UK porno, made in England Engelse sportwagens
Re: UK porno, made in England, Brits, Engelse
Bericht door GTRene » 10 aug 2012, 12:26
Bericht door GTRene » 11 aug 2012, 00:16
:kikker:
Bericht door GTRene » 13 aug 2012, 17:00
aparte opbouw...
je zou die maar moeten poetsen :gek:
daar is het kerk-orgel verstopt :D
http://www.hotrod.com/featuredvehicles/ ... aguar_xke/
Bericht door Joy » 13 aug 2012, 17:18
Vet ding zeg. I like!
Bericht door Tim N » 13 aug 2012, 18:07
Me wants!!
AlexMK4
Bericht door AlexMK4 » 13 aug 2012, 18:37
GTRene schreef: Afbeelding
Is het iemand wel eens opgevallen dat zo'n F1 dezelfde achterlichtunits heeft als op de gemiddelde vrachtwagentrailer?
Bericht door dvh » 13 aug 2012, 18:41
GTRene schreef:Afbeelding
aparte opbouw...
:hot: :gek:
Bericht door GTRene » 14 aug 2012, 16:36
ook grappig en uniek deze Gilbern T11, destijds voor een show gebouwd.
Designed by British designer Trevor Fiore, the T11 was built in 1970, and was due to show at the 1971 Geneva Motor Show. The company recalled the project, however. The one example produced was restored and completed recently.[when
hier meer de "gewone" Gilbern Invader...
wellicht ook een leuke klassieker...immers kunstof body, wel een stalen buizenchassis, dus daar opletten met de roestduivel :D
ff van Wiki geplukt.
The final car was the Invader, introduced in July 1969[8] and based on the Genie but with improved chassis and larger brakes. The front suspension now came from the MGC and the chassis was strengthened. It took the brand further up- market with fittings such as electric windows and walnut-veneered dashboard. The Invader was available as a complete car and from 1970 an estate version was also produced. Automatic or manual transmission with overdrive were available. It was updated to the Mk II version in 1971.
Launched in September 1972,[9] the Mk III version had a Ford Cortina front suspension and was restyled front and rear. The engine was the higher tune unit from the Ford Capri 3000GT. The body was produced using new moulds and was both wider and lower than that of the earlier Invader.[9] Track was extended by four inches (10 cm).[9] The wider axle led to wheel spats being added to the sides of the car. At the back the live rear axle was located by trailing links and a Panhard rod: adjustable shock absorbers were fitted all round.[9]
It was only available as a factory-built car and cost £2693 in 1972
mk3
Bericht door GTRene » 19 aug 2012, 15:02
ook leuk deze 1975 Jaguar XJ12C ” Big Cat ” by Broadspeed
Bericht door smiley » 19 aug 2012, 15:55
Bericht door GTRene » 19 aug 2012, 16:21
lol, ja dat is'm :D
Bericht door GTRene » 23 aug 2012, 13:55
1995 Marcos LM600 ” Road Car
Bericht door GTRene » 24 aug 2012, 00:22
zoooo mooi :kikker:
de prachtige Chevron B8 modellen
Dennis Cavallino
Bericht door Dennis Cavallino » 24 aug 2012, 13:09
Bericht door GTRene » 25 aug 2012, 21:17
en wat te denken van Elva, wat een prachtige GT 160 :df:
Bericht door GTRene » 25 aug 2012, 21:22
Bericht door GTRene » 26 aug 2012, 19:06
kiek dit dahn...
1966 Vauxhall XVR
Vauxhall XVR
Bericht door GTRene » 26 aug 2012, 19:11
dat ding bestaat schijnbaar nog steeds, zie>>
Bericht door ErikS » 27 aug 2012, 09:06
Verkapte C3 stingray zeg.... :tooth:
Bericht door GTRene » 27 aug 2012, 10:35
lol, ja en deze heeft de split-window voor :D
wel een erg fraai ding helemaal voor die tijd vind ik.
zie ook die smalle achterverlichting...beetje ala ledlight strip :D
jaydee
Bericht door jaydee » 27 aug 2012, 12:55
Er zit behoorlijk wat GM in, ja :) Ik zie ook veel overeenkomsten met de Chevrolet Cheetah en natuurlijk de Opel GT.
Bijzondere vondst, die vleugeldeuren met voor- en zijruit uit een stuk.
Bericht door GTRene » 27 aug 2012, 13:15
inderdaad apart en gaaf, zal wel een kunstof body zijn.
ik zat me al af te vragen waar de motor zit immers zo laag van voor doch geen of weinig ruimte achter...
anyways...voor die oranje stond een bord, ff uitvergroot>>
zijn er dus 3 van gemaakt, leuke foto waar ze op staan>>
schijnbaar kan de kap toch los voor, vroeg me al af hoe dat werkte...zal daar de motor wel zitten.
Bericht door GTRene » 01 sep 2012, 14:37
prachtig spul :df:
Bericht door GTRene » 19 sep 2012, 00:36
deze is gaaf, ongelofelijk hoe snel die afschiet daar :shock:
Lotus Elan coupe. 1600cc maar weegt niet veel.
Bericht door GTRene » 18 okt 2012, 12:13
prachtige AC Ace bristol zagato
Gebruikers op dit forum: EvdP, TLRS en 38 gasten
