135i 335i 535i tuning draadje
Gesloten
Bericht door GTRene » 25 apr 2008, 12:50
Er is al veel over gesproken, misschien dat Dinan een antwoordt heeft, die schijnen al setjes klaar te hebben, check wel je DME code's die wat reeds klaar zijn staan vermeld als je het verhaal leest, de prijs 1.999,-dollar is zelfs voor Amerikanen aan de prijs, maar tis ook een hele waslijst van herprogrammeren geweest als je de lijst zo leest.
de 135i omvangrijke chiptuning>>
http://www.dinancars.com/store/Performa ... -3898.html
de 335i omvangrijke chiptuning>>
http://www.dinancars.com/store/Performa ... -3832.html
de 535i omvangrijke tuning>>
http://www.dinancars.com/store/Performa ... -3846.html
en wat best wel omvangrijk is? hier als voorbeeld het 335i chippie :shock:
Performance Engine Software/Boost Upgrade
Dinan is pleased to announce the introduction of the anxiously awaited Performance Engine Software for BMW 335 models. And as always, Dinan matches the new car warranty coverage for up to 4 years or 50,000 miles, including the possibility of consequential damages*. No one offers better performance or backs it up with such comprehensive warranty coverage.
The Dinan Performance Engine Software safely increases turbo-boost pressure from the stock 8.8 to 13.2 psi, along with properly retuned fuel mixtures, ignition timing and full map rescaling. In fact, over 2000 engine management functions have been recalibrated, offering substantial increases in power output while maintaining the civility and reliability expected of a Dinan performance product. Some examples include:
Remapped Water Pump Speeds. In an effort to more effectively control oil and water temperatures, which have been notably excessive even at stock boost pressures, the Dinan software actually increases water pump speeds as boost pressure increases. A much larger, more efficiently ducted oil cooler has also been developed, further improving heat exchange for lower and more consistent operating temperatures, even with the added boost pressure.
Boost Pressure Control. Increased boost pressure exceeds the turbochargers’ design limitations at higher rpm, potentially shortening their lifespan. Dinan addresses this issue by tapering the boost gradually at higher engine speeds. This approach also addresses the fact that with increased boost at higher rpm the turbocharger temperatures would exceed the intercooler’s ability to cool the intake charge, resulting in a loss of power and compromising the long-term durability of the engine. The tapered boost keeps temperatures within the design limitations so as to optimize output and ensure engine reliability with the added boost pressure.
Top Speed Governor Removed. With Dinan’s software, the 335 will be capable of achieving its natural top speed as the governor has been removed.
The results of Dinan’s tuning are nothing short of breathtaking, with the added boost and related recalibration producing maximum output of 384 horsepower at 5700 rpm and 421 lb-ft torque at 4300 rpm. All of this additional power is available from Dinan’s software alone, which is easily downloaded by your Authorized Dinan Dealer in about an hour.
Currently, Dinan software is applicable for vehicles equipped with the MSD v80.0 DME (engine management computer). Vehicles equipped with the MSD v81.0 DME are not yet supported. For the most part, the production date break appears to be 3/08, however this is not an absolute so it is best to check the DME label.
*In order to qualify for Dinan’s matching new car warranty coverage, which includes consequential damages, the vehicle MUST be equipped with either a factory oil cooler (not all 335s were equipped from the factory with an oil cooler) or Dinan’s High Capacity Oil Cooler (recommended).
Dinan software is not available for purchase on-line as it must be downloaded by an Authorized Dinan Dealer using specialized equipment. Contact your local Dinan Authorized Dealer directly for the purchase and installation of Dinan software.
Part # D900-30T3
Labor Hours 1
Price $1999.00
Emission Status 49 State Emission Legal
Maximum Horsepower Gain
Maximum Torque Gain
Point Value 2
Peak Horsepower 384 horsepower at 5700 rpm
Peak Torque 421 lb-ft torque at 4300 rpm
Special Notes Dinan software is not available for purchase on-line as it must be downloaded by an Authorized Dinan Dealer using specialized equipment. Contact your local Dinan Authorized Dealer directly for the purchase and installation of Dinan software. Currently, Dinan software is applicable for vehicles equipped with the MSD v80.0 DME (engine management computer). Vehicles equipped with the MSD v81.0 DME are not yet supported. For the most part, the production date break appears to be 3/08, however this is not an absolute so it is best to check the DME label.
Included Items
Required Products *In order to qualify for Dinan’s matching new car warranty coverage, which includes consequential damages, the vehicle MUST be equipped with either a factory oil cooler (not all 335s were equipped from the factory with an oil cooler) or Dinan’s High Capacity Oil Cooler (recommended).
ow en voor alle produckten (leuk choppen alle types) zie hier >>
http://www.dinancars.com/store/cart.php
Bericht door RVV » 25 apr 2008, 13:43
Gesloten
Gebruikers op dit forum: Geen geregistreerde gebruikers en 61 gasten
