Z3 Coupé S54 swap/6 bak + e91 320d
Re: Z3 Coupé S54 swap + 6bak (eerste start + nieuwe foto's)
Bericht door GTRene » 07 okt 2015, 18:02
idd gewoon Z3 coupe folder met foto van S54 motor, die moet er wel zijn, meer bewijs hoeft niet nodig te zijn.
je hebt zo te lezen al heel wat wegen bewandeld, om moedeloos van te worden terwijl het eigenlijk zo simpel kan.
maar dat licht er ook aan bij welk keurings station en welke keurmeesters e.d. je te maken krijgt.
zoiets maar dan NL of Duitse versie, misschien heb ik ook nog de folder...zal eens kijken laters
http://www.ebay.com/itm/2001-BMW-Z3-M-R ... 58cede5ec0" onclick="window.open(this.href);return false;
en anders stuur je ze naar wiki>>
https://en.wikipedia.org/wiki/BMW_M_Coupe" onclick="window.open(this.href);return false;
S54 (2001–2002)[edit]
In October 2001, the M Coupe reappeared worldwide with the new 3.2-litre S54B32 engine from the E46 M3. In the M Coupe it produces 325 PS (239 kW; 321 hp) at 7400 rpm and 258 lb·ft (350 N·m) at 4900rpm in European specification and 319 PS (235 kW; 315 hp) at 7400 rpm and 251 lb·ft (340 N·m) in North American specification. The difference in peak power and torque is due to the catalytic converters being located closer to the engine on the NA spec cars, which allows the catalysts to heat up faster and reduce cold start emissions. It has been observed that the NA-spec catalytic converters may have been fitted to cars in some European countries.[3]
In South Africa only 39 right hand drive S54 models were imported and all were equipped by BMW SA with AC Schnitzer suspension, exhaust, short shift kit and 18-inch "Type 3" wheels.[2][4]
European left hand drive S54 engine: 269 cars built from February 2001 through May 2002
European right hand drive S54 engine: 165 cars built from February 2001 through May 2002
North America S54 engine: 678 cars built from February 2001 through May 2002
Total S54 Production: 1112[2]
Bericht door matthyssie » 07 okt 2015, 19:24
Op het kenteken van een Z3M met S54 (dus bijv die van Niels) staat toch een typegoedkeuringsnummer? Kunnen ze daar niks mee?
e30touring1990
Auto: Z3QP S54/1M/G11 740/M8C
Bericht door e30touring1990 » 07 okt 2015, 19:25
Goede ideeën mannen! Thanks voor de snelle reacties.
@Niels, Ik ga je een pb sturen!
@Tristan, goede suggestie:)
@Fabian, ik kwam niet verder dan een telefonisch medewerker. Op z'n zachtst gezegd zijn ze niet erg flexibel.
@René, wiki zat ik ook aan te denken maar aangezien iedereen de content van wikipedia kan aanpassen vraag ik me af hoe legit ze dit vinden. Ik kan het sowieso uitdraaien en meenemen uiteraard.
Waar het ze om gaat is dat er aangetoond wordt dat de Z3 is geleverd met S54. Verder willen ze waarschijnlijk weten dat er in de constructie geen extra verstevigingen zijn aangebracht hoewel ik me af vraag in hoeverre ze daar echt naar kunnen en zullen kijken.
Uitgangspunt is gewoon dat er een Europees type goedkeuring bestaat voor combi carrosserie + motor.
Bericht door GTRene » 07 okt 2015, 21:15
net al even gekeken tussen al die BMW M folders hiero, wel aardig wat M coupe en M roadster en Z3 zaken, maar of van 1997 of 1999 of 2000 en bv in die van 2000 staan niet eens de gegevens bij omdat die veranderd zouden worden, waren ten tijde van drukken nog niet bekend.
Kon dus helaas geen M coupe S54 folder vinden, wel de M3 brochures van die tijden, maja.
Zag ook een 2000 folder met de Z3 coupe 3.0 :mrgreen:
en las dat het geen gewoon digitaal klokje is in de console, maar een boardcomputer...hm :)
toch de autoboekjes die er bij zitten maar eens een keer doorlezen, wat er allemaal nog meer op zit.
Bericht door Niels » 08 okt 2015, 04:13
Moet goedkomen lijkt me!
Bericht door MParallel » 08 okt 2015, 12:43
Waarom wil BMW niete ven bevestigen dat dit zo geleverd is? Kleine moeite toch?
Je vraagt ze niet om iets te fantaseren van V10 blok in E30 geleverd oid.
FreudeamFahren
Bericht door FreudeamFahren » 08 okt 2015, 12:56
Omdat BMW elke vorm van aansprakelijkheid wil mijden.
Stel dat BMW zegt: is zo geleverd. Auto wordt goedgekeurd, er ontstaat een ongeluk als gevolg van een groot technisch defect, de intercity van half 8 naar Schubbekutteveen ontspoord, de verzekeraar "mag" een schadepost van miljoenen vergoeden, onderzoekt het voertuig, krijgt daarbij schriftelijk bevestigd dat BMW hem ook zo bouwt en daar komt de procedure verzekeraar vs BMW.
In de manier van vastleggen door BMW is dat risico te beperken, maar door die uitspraken helemaal niet te doen is het risico verkleind tot nul.
Bericht door GTRene » 08 okt 2015, 13:01
heb wat gevonden over het type met 325pl (geknepen in rpm motor)
een brochure van bmw uit 2002 met ook de laatste M coupe
http://link.marktplaats.nl/m953965181" onclick="window.open(this.href);return false;
dacht hey, komt me redelijk bekend voor die voorpagina...ik weer naar boven, ja zelfde auto maar dan onderin en brochure uit jaar 2003 met de csl en cabrio en m3 (dus niet de Z3 M helaas)
e30touring1990
Bericht door e30touring1990 » 08 okt 2015, 14:06
MParallel schreef:Waarom wil BMW niete ven bevestigen dat dit zo geleverd is? Kleine moeite toch?
Wat FaF zegt idd. Dat is ook hetgeen waar ik bang voor was. Vanmorgen het RDW gebeld met de vraag of hij voldoende informatie heeft aan evt kopie kenteken van Niels met type goedkeuring volgens Europese wetgeving maar daar werd geen genoegen mee genomen omdat zijn auto van 2001 is en die van mij van 1999.
Kortom ik word een beetje moedeloos van dat touwtrekken met zo'n organisatie als het RDW. Enige wat ik nu eigenlijk nog als opties zie: A) uitvoeren naar DE en tuv keuren om vervolgens opnieuw in te voeren waarbij RDW verplicht is deze keuring over te nemen want EU richtlijnen. Nadeel veel administratieve rompslomp. B) Lelystad. Het gaat met niet zozeer om het geld wat erbij gemoeid is (hoewel dat ook zonde is ofc) maar meer dat ik principieel niet wil bukken voor die organisatie en haar inconsistente regelvoering. Daarnaast heb ik natuurlijk liever niet dat ze er in gaan rijden.
Bericht door Arthur » 08 okt 2015, 14:24
Wat gebeurt er dan met je auto als je gaat voor optie B? Ze doen toch geen crashtest ofzo. Mss gaat ie topspeed over de kombaan, zigzaggend door de bocht en vol in de ankers. Iets wat jij ongetwijfeld ook een keer (moet) doet(n).
Je wilt toch een keer met dat ding de weg op, ga ik vanuit?
Bericht door Martijn_bmw » 08 okt 2015, 15:12
zoek een voorbeeld auto uit 1999? die zullen vast te koop staan...
-edit-
even opgezocht, zo snel 4 voorbeelden:
http://www.autotrader.nl/auto/bmw-z3/19 ... 3-m-coupe/" onclick="window.open(this.href);return false;
http://www.autowereld.nl/bmw/z3-coupe/m ... tails.html" onclick="window.open(this.href);return false;
geef zon kenteken als voorbeeld, daarbij zou ik even bellen met BMW dusseldorp hoogenveen daar staat deze: ( http://www.autowereld.nl/bmw/z3-coupe/m ... tails.html" onclick="window.open(this.href);return false; ) die dealer is echt bijzonder hulpvaardig altijd. Ben er van de zomer geweest om een 1 serie te kopen, niks waste gek.
misschien kunnen ze je verder helpen adv de Z3M die bij hun te koop staat ook uit 1999
Bericht door Martijn_bmw » 08 okt 2015, 15:17
https://ovi.rdw.nl/default.aspx?kenteken=71SZSJ" onclick="window.open(this.href);return false;
hoeveel info willen ze hebben... eventueel bij hoogeveen CVO opvragen van dit kenteken, willen ze dat niet dan langs gaan chassis nummer opschrijven en CVO bij BMW nl aavragen met het chassisnummer
e30touring1990
Bericht door e30touring1990 » 08 okt 2015, 15:30
Wederom goede ideeën mannen! Thanks voor het meedenken. Ik ga een telefoontje wagen aan Dusseldorp in de hoop dat ze een cvo kunnen geven. Ik weet alleen niet of dit per chassisnr gebonden is of dat de data overdraagbaar is naar een ander chassisnr.
Bericht door Martijn_bmw » 08 okt 2015, 15:54
CVO is chassis gebonden maar dan heb je wel een voorbeeld uit je eigen bouwjaar...
Ik werd toe geholpen door Luca Neerhof, jonge aardige vent die echt BMW gek is en ook zulke projecten wel kan waarderen denk ik.
Bericht door Arthur » 08 okt 2015, 16:32
Die heeft volgens mij ook een mooie E30M3. Zijn allemaal behulpzame gasten daar die meedenken. Zou zeker bellen of, als je redelijk in de buurt woont, gewoon langs gaan.
FreudeamFahren
Bericht door FreudeamFahren » 08 okt 2015, 16:34
Martijn_bmw schreef:zoek een voorbeeld auto uit 1999? die zullen vast te koop staan...
-edit-
Ja maar in 1999 zat er een S50B32 in de M Coupe, geen S54B32. Ik ben bang dat TÜV of Lelystad onvermijdelijk is: in '99 is er nooit een Z3 met S54 blok geleverd. Het S54 blok bestond toen alleen nog op de tekentafel...
Bericht door Martijn_bmw » 08 okt 2015, 16:45
dat is idd een probleem... tenzij de RDW medewerker niet slim genoeg is om te zien dat het een S54 blok is.
opzich voor je kenteken boeit het niet inhoud komt overeen en die paar PK verschil is ook niet spannend.
(als ze dan S50 info overnemen op je nieuwe kenteken)
Bericht door matthyssie » 08 okt 2015, 16:46
S50B32 en S54B32 hebben toch echt een andere cilinderinhoud..
e30touring1990
Bericht door e30touring1990 » 08 okt 2015, 16:55
S54 is idd nooit geleverd in bouwjaar '99. Mijn gedachtegang was dat een z3m uit '99 en uit '01 dezelfde carrosserie en ophanging etc heeft en er dus geen verstevigingen oid zijn aangebracht tussen die modeljaren. Met deze gedachte moet het (lijkt mij dan, maar RDW dus niet) geen probleem zijn om dit door te voeren aangezien het een bekende combi van carrosserie en motor is.
Riceaux
Bericht door Riceaux » 08 okt 2015, 16:56
Arthur schreef:Die heeft volgens mij ook een mooie E30M3. Zijn allemaal behulpzame gasten daar die meedenken. Zou zeker bellen of, als je redelijk in de buurt woont, gewoon langs gaan.
En een Ferrari F360 :tooth: Werkt bij BMW Dusseldorp.
FreudeamFahren
Bericht door FreudeamFahren » 08 okt 2015, 19:14
e30touring1990 schreef:S54 is idd nooit geleverd in bouwjaar '99. Mijn gedachtegang was dat een z3m uit '99 en uit '01 dezelfde carrosserie en ophanging etc heeft en er dus geen verstevigingen oid zijn aangebracht tussen die modeljaren. Met deze gedachte moet het (lijkt mij dan, maar RDW dus niet) geen probleem zijn om dit door te voeren aangezien het een bekende combi van carrosserie en motor is.
Dat er geen verschil is zou een aanname zijn van de RDW: ze hebben immers geen papierwerk die dat bevestigt. De motor is in hetzelfde generieke type geleverd maar nooit in het specifieke bouwjaar. Met een basis Z3 uit '01 of '02 was je slagingskans aanzienlijk royaler geweest. Maar ja, aan die constatering heb je geen zak.
Lang verhaal kort: met stille uitlaat en getrokken beurs richting Lelystad, en klaar.
Bericht door Fabian » 08 okt 2015, 19:17
What he says indeed!
e30touring1990
Bericht door e30touring1990 » 08 okt 2015, 19:55
Ik begin er steeds meer voor te vrezen dat je gelijk hebt FaF.
Ben er mee bezig en zit ook nog af te wegen over het export en herinport verhaal en dus de Tuv keuring mee de grens over te nemen. Is er iemand hier die daar ervaring mee heeft?
Wat betreft Lelystad. Ik rij nu rond met een eisenmann en ik heb geen idee of die voldoet aan de DB norm :tooth:
Bericht door Tim N » 09 okt 2015, 15:51
Met eisenmann zou ik de moeite van het heenrijden niet eens nemen ;-P
Bericht door GTRene » 09 okt 2015, 16:02
dat lijkt idd als vragen om, beter een relatief stille uitlaat eronder zetten, desnoods alleen voor type keuring.
Gebruikers op dit forum: Baidu [Spider], beske, Bombadil, Majestic-12 [Bot] en 19 gasten
