Nissan 370Z pag 3 test met Tiff
Roman
Bericht door Roman » 27 jun 2008, 01:02
The crew at 7Tune got a hold of the latest issue of Best Car, and in addition to creating their own full size Z34 Nissan through the use of bondo and stickers, they've got more details on the next iteration of the Z car.
Due to go on sale later this year, likely after an official unveiling at the LA Auto Show, the 370Z will be packing the same 3.7-liter, VQ37HVR V6 found in the Infiniti G37, with output estimated at around 335 hp and 278 lb.-ft. of torque (JDM spec). Best Car spoke with the Z34's Chief of Production, Shinjiro Yukawa, and he revealed that a special edition model is being considered that would significantly raise the performance of the new Z by fitting a V8 underhood.
The new car will come in about 100 kg (220 pounds) lighter than the outgoing model, and equipped with either a six-speed manual gearbox or a seven-speed sportshift-equipped automatic. Double wishbones will suspend things up front, while a multi-link arrangement will handle duties in the back. The top-spec S and ST versions are expected to roll on upgraded 19-inch wheels, while lower models make due with 18-inch hoops, and Brembo 6-piston front and 4-piston rear brakes will halt forward progress on the high-end models.
As expected, the headlamps will feature the same L-shaped design originally debuted on the new Maxima, while the A-pillar and roof treatment are rumored to ape the lines found on the R35 GT-R. Also expect upswept side windows and more bulbous fenders to round out the exterior makeover.
[img:530:336]http://www.7tune.com/newtune/justin/new ... dy_z_1.jpg[/img]
[img:530:236]http://www.7tune.com/newtune/justin/new ... dy_z_2.jpg[/img]
[img:530:375]http://www.7tune.com/newtune/justin/new ... dy_z_3.jpg[/img]
[img:530:236]http://www.7tune.com/newtune/justin/new ... dy_z_4.jpg[/img]
http://www.7tune.com/high-performance-z ... ssible-v8/
Laatst gewijzigd door Roman op 25 jun 2009, 10:55, 1 keer totaal gewijzigd.
Bericht door indobesar » 27 jun 2008, 01:16
Ziet er smooth uit ivm de 350Z. De 3,7 v6 is een juweel, als ik de testen van de G37 lees.
Bericht door GTRene » 27 jun 2008, 11:21
100kg lichter? das goed nieuws 8)
Aernoudt
Bericht door Aernoudt » 27 jun 2008, 11:51
GTRene schreef:100kg lichter? das goed nieuws 8)
Yep ! Ben ook benieuwd naar de nieuwe bak en de nieuwe motor. Vorige bak was best stroefjes.. Motor kon (zeker onderin; daar zijn ze bij BMW echt een stuk verder mee; kwam die best te kort (heb niet met die laatste versie gereden wel met de eerste en het tussen model))
Bericht door Macboy » 14 jul 2008, 11:34
Japanners snappen het tenminste qua gewicht (Mazda zet de benchmark, maar heeft geen sportauto in het gamma dus niet zo heel relevant)
Mark Nauta
Bericht door Mark Nauta » 14 jul 2008, 11:39
Op die 2e foto lijkt de achterkant wel heel massief en een tikkeltje 'doorgezakt'. Vind ik niet echt mooi. Als ik dit zo zie, dan gaat mijn voorkeur uit naar de 350, maar eens zien hoe die gaat worden dan en hoe het irl lijkt.
Bort
Bericht door Bort » 14 jul 2008, 15:34
Die voorste wielkassen icm de voorlichten. Krijg ik toch een what the fuck gevoel van.
Bericht door Knot » 14 jul 2008, 16:57
Autotje mocht wel wat afslanken idd, was geen echte lichtvoeter...
Sven VS
Bericht door Sven VS » 14 jul 2008, 19:01
Macboy schreef:Japanners snappen het tenminste qua gewicht (Mazda zet de benchmark, maar heeft geen sportauto in het gamma dus niet zo heel relevant)
:shock: onder een steen geleefd de laatste jaren ?
SteV6
Bericht door SteV6 » 14 jul 2008, 20:10
Als die foto's een indicatie zijn van hoe het model er uit moet gaan zien, dan wordt de buitenkant voor mij toch een flinke hindernis om een 370Z te gaan overwegen.
SteV6
Hendrik Kinderman
Bericht door Hendrik Kinderman » 14 jul 2008, 20:21
SteV6 schreef:Als die foto's een indicatie zijn van hoe het model er uit moet gaan zien, dan wordt de buitenkant voor mij toch een flinke hindernis om een 370Z te gaan overwegen.
SteV6
Photoshop van de huidige 350Z... vind de achterste zijruitjes nog niet zo geweldig. heeft daardoor wel iets van de 240Z, wat wel weer 'iets' heeft
Roman
Re: Nissan 370Z (misschien ook V8)
Bericht door Roman » 09 okt 2008, 13:37
Nissan's upcoming redesign of its Z car is almost here, and proof positive is this prototype caught cruising around in the vicinity of Germany's famed Nürburgring. The redesign is on full display here, with the boomerang-style headlights and taillights first seen on the new Maxima clearly visible. The whole front end is new but retains a visual connection with its predecessor, while big fender flares give away that the new car might be rolling on a wider track. There are also a few more kinks and creases on the new car, which are on display in the chunky C-pillar. We think it looks terrific as an attractive evolution of the current 350Z. The new car will change its nomenclature slightly to 370Z when it debuts this auto show season thank to the addition of Nissan's new 3.7L V6 that will be producing well over 300 horsepower in the new Z. Word has it that Nissan has also worked hard to address one of the biggest criticisms against the current car: weight. We'll probably have more spy shots of the 370Z as soon as Nissan begins running it around the 'Ring, and wouldn't be surprised to see the car officially debut at next month's LA Auto Show.
Laat maar komen :hosanna:
Stéphane
Bericht door Stéphane » 10 okt 2008, 11:57
Gaaf! Ik blijf het leuk vinden om die auto's te zien rijden op plaatsen waar je zelf ook wel eens geweest ben op en rondom de Ring. Die laatste foto's herken ik de locatie ook wel, maar ik kan het nu even niet precies voor me halen :D
Aernoudt
Bericht door Aernoudt » 10 okt 2008, 19:43
Ben heel benieuwd ! Ziet er goed uit (en qua specs: lichter en meer vermogen klinkt als muziek in de oren)
Bericht door Macboy » 12 okt 2008, 01:59
Stéphane schreef:Die laatste foto's herken ik de locatie ook wel, maar ik kan het nu even niet precies voor me halen :D
Dat is toch dat eerste dorpje richting Kesselchen ?
Stéphane
Bericht door Stéphane » 12 okt 2008, 22:52
Nee, is in Nürburg zelf ergens beneden richting Tiergarten volgens mij.
Jan Visser
Bericht door Jan Visser » 19 okt 2008, 14:47
Nieuwe 370Z in een filmpje van Motortrend
Stéphane
Bericht door Stéphane » 19 okt 2008, 19:30
Gaaf :shakeit:
Erick
Bericht door Erick » 20 okt 2008, 11:31
Als je een beetje je gedachte erover laat gaan is het dus bijna een combi van een GTR front 350Z/240Z zijkant(240Z voor het zijruitje) en een gewijzigde 350Z achterkant met Maxima voor en achterlichten die nu op de lampen van de GTR lijken.
Bericht door GTRene » 20 okt 2008, 12:21
Ik kan me bijna niet voorstellen dat die auto zo laag wordt geleverd als op de foto's...hij ligt behoorlijk diep...of der komst een special onderstel onder die de auto kan verlagen voor op het circuit...race-modus :df:
Bericht door indobesar » 29 okt 2008, 13:58
Vergeet de Nissan 350Z: dit is de 370Z. Die moet Nissan weer wat beter op de kaart zetten in de klasse van de Porsche Cayman en de Audi TT.
Nissan geeft de eerste informatie vrij over de Nissan 370Z. Voorlopig moeten we het even doen met deze drie foto’s. Het nieuwe model is directe familie van de Infiniti G37. Ze hebben de zelfde 3,7-liter V6, al levert die in de Nissan wat meer vermogen. Ook aan de binnenkant zijn de familiebanden duidelijk: het interieur lijkt eveneens erg op dat van de Infiniti. Opmerkelijk is dat de toerenteller opnieuw een centrale plek op het dashboard gekregen.
Wat betreft vermogen ontlopen de Infiniti en deze nieuwe Nissan elkaar wel. De Infiniti komt niet verder dan 320 pk, voor 370Z zetten we in op minimaal 330 pk. Op dit moment hebben we nog geen specificaties beschikbaar. Door de extra paarden wordt de 370Z een wat sportievere auto, waar de Infiniti meer is gericht op luxe. De nieuwe Nissan is volgende maand voor het eerst op de autoshow in Los Angeles te bewonderen. In de loop van volgend jaar maakt hij zijn opwachting
Bericht door indobesar » 29 okt 2008, 13:59
Oogt erg compact en gespierd. Gaaf ding!
Bericht door allen » 29 okt 2008, 14:07
Gezien het feit dat ik altijd kriegel wordt van verlichting met rare vormen zou ik moeten zeggen dat het een lelijke wagen is. Doe ik niet. Vind het absoluut een prachtig ding. Zowel van binnen als van buiten.
Bericht door RVV » 29 okt 2008, 14:18
Erg mooie auto, vond ik van dee vorige ook al.
Bericht door Tom » 29 okt 2008, 14:19
Die lichten... bahbah.
Misser.
Vorige vond ik veeeel mooier/tijdlozer.
Gebruikers op dit forum: Geen geregistreerde gebruikers en 118 gasten
