MiTo GTA concept 240pk
Bericht door GTRene » 23 feb 2009, 14:43
Mooi bommetje :df:
Alfa Romeo MiTo GTA Concept, a high performance concept of the new Alfa Romeo MiTo, makes its debut at the 2009 Geneva International Motor Show. Designed using the experience gained with the Alfa Romeo 8C Competizione and 8C Spider, the Alfa Romeo MiTo GTA Concept shares with the exclusive "supercar" the philosophy based on achieving the greatest driving pleasure, resulting from exceptional agility produced by a power-to-weight ratio worthy of a racing car.
In line with the famous GTA (Gran Turismo Alleggerito) signature, (Alleggerito means reduced weight in Italian), the Alfa Romeo MiTo GTA Concept prioritises weight reduction, and the achievement of an optimum power-to-weight ratio.
Considerable work has gone into lowering the vehicle's centre of gravity; thus certain components such as the tailgate spoiler, roof and mirror fairings are in carbon-fibre; while aluminium is used extensively in the braking system, suspension, and some parts of the chassis.
Under the bonnet, an exciting new petrol engine, very much in keeping with the pre-requisites of downsizing, environmental awareness, and the offer of high power and efficiency in return for low weight and optimised packaging, powers the Alfa Romeo MiTo GTA Concept.
Designed by Fiat Powertrain Technologies and exploiting the vast experience gained in the production of Twin Spark and Alfa V6 road and race engines, the compact new petrol engine employs advanced technical solutions including direct injection, dual variable valve timing, state-of-the-art turbocharging and advanced electronic management systems to produce a remarkable 240bhp from just 1742cc.
Under-floor aerodynamics have been a particular concern, while the entire car has been lowered by some 20mm. Front suspension employs new geometry with aluminium leading arms, while the rear suspension has all-new bushings, and the comprehensively revised chassis boasts an 'active' suspension system, (advanced damper control), which counteracts the transfer of load under acceleration, stiffening the rear end and maximising traction. The Alfa Romeo MiTo GTA Concept's suspension also interacts with the braking system and steering to obtain the most efficient control of vehicle dynamics, while a 'Sky-Hook' function ensures an excellent level of passenger comfort under conditions of everyday use.
die achterkant ook erg fraai 8) :love:
Re: MiTo GTA concept 240pk
Bericht door Arthur » 23 feb 2009, 14:45
Da's een Corvette?
Bericht door GTRene » 23 feb 2009, 14:46
Arthur schreef:Da's een Corvette?
Ja de link werkte niet vanaf foto, is reeds veranderd :beer:
Erik-Jan
Bericht door Erik-Jan » 23 feb 2009, 14:48
Ik ben heel benieuwd hoe dit rijdt, hij ziet er i.i.g spectaculair uit!
Is er al iets bekend over de introductie datum?
Bericht door GTRene » 23 feb 2009, 14:49
hier zijn de 3 foto's in het groot te downloaden.
http://www.netcarshow.com/alfa_romeo/20 ... per_03.htm" onclick="window.open(this.href);return false;
http://www.netcarshow.com/alfa_romeo/20 ... per_02.htm" onclick="window.open(this.href);return false;
http://www.netcarshow.com/alfa_romeo/20 ... per_01.htm" onclick="window.open(this.href);return false;
Aernoudt
Bericht door Aernoudt » 23 feb 2009, 14:49
Filmpje van de achterkant:
http://tv.repubblica.it/copertina/e-una ... 9727?video" onclick="window.open(this.href);return false;
Bericht door GTRene » 23 feb 2009, 14:51
Aernoudt schreef:Filmpje van de achterkant:
lekker kontje he :thumbup:
Metchu
Bericht door Metchu » 23 feb 2009, 14:55
Ik zat te wachten tot ie werd gestart... helaas :( Maar het ziet er goed uit... 8)
Bericht door GTRene » 23 feb 2009, 15:34
Hij schijnt dus te komen in de zomer?
De Alfa Romeo Mito GTA (Gran Turismo Alleggerito) heeft zoals verwacht de beschikking over een viercilinder turbomotor met een vermogen van 240 pk. De cilinderinhoud bedraagt 1.742 cc, waardoor we strikt genomen dus eigenlijk met een 1,7-liter blok te maken hebben. Alfa Romeo heeft het echter consequent over 1,8 liter.
Het Italiaanse merk heeft veel in het werk gesteld om het zwaartepunt te verlagen. Gewichtsreductie is daarom het toverwoord bij de Mito GTA. De achterspoiler, het dak en de buitenspiegelkappen zijn van koolstofvezel. De ingenieurs hebben in het remsysteem en voor de wielophanging aluminium gebruikt. De Mito GTA ligt 20 millimeter dichter bij het wegdek. Een actieve wielophaning (Advanced Damper Control) zorgt voor maximale tractie.
De Mito GTA Concept beleeft z'n debuut op de Autosalon van Genève. In de loop van de zomer komt de productieversie van de top-Mito op de markt. De belangrijkste concurrent wordt de Mini John Cooper Works. Die moet het echter doen met 211 pk.
2000USA
Bericht door 2000USA » 23 feb 2009, 15:36
Filmpje 2 toch?
Metchu
Bericht door Metchu » 23 feb 2009, 15:39
Nu zie ik het, er is nog een 2 en een 3 aan de rechterkant... Maar dat filmpje breekt ook niet echt potten he ... :?
Mike R32
Bericht door Mike R32 » 23 feb 2009, 15:50
Mooi bommetje, prijzen zullen wel iets onder die van de Mini JCW liggen.
elogiov6
Bericht door elogiov6 » 23 feb 2009, 19:39
Wat een prachtige alfa! Helemaal goed! Deze roept bij mij hetzelfde gevoel op als;
Laatst gewijzigd door elogiov6 op 24 feb 2009, 16:27, 1 keer totaal gewijzigd.
Snipe
Bericht door Snipe » 23 feb 2009, 21:24
Vrolijk 130i's voorbij blazen met je Mito 1.7 :df:
Mooi man.
Aernoudt
Bericht door Aernoudt » 23 feb 2009, 21:28
elogiov6 schreef:Wat een prachtige alfa! Helemaal goed! Deze roept bij mij hetzelfde gevoel op als;...
Ga jij eens heel gauw je mond spoelen ! :protest:
elogiov6
Bericht door elogiov6 » 23 feb 2009, 22:22
Hahahahah, :nana: Nee hoor Aernoudt, weight reduction en optimum power to weight ratio klinkt mij als muziek in de oren, Heb jaren met lede ogen moeten toezien hoe de 156 steeds zwaarder werdt. En een beetje Brera 1600 KG! Ben erg blij dat het gewicht bij deze GTA weer een bepalende factor is.
Aernoudt
Bericht door Aernoudt » 23 feb 2009, 22:28
Die 100 gram lichtere spiegels doen het 'm echt niet denk ik zo ;)
Bericht door GTRene » 23 feb 2009, 22:36
Aernoudt schreef:Die 100 gram lichtere spiegels doen het 'm echt niet denk ik zo ;)
:mrgreen: tis wel iets meer, zal me beniwuen wat het uiteindelijk weegt...
Aernoudt
Bericht door Aernoudt » 23 feb 2009, 22:41
1230 kilo ongeveer
Roy
Bericht door Roy » 23 feb 2009, 23:01
Wat een achterkant :thumbup:
Bericht door GTRene » 24 feb 2009, 10:28
Aernoudt schreef:1230 kilo ongeveer
Das netjes voor de auto's van tegenwoordig...en met 240pk is dat een beetje power to weight van een E30 M3 Sport Evo :mrgreen:
Harrie
Bericht door Harrie » 24 feb 2009, 11:15
Ik vind het een erg mooie auto. Klein dik ding. Maar 1230kg vind ik toch wel erg veel voor zo'n KLEINE auto.
Ik ga zeker kijken als ie uit is.
Bericht door Arthur » 26 feb 2009, 13:32
Ik vind zo'n Mito aan de voorkant gezien niet mooi. Oogt erg smal. Past 'ie iig in de binnenspiegel @Snipe :wink:
Snipe
Bericht door Snipe » 26 feb 2009, 13:40
Recht van voor gezien is 'ie inderdaad iets te smal.
@ Arthur:
Bericht door Arthur » 26 feb 2009, 14:07
:) Da's een buitenspiegel.
Gebruikers op dit forum: Geen geregistreerde gebruikers en 41 gasten
