SPORTEC SPR1 T80 : 858pk 0-200 8,6 s
Bericht door RVV » 04 jul 2009, 00:31
SPR1 T80: 858bhp, power to all four wheels and 236mph plus top speed
Swiss automotive tuner SPORTEC, famed for its ultra high performance SPR1 range of 997 based supercars, is proud to announce the latest addition to its range, the T80. Conceived, designed and constructed in Switzerland by SPORTEC's technical team, the new version of the SPR1 offers unrivalled supercar performance and exclusivity.
The T80 builds upon the performance of the SPR1 range by increasing the power of its bi-turbo, 3.6-litre, 24-valve, flat six T80M engine to a staggering 858 bhp, which, when combined with the benefits of permanent four wheel drive, creates a benchmark blend of poise and performance.
This means that each of the SPR1 T80's four wheels channels 214.5 bhp to the tarmac, akin to having a VW Golf GTi powering each tyre, yet the SPR1's bi-turbo engine remains fully Euro IV emissions compliant.
The SPORTEC SPR1 T80 enjoys supercar performance, taking a mere 3.0 seconds to hit 62mph (100kmh,) with 186mph (300kmh) appearing in just 18.9 seconds. A top speed of more than 236mph has been recorded at Nardo, Italy.
Technically, the SPORTEC SPR1 T80 boasts highlights including titanium connecting rods, a flat carbon fibre under floor, active suspension and F1 style ceramic brake discs.
The use of composite (carbon / Kevlar) body panels, forged alloy wheels, an integrated safety cage and ceramic brake discs allows the SPR1 to be lighter, safer and more dynamic than other cars in its class.
Available in a choice of colours, the SPR1 T80 boasts a number of exclusive SPORTEC styling and interior touches, including lightweight 20 inch forged alloy wheels, a carbon fibre rear wing and leather / alcantara interior.
Brackley based Automotive Performance Services (APS) is the UK concession for SPORTEC. The SPR1 T80 will be making its British debut at the prestigious Salon Privé show at London's Hurlingham club between 22nd-24th July.
A full PDF version of the SPR1 T80 brochure, including images, is available at the following link:-
http://www.sportec.ch/files/documents/a ... 06d6c4.pdf" onclick="window.open(this.href);return false;
SPORTEC SPR1 T80 TECHNICAL OVERVIEW
1.0 Engine SPR1 T80
Engine type: 3.6-litre 6-cylinder boxer (858 bhp)
Engine code: T80.1
1.1 Technology
Forged light alloy block and cylinder heads, forged steel crankshaft, four valve cylinder heads with hydraulic tappets, nimonic exhaust valves, variable valve timing, F1 style titanium connecting rods, forged alloy pistons, dry sump lubrication system, six coil high tension system, selective cylinder knock control, OBD2 control for engine management monitoring
Special features
Hand crafted exhaust system with dual metal 200 CPSI catalyst and bypass valve, Euro IV emissions approved, MFC G4.0 multifunction control unit with: twin injector control, MAP sensor, multi map closed loop boost control, exhaust bypass control, load dependent dump valve control, twin throttle control, power dependent fuel pump control
Equal flow intake manifold, twin throttle body, SPORTEC hybrid turbochargers, high efficiency intercooler system with carbon fibre air ducts, carbon fibre flow optimised air intake system
Options
Traction/launch control, motorsport exhaust system (not road legal)
1.2 Drive train
Technology
Six speed, manual transmission, permanent four wheel drive, 60% limited slip differential, gearbox oil cooler
Special features
Driveability optimised SPORTEC high performance clutch rated to 1200NM of torque
Options
Customised gear ratios, motorsport limited slip differential
1.3 Suspension
Technology
Weight optimised seven spoke forged alloy SPR1 design, available polished or painted as per customer's choice, front axle: 9J x 20 inch (11.9 kilos) with 255/30R20 tyres, rear axle: 12.5 x 20 inch (12.5 kilos) with 345/25/ZR20 tyres, electric power steering, front axle with McPherson struts, uniball top mounts, light alloy links, multilink rear suspension with uniball top mounts, front and rear anti roll bars (rear adjustable,) adjustable ride height, active suspension
Special features
Electronic adjustable shock absorbers
1.4 Brake system
Technology
Front: Six piston fixed calliper, 380 x 34mm cross drilled and ventilated ceramic discs
Rear: Four piston fixed calliper, 322 x 28mm, cross drilled and ventilated ceramic discs
ABS
1.5 Body
Technology
Zinc coated galvanised steel bodyshell with integrated safety cell, carbon / Kevlar composite body panels, flat underfloor, adjustable rear spoiler
Special features
Increased torsional stiffness and weight reduction via bonded carbon / Kevlar composite body panels and safety cell, nano painting of customer's choice of colour, air flow optimised engine and intercooler ducting
Options
Door bars and removable rear cross brace in safety roll cage, sunroof
1.6 Electric system
Standard
Power windows, remote central locking, heated rear window, bi-xenon headlights, fog lights
Option
GPS car locator
1.7 Interior
Sport seats, complete leather/alcantara interior, stainless steel scuff plates, automatic air conditioning
Special features
Customer's choice of leather / alcantara colours
Options
Multifunction steering wheel, navigation system, car hi fi system, air conditioning, fully customised interior (leather / wood / carbon seats and trim,) sill scuff plates with customer's choice of logo
1.8 Package options and individual equipment
Clubsport package
Carbon fibre doors and bonnet, light weight interior with carbon door covers, adjustable carbon fibre rear wing, adjustable front lip spoiler, traction / launch control, active suspension, multifunction steering wheel, carbon fibre flat underfloor, six point safety belts, door bars and removable rear cross brace in safety roll cage, sports brake pads, optimised brake cooling, modified spring and damper settings, uprated rear axle links
Highspeed package
Active suspension, carbon fibre flat underfloor, flow optimised wheelarch liners, load controlled intercooler water spray, electric adjustable rear spoiler and special aerofoil, flow optimised wing mirrors, modified spring and damper settings
Further options
Motorsport exhaust system (track use only,) GPS car locator, satellite navigation system, car hi-fi, air conditioning, fully customised interior (leather / wood / carbon seats and trim,) sunroof, personalised scuff plates, global maintenance package, mobility warranty
2.0 SPORTEC SPR1 T80 Technical Data
Engine type: Six cylinder boxer engine
Displacement: 3600cc
Bore/stroke: 100 x 76.4mm
Compression ratio: 9.0:1
Power output: 858bhp @ 8200rpm
Torque output: 642lb.ft @ 4800rpm
Engine management: Bosch ME 7.8 SPORTEC MFC G4.0
Fuel quality: 98 RON unleaded
Idle speed: 820rpm
Max engine speed:
1st gear: 8700rpm
2nd-5th gear: 8500rpm
6th gear: 8200rpm
Emissions standard: Euro IV
Transmission
Six-speed manual, four wheel drive
Gear ratios:
1st: 3.82
2nd: 2.05
3rd: 1.41
4th: 1.12
5th: 0.92
6th: 0.75
Reverse gear: 2.86
Final drive ratio: 3.44
Speed at 1000rpm in 6th gear: 30.76mph
Clutch disc diameter: 240mm
Chassis
Front axle Light alloy links with McPherson struts, uniball top mounts
Rear axle Multi link suspension, uniball top mounts
Steering: Electric power steering
Steering ratio: 1:16.9
Steering from lock to lock:2.98
Brakes
Front: 8 piston light alloy calliper
Rear: 4 piston light alloy calliper
Brake discs
Front: Cross drilled and ventilated ceramic 380 x 34mm discs
Rear: Cross drilled and ventilated ceramic 322 x 28mm discs
Wheels
Front: 9J x 20 inch 30mm offset
Rear: 12.5J x 20 inch 40mm offset
Tyres
Front: 255/30 R20 92Y XL
Rear: 345/25 R20 100Y
Weights
Kerb weight (DIN)*: 1345 KG
Front / rear weight distribution:40/60
*Depending on equipment
Dimensions
Length: 4467mm
Width: 1878mm
Height: 1275mm
Wheelbase: 2350mm
Track
front:1550mm
rear: 1564mm
Fuel capacity: 64 litres
Performance
Maximum speed: Over 236mph (380kmh)
Acceleration:
0-100kmh (62 mph): 3.0 seconds
0-200kmh (124mph): 8.6 seconds
0-300kmh (186mph) : 18.9 seconds
Power to weight ratio: 637 bhp per ton
Bhp per litre: 238
Re: SPORTEC SPR1 T80 : 858pk 0-200 8,6 s
Bericht door Niels » 04 jul 2009, 01:02
Bizar :shock:
Bericht door GTRene » 04 jul 2009, 01:07
geweldig deze, zag hem ook op PH super mooi geslaagd :thumbup: en wat snel :love:
uitnodigend...
Laatst gewijzigd door GTRene op 04 jul 2009, 01:09, 1 keer totaal gewijzigd.
Bericht door RVV » 04 jul 2009, 01:07
van 0-200 net zo snel als:
http://www.einszweidrei.de/porsche/gt1lemans1996-1.htm" onclick="window.open(this.href);return false;
:shock:
Bericht door GTRene » 04 jul 2009, 01:11
gewoon een raket zo snel naar de 200 :thumbup:
Hugo Bos
Bericht door Hugo Bos » 04 jul 2009, 01:17
En met een normale handbak :shocking:
Bericht door RVV » 04 jul 2009, 01:21
0-300.. bijna zo snel als een Veryon.. die doet het in 18,2 s slechts 0,7 s langzamer.. phff
Bericht door GTRene » 04 jul 2009, 01:30
Rico schreef:0-300.. bijna zo snel als een Veryon.. die doet het in 18,2 s slechts 0,7 s langzamer.. phff
mooie adrenaliene vervanger ipv de M5 :mrgreen: biets ik alvast een ritje :wink:
Bericht door Xave30 » 04 jul 2009, 08:20
Wat en auto!
In de styling vind ik lekker nuchter zo. Ziet als geen supercar uit. :wink:
Mark krijgt een OMG moment als hij deze ziet :mrgreen:
markk
Bericht door markk » 04 jul 2009, 09:15
Hohoho Rico, geen stappen overslaan in de hierarchie. Plekje voor plekje omhhog. Dus:
- non beamer
- bmw
- bmw ///m
- porsche
- tuned porsche (techart, gemballa, sportec, etc.)
- lambo
- ferrari
- tuned ferrari (novitec, scuderia, etc.)
- exotics (zonda, mc laren, etc.)
:df:
Mark
Erik K.
Bericht door Erik K. » 04 jul 2009, 09:42
Lekker rap ding :shock:
Bericht door Joy » 04 jul 2009, 09:57
Markk, je vergeet wat:
- non beamer
- bmw
- bmw ///m
- porsche
- lambo
- ferrari
- E36 M3 Erik Kramer
FrankvW
Bericht door FrankvW » 04 jul 2009, 10:22
Doe mij die mah :shock:
Wat een prachtbak :love: :thumbup:
Mark Nauta
Bericht door Mark Nauta » 04 jul 2009, 10:53
Wat een beest zeg!!! Dat zijn toch geen normale waarden meer. Of ik hem echt mooi vind weet ik nog niet. Indrukwekkend is hij zeker!
Bericht door RVV » 04 jul 2009, 11:20
Joy Jolliffe schreef:Markk, je vergeet wat: :mrgreen:
- non beamer
- bmw
- bmw ///m
- porsche
- lambo
- ferrari
- BMW 130i :whistle:
Bericht door Joy » 04 jul 2009, 11:21
:hosanna:
Bericht door ErikS » 04 jul 2009, 11:25
- non beamer
- bmw
- BMW 130i
- bmw ///m
- BMW 130i
- porsche
- BMW 130i
- tuned porsche (techart, gemballa, sportec, etc.)\
- BMW 130i
- lambo
- BMW 130i
- ferrari
- BMW 130i
- BMW 130i
- BMW 130i
- BMW 130i
Dit is pas een rico lijstje, omdat die toch zoooo goed is... 8)
Erik K.
Bericht door Erik K. » 04 jul 2009, 14:01
Bericht door RVV » 04 jul 2009, 14:02
Hahaha, ja straks n de M5 weer een 130i.. dan een Porsche 911 turbo ofzo.. :mrgreen:
Luuk
Bericht door Luuk » 04 jul 2009, 14:42
Wat een ZIEK apparaat zeg, laat je met de sprint een hoop supercars achter je! :turtle:
Dat interieur is ook gewoon porn kwadraat.
Bericht door GTRene » 04 jul 2009, 15:32
super interieur, dat alcantara op het dash :love: die stoelen en die... :lol: gewoon een ziek ding :hosanna:
daar hoort zeker een navigatie met alle flitspalen en lussen e.d. in en een radarverklikker en laserbeam verstoorder :mrgreen: ow, en draaibare nummerplaten :thumbup: of legaal een kantelkenteken :beer:
http://www.dvhn.nl/nieuws/noorden/artic ... nts=3stars" onclick="window.open(this.href);return false;
Steven N.
Bericht door Steven N. » 04 jul 2009, 17:25
Bizar apparaat zeg!
Dat dashboard :shocking: :love:
Bericht door Macboy » 05 jul 2009, 23:39
Porno. Jammer alleen van het stuur, had uiteraard helemaal alcantara moeten zijn, juist op de gripplekken.
Gebruikers op dit forum: Fabian, Mark 320iS, Rivanov, vigilante, Wout309t en 4 gasten
