E36 strippen, wat doet wat?
Paul
Bericht door Paul » 14 jun 2009, 12:54
Hier een lijstje, misschien makkelijk voor de mensen die hun E36je willen gaan strippen..
Ik denk dat ik er vant winter ook maar aan moet geloven ;)
Wat weegt wat?
Rear Grab Handle = 0.1kg
Rear interior light = 0.1kg
Rear headrest = 1.5kg
Rear speakers from parcel shelf = 2.25kg
Glovebox inc. vents and torch = 2.2kg
Front foglights and mountings = 1.1kg
Boot side trim panels (carpet) = 2.5kg
Warning Triangle = 1.25kg
Boot lid gas shock = 0.5kg
Front wheelarch liners and fasteners = 2kg
Front brake cooling ducts = 0.3kg
Left side plastic boot floor trim panel = 0.9kg
Rear centre armrest = 1.4kg
Mobile phone aerial = 0.05kg
Glovebox under-trim = 0.5kg
Misc. trim around glovebox = 0.5kg
Tool kit from bootlid = 1.2kg
Rear door trim panel = 4.7kg
Boot interior light covers = 0.6kg
Passenger footwell speaker and lining = 0.5kg
Passenger sunvisor = 0.4kg
Front A-pillar trim panel = 0.5kg
Rear a-pillar trim panel = 1.1kg
Rear speaker cover = 0.2kg
Misc. Rear parcel shelf fittings = 0.5kg
Rear parcel shelf and padding = 3.1kg
Headlining = 1.4kg
Carpet under rear seats = 2kg
Insulation over wheelarch in boot = 2.1kg
Boot interior plastic wiring cover = 1kg
Rear seat insulation material = 2.4kg
Rear seat plastic edging trim = 0.4kg
Insulation from rear seat back = 4.2kg
Rear strut top covers (rubber) = 0.1kg
Plastic battery cable cover = 0.1kg
Sunroof seal = 0.5kg
Foam surround from rear seatbelts = 0.1kg
Foam gearlever surround = 0.1kg
Centre console rear section = 0.8kg
Heating vents from underneath floor carpet = 1.1kg
Seatbelt pillar plastic trim = 1.6kg
Ashtrays = 0.3kg
Drivers side front footwell trim = 0.35kg
Carpet = 8.4kg
Front plastic kickplates = 0.4kg
Driver's side front speaker = 0.5kg
Rear seatbelts = 2.2kg
Radio = 1.8kg
Plastic door trim centre (front) = 0.8kg
Rear interior door handles = 0.25kg
Front door speakers = 0.35kg
Cigarette lighter, misc fastenings and handbrake bracket = 0.2kg
Front passenger inertia reel and seatbelt = 1.1kg
Front passenger seatbelt fittings and adjuster = 0.5kg
Front kickplates = 0.3kg
handbrake gaiter = 0.1kg
tyre wrench = 0.4kg
Plastic battery cover from boot = 0.75kg
Boot solenoids for lock and petrol cap = 0.25kg
Jack = 2.1kg
Plastic boot trim over battery = 0.4kg
Spare wheel retainer = 0.1kg
Boot carpet = 3.9kg
Spare wheel and tyre = 18kg
Front seats (leather) = 48kg
Number plates = 0.5kg
Steering wheel boss = 0.45kg
Main fascia heater vent = 0.3kg
Black plastic trim from front bumper = 0.5kg
Radio fascia trim = 0.95kg
Driver's footwell trim = 1.3kg
Computer information module = 0.4kg
Cigarette lighter surround trim = 0.25kg
Gear gaiter and trim = 0.25kg
Under-bonnet heat shielding and fasteners = 1kg
Front electric window and hazard light switches = 0.1kg
Plastic wiring protectors = 1kg
Radio wiring loom, fasteners, heat shrink and connectors = 1.6kg
Steering column plastic surround = 0.2kg
Electric mirrors = 2kg
Horn = 0.35kg
Headlight washer pump = 0.3kg
Headlight washer system and wiring = 1.1kg
Drivers side seatbelt and fittings = 1.5kg
Front kidney grilles and surrounds = 0.55kg
Rear kick plates = 0.48kg
Rear door and boot weatherseals = 2.8kg
Rear door front seal and inside window trim plate = 0.45kg
Weight Reduction TOTAL = 157.63kg
Original Weight = 1350kg
Current Weight = 1192.37kg
alexm3gt
Re: E36 strippen, wat doet wat?
Bericht door alexm3gt » 14 jun 2009, 14:08
de stoelen tikken lekker aan met 48 kilo mis alleen de achterbank nog in het rijtje
@iko
Bericht door @iko » 14 jun 2009, 14:43
alexm3gt schreef:de stoelen tikken lekker aan met 48 kilo mis alleen de achterbank nog in het rijtje
je zal toch ergens op moeten zitten zonder voorstoelen :wink:
Bericht door Macboy » 14 jun 2009, 22:32
Vriendelijk verzoek om het even in volgorde van gewicht te plaatsen.
Thanks.
@iko
Bericht door @iko » 14 jun 2009, 22:36
Macboy schreef:Vriendelijk verzoek om het even in volgorde van gewicht te plaatsen.
Thanks.
had ik toevallig al even gedaan. Bij deze:
Mobile phone aerial 0,05 kg
Rear Grab Handle 0,1 kg
Rear interior light 0,1 kg
Rear strut top covers (rubber) 0,1 kg
Plastic battery cable cover 0,1 kg
Foam surround from rear seatbelts 0,1 kg
Foam gearlever surround 0,1 kg
handbrake gaiter 0,1 kg
Spare wheel retainer 0,1 kg
Front electric window and hazard light switches 0,1 kg
Rear speaker cover 0,2 kg
Cigarette lighter, misc fastenings and handbrake bracket 0,2 kg
Steering column plastic surround 0,2 kg
Rear interior door handles 0,25 kg
Boot solenoids for lock and petrol cap 0,25 kg
Cigarette lighter surround trim 0,25 kg
Gear gaiter and trim 0,25 kg
Front brake cooling ducts 0,3 kg
Ashtrays 0,3 kg
Front kickplates 0,3 kg
Main fascia heater vent 0,3 kg
Headlight washer pump 0,3 kg
Drivers side front footwell trim 0,35 kg
Front door speakers 0,35 kg
Horn 0,35 kg
Passenger sunvisor 0,4 kg
Rear seat plastic edging trim 0,4 kg
Front plastic kickplates 0,4 kg
tyre wrench 0,4 kg
Plastic boot trim over battery 0,4 kg
Computer information module 0,4 kg
Steering wheel boss 0,45 kg
Rear door front seal and inside window trim plate 0,45 kg
Rear kick plates 0,48 kg
Boot lid gas shock 0,5 kg
Glovebox under-trim 0,5 kg
Misc, trim around glovebox 0,5 kg
Passenger footwell speaker and lining 0,5 kg
Front A-pillar trim panel 0,5 kg
Misc, Rear parcel shelf fittings 0,5 kg
Sunroof seal 0,5 kg
Driver's side front speaker 0,5 kg
Front passenger seatbelt fittings and adjuster 0,5 kg
Number plates 0,5 kg
Black plastic trim from front bumper 0,5 kg
Front kidney grilles and surrounds 0,55 kg
Boot interior light covers 0,6 kg
Plastic battery cover from boot 0,75 kg
Centre console rear section 0,8 kg
Plastic door trim centre (front) 0,8 kg
Left side plastic boot floor trim panel 0,9 kg
Radio fascia trim 0,95 kg
Boot interior plastic wiring cover 1 kg
Under-bonnet heat shielding and fasteners 1 kg
Plastic wiring protectors 1 kg
Front foglights and mountings 1,1 kg
Rear a-pillar trim panel 1,1 kg
Heating vents from underneath floor carpet 1,1 kg
Front passenger inertia reel and seatbelt 1,1 kg
Headlight washer system and wiring 1,1 kg
Tool kit from bootlid 1,2 kg
Warning Triangle 1,25 kg
Driver's footwell trim 1,3 kg
Rear centre armrest 1,4 kg
Headlining 1,4 kg
Rear headrest 1,5 kg
Drivers side seatbelt and fittings 1,5 kg
Seatbelt pillar plastic trim 1,6 kg
Radio wiring loom, fasteners, heat shrink and connectors 1,6 kg
Radio 1,8 kg
Front wheelarch liners and fasteners 2 kg
Carpet under rear seats 2 kg
Electric mirrors 2 kg
Insulation over wheelarch in boot 2,1 kg
Jack 2,1 kg
Glovebox inc, vents and torch 2,2 kg
Rear seatbelts 2,2 kg
Rear speakers from parcel shelf 2,25 kg
Rear seat insulation material 2,4 kg
Boot side trim panels (carpet) 2,5 kg
Rear door and boot weatherseals 2,8 kg
Rear parcel shelf and padding 3,1 kg
Boot carpet 3,9 kg
Insulation from rear seat back 4,2 kg
Rear door trim panel 4,7 kg
Carpet 8,4 kg
Spare wheel and tyre 18 kg
Front seats (leather) 48 kg
Tip: als je gaat slopen, begin dan onderaan dit lijstje :)
Paul
Bericht door Paul » 15 jun 2009, 13:24
lol, dit gaat dus niet over een m3 heh.. die stoelen zijn nog even behoorlijk wat zwaarder met hun 32/33 kilo per stuk :clap:
Bericht door Bert ///M3 » 15 jun 2009, 13:38
Idd.
kan je ook wel aan het startgewicht zien, 1350 KG. M3 zit op 1500 KG volgetankt.
Da Puppet Masta
Bericht door Da Puppet Masta » 20 sep 2010, 15:43
Nice topic.
Dit ga ik maar eens volgen!
Cu,
B
Michel P
Bericht door Michel P » 20 sep 2010, 15:46
Thanks.
Dank kom jij bovenaan te staan in de lijst Macboy :bag:
Paul
Bericht door Paul » 20 sep 2010, 16:46
Uhmm topic was bijna 1.5 jaar oud.... :mrgreen:
Gebruikers op dit forum: Google [Bot] en 3 gasten
