Kentekencheck, leuke feature!
RobS
Re: Kentekencheck, leuke feature!
Bericht door RobS » 01 feb 2011, 18:32
Metchu schreef:
Server Error in '/' Application.
The remote server returned an error: (550) File unavailable (e.g., file not found, no access).
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Net.WebException: The remote server returned an error: (550) File unavailable (e.g., file not found, no access).
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[WebException: The remote server returned an error: (550) File unavailable (e.g., file not found, no access).]
System.Net.FtpWebRequest.SyncRequestCallback(Object obj) +330
System.Net.FtpWebRequest.RequestCallback(Object obj) +23
System.Net.CommandStream.InvokeRequestCallback(Object obj) +17
System.Net.CommandStream.Abort(Exception e) +168
System.Net.FtpWebRequest.FinishRequestStage(RequestStage stage) +454
System.Net.FtpWebRequest.GetResponse() +1398
dftv.ftp.DirectoryListing(String folder) +161
dftv.Images.GetAutodiskImages(Byte MerkID, Int32 ModelNo, Int32 Year, String MerkDescription, String TypeDescription) +399
kenteken.BindKenteken(String Kenteken) +1460
kenteken.Page_Load(Object sender, EventArgs e) +186
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
PageOverride.OnLoad(EventArgs e) +4
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.4200; ASP.NET Version:2.0.50727.4016
Hier idem, ook mx-5
Stefan R
Auto: Vakantievoertuig
Bericht door Stefan R » 01 feb 2011, 18:33
Foutmelding..... :(
ErikMartijn
Bericht door ErikMartijn » 01 feb 2011, 20:33
Ik kreeg ook een error...
Bericht door JP » 01 feb 2011, 20:36
Een 6.2 en dat voor een Golf.
Maar ja, aandrijving aan de verkeerde kant èn turbo. Dat werkt ook alleen maar averechts... :hmmm:
Sytze
Bericht door Sytze » 01 feb 2011, 20:45
Is het eindelijk storingsvrij kan ik het niet meer zien ivm limiet!
Thomasss
Auto: Bakfiets!
Bericht door Thomasss » 01 feb 2011, 22:23
7,2 voor een 180pk Megane. Dikke prima. :D
Laurens
Bericht door Laurens » 01 feb 2011, 22:25
7,1 voor de E46 ach ja met een Dacia Logan kun je net zoveel DF hebben als het maar hard de hoek om gaat :playcar:
SteV6
Bericht door SteV6 » 01 feb 2011, 22:42
Snipe schreef:Lager is beter, want het is namelijk gewoon het aantal kilo's per pk.
Idee is dus leuk, maar kilo's per pk zegt niets over de Driving-Fun-factor ....
HAMMERHEAD
Bericht door HAMMERHEAD » 01 feb 2011, 23:00
Uitvoering:
Type:onbekend
Aantal zitplaatsen:0
Kleur(en):grijs
Motor:
Brandstof:benzine
Aantal cilinders:4
Cilinderinhoud:N.v.t.
Vermogen:0 kw (0 pk)
Massa & laadvermogen:
Massa leeg voertuig:1200 kg
Laadvermogen:N.v.t.
Toegestane max. massa voertuig:0 kg
Massa rijklaar:1300 kg
toch altijd leuk zo'n import :)
Snipe
Bericht door Snipe » 01 feb 2011, 23:12
Zie het maar als ons protest tegen de steeds maar zwaardere auto's. In de advertenties voor gebruikte auto's zal die verhouding ook een rol gaan spelen, want het getal wordt standaard vermeld bij alle aangeboden auto's.
VLA
Bericht door VLA » 02 feb 2011, 14:33
DF score : 5,1 (Honda S2000)
Michel P
Bericht door Michel P » 02 feb 2011, 14:38
Nog steeds een error Jelmer, met het bij jou bekende kenteken!
Gijzer
Bericht door Gijzer » 03 feb 2011, 07:49
Yes, een 9,1.
Zo'n cijfer heb ik op mijn studie nog nooit gehaald. :banaan: :banaan: :banaan:
RJay
Bericht door RJay » 03 feb 2011, 07:59
Mijn marbellatje scoort infinity.
Klinkt goed :mrgreen:
wjn
Bericht door wjn » 03 feb 2011, 16:47
Ik blijf foutmeldingen krijgen:
Source Error:
Stack Trace:
siegerdehaan89
Bericht door siegerdehaan89 » 03 feb 2011, 17:50
Mijn Giulia:
Merk:alfa romeo
Handelsbenaming:GIULIA SUPER 1.6 LUSSO
Brandstof:benzine
Vervaldatum APK:5-7-1980
Aanvang 1ste tenaamstelling:5-7-1978
Aanvang laatste tennaamstelling:2-2-2011
BPM:€ 0,-
Score: Infinity
En dat laatste klopt heeeelemaal alsie straks klaar is!!!! Tzt eens een sprint trekken tegen VWK zn 3.2 :clap: :mrgreen:
Niels v D
Bericht door Niels v D » 09 feb 2011, 20:08
Komt er weer een 1.8t in Sieger? Doe ons eens updaten? :)
ErikMartijn
Bericht door ErikMartijn » 09 feb 2011, 20:12
Krijg nog steeds deze error:
Source Error:
Stack Trace:
kenteken.BindKenteken(String Kenteken) +1475
kenteken.Page_Load(Object sender, EventArgs e) +253
Sytze
Bericht door Sytze » 09 feb 2011, 20:54
Heb ik ook last van,met het kenteken van een andere auto is het wel goed.
Hans R
Auto: Jeep Rubicon
Bericht door Hans R » 09 feb 2011, 20:56
Hahahaha... Lotus Exige 240 PP een 3,7 DF :lol:
Grapjassen..
Edit: ik zie net pas hoe lager hoe beter :thumbup:
Bericht door Peter Tunissen » 09 feb 2011, 20:56
Het is hoe lager, hoe beter..... ;)
Joopieboy
Bericht door Joopieboy » 13 feb 2011, 11:09
Leuke feature ja haha. Mijn suuz krijgt een 11,1, een behoorlijk vooruitgang op mijn R19, die een 11,7 krijgt. :mrgreen:
Nicodepico
Bericht door Nicodepico » 14 feb 2011, 21:46
Je bent pas een echte autonerd als je aan de DF-factor het merk en model auto kan raden./
Komt ie, 6,9
Raad maar! ;-)
Sytze
Bericht door Sytze » 21 feb 2011, 20:51
Wordt die storing ook nog verholpen of?
Ben wel benieuwd naar de DF score :banaan:
Erik dB
Bericht door Erik dB » 21 feb 2011, 21:35
Onbekend voor zowel de Alfa als BMW.
Gebruikers op dit forum: Eric Z, Fabian, RS-Ron en 54 gasten
