ED35, Eric Z, Google [Bot], MarcF en 25 gasten
