Dus ja ik weet niet nu hoe & wat?
Op die foto's van Rebel zie ik 'n paar die ik wel ken: Benno Leeser(Gassan) , Paul Simons(Ice Watch Paul Simons) en Koster van Bretling NL.
Wel eens (mee)gereden in een GT-R ?Robin_NL schreef: Je zou dit de Nissan GTR(Playstationachtige electronic gadgetry) onder de horloges kunnen noemen.
Bij de mechanische GRAND Seikos denk ik aan 'n Lexus LFA of 'n NSX achtig iets. (Puurder en echter(?))
Specifications:
Model: Moana Pacific Professional
Movement: 9015 Miyota with hacking seconds
Case diameter: 44mm excluding the crown
Case finish: PVD (black), PVD (rose gold) and Stainless steel brushed/polished.
Bezel: Black ceramic (matt finish) with C3 LUMINOUS fillings.
Crown: Screw down crown.
Crystal: Sapphire (double domed) with AR coating.
Dial and hands: Super Luminova C3 .
Pressure valve: functional pressure escape valve, protecting the watch against pressure differences that can occur below 300 meters of depth
Water-resistance: 500m/1650ft Water resistance
Strap: All new black PU rubber strap with logo, name and customized stainless steel deployment buckle. (other strap options will be available)
Price: Stainless Steel: €499 / Black PVD: € 529 / Rose gold PVD: € 549.*
New Movement
Please note that this will be the first time we will use the relatively new Citizen/Miyota 9015 movement.
This movement is positioned between the well known ETA 2824 and more luxurious 2892 movements. We have returned to the Miyota company as we have great experiences with the 8215 movement.
•Automatic winding and hand winding
•28.800 BPH
•24 Jewels
•Hour, minute and sweeping second hands
•Date function
•Second stop mode (hacking function) when setting time
•Shock absorber for balance staff
•Running time of more than 42 hours when fully wound
Originally introduced at Baselworld 2012, the Seiko Astron GPS Solar is an unprecedented solar powered quartz GPS watch. It features automatic GPS calibration of hours, minutes and seconds, including automatic and manual time zone adjustment, across all time zones (and with regards to Daylight Savings time); it also has a perpetual calendar function, correct to February 2100.
GPS signals can be received from any of the free Global Positioning Satellites, from any place in the world, via the built-in antenna which wrapped around the inside of the case band. The GPS signal, like on radio-controlled watches, automatically calibrates the hours, minutes and seconds. The biggest advantage of GPS calibration versus atomic radio-controlled calibration — especially considering that both are essentially atomically calibrated systems as far as accuracy, is the range. GPS reaches virtually anywhere on Earth, provided of course, there is a unobstructed line of site of at least 4 of the 24 Navastar GPS satellites currently orbiting the Earth (there are also 4 spare satellites). Like GPS, radio-controlled watches require an unobstructed line of site, but unlike GPS, signal calibration is transmitted from the nearest of 6 worldwide atomic radio broadcast stations which are on the ground, and the range is therefore limited to approximately 1,800+/- miles. GPS based systems are not limited — this is why GPS/Satellite phones and non-cellular based GPS navigation units are important to scientists, military and anyone far out of the range of traditional communication signals — because range is unlimited.
Powered by quartz caliber 7X52, which consists of a low-energy consumption solar powered GPS module, accuracy is +/- 15 second per month (without receiving a time signal) and precise to the second when the signal is received. The case measures 47 mm by 16.5 which is fairly large, however, that is the price you pay for such advanced technology. Like its 1969 predecessor, the world’s first quartz watch, the new Astron will make a significant impact of wristwatches in the future. Expect more models to utilize similar technology down the road.
Gebruikers op dit forum: Amazon [Bot], Majestic-12 [Bot] en 18 gasten
