9ff tiger 1200pk
9ff tiger 1200pk
Bericht door GTRene » 30 nov 2010, 11:56
9ff heeft ook weer wat leuks...
1200pk alleen op de achterwielen :mrgreen:
hoe dat rijd?
0 naar 300km/u in bv 14.1sec :shocking:
top? 414km/u is al gehaald schijnbaar....
lekker rustige video...tot 50sec...then all hell brakes loose.
ow, hij staat ook te koop :D
http://suchen.mobile.de/fahrzeuge/showD ... abNumber=1" onclick="window.open(this.href);return false;
You are looking for an Insane car? Stop searching !
The facts:
- 9ff 1200 HP Engine with 1100 Nm torque
- 9ff GTurbo Gearbox
- Shifter “Race”
- 9ff Driveshafts
- 9ff Light weight windows
- 9ff Front Fernder Carbon Air Outtake
- 9ff Carbon doors
- 9ff Carbon front bonnet
- 9ff Carbon rear wing
- 9ff Body-Kit “Aero”
- 9ff 400 Km/h Speedometer
- 9ff Suspension.....for all informations contact our 9ff team
Need Emotions ? Take a look at
http://www.youtube.com/watch?v=pwFm9MOR-jM" onclick="window.open(this.href);return false;
In case you´ll have any questions do not hesitate to contact us !
Special thanks to Fred L. and the Team of Option Auto
9ff GTurbo 1200 / Live auf der Motor Show Essen
Überwältigende Leistung zu einem unglaublichen Messepreis !!!
leuk speelgoed :df:
Re: 9ff tiger 1200pk
Bericht door GTRene » 30 nov 2010, 12:09
in detail>
The Performance
HP/KW 1200/881
Torque 1100 Nm
Acceleration
0-100 in 2,8 sec.
0-200 in 7,1 sec.
0-300 in 14,1 sec.
V-Max 414 Km/h
9ff TR-1200 engine consists of
• 9ff doweled engine block
• 9ff extra strong engine bolts
• 9ff turbochargers F1200
• 9ff pistons
• 9ff cylinders
• 9ff cubic capacity increase to 9ff´s 4 Liter
• 9ff titanium connecting rods
• 9ff fine balanced crankshaft
• 9ff cylinder heads including bigger valves and ports
• 9ff camshaft cases
• 9ff valve springs
• 9ff camshafts
• 9ff intake manifold
• 9ff throttle
• 9ff fuel system
• 9ff exhaust manifolds
• 9ff Titanium sport exhaust system (Switchable - for quiet and sport sound management)
• 9ff 100 cell sport metal catalytic converter
• 9ff sport clutch (comfort like original clutch)
• 9ff boost cooling system
• 9ff high pressure water injection system
• 9ff air intake system
• 9ff ECU
• 9ff intercoolers 130 mm
9ff GTurbo Gearbox
• Gearbox reinforcement
• Stronger gear wheels
• Transmission setup of 5th gear to 300 km/h for best acceleration to 300
• Transmission setup of 6th gear 400 km/h
• gearbox oil cooling system
• 9ff gearbox oil
Price 5th / 6th gear 5.980,- Euro
Price Oil cooling System 2.980,- Euro
Shifter "Race"
• 9ff gear shifting gate
9ff Suspension
• 9ff Full adjustable suspension
• Uniball bearings
• 9ff Lifter at the front axle
• Adjustable stabilizing bars at front and rear axle
9ff Driveshafts
• 9ff drive shafts for high performance cars
• Special manufactured steel
• best durability under full load
9ff light weight windows
• light weight rear window
• light weight rear side windows
• light weight carbon
• reduces the Air pressure inside the fender
• usefull for high speed rides
9ff Carbon doors
• light weight carbon fiber doors
• makrolon windows
• saves up to 80% weight in relation to original doors
• light weight carbon bonnet
• matches to original fixing points
• light weight carbon fiber wing
• Aerodynamic setup for well balanced downforce
• 400 km/h approved
9ff Body-Kit "Aero"
Consists of:
• 9ff Front Bumper
• 9ff Side Skirts
• 9ff Rear Bumper
For a better downforce and a increased of the dynamic stability
9ff 400 Km/h Speedomter
• 9ff Speedometer with 400 km/h scale
• Variable colours and scales available
• Boost gauge display included
Brakes
• 9ff ABS for 430 km/h
• Brake Pads "Green"
Wheels
• 9.5 x 19 " with Dunlop Sport Maxx 265/ 35 ZR 19 in the Front
• 12 x 20" with Dunlop Sport Maxx 325/ 30 ZR 20" in the back
• Rear Wheels covered with Aluminum Plate for high Speed turns
The story behind the 9ff GTurbo
The concept of these cars follows the requirements of motor sport.
The requirements and expectations of a tuner are accordingly high. 9ff has accepted this
challenge and put a Bi-Turbo conversion to the engine.
The result is a maximum power from up to 1200HP.
Only the highest-quality materials are used.
For example titanium connecting rods and extra strong forged pistons.
However, only many years of experience and the competence of 9ff in the areas of
development, construction and set-up of high-end engines make this engine power
possible.
As a result 9ff offers the following conversions:
9ff GTurbo750: 750HP / 850 NM torque
9ff GTurbo850: 850HP / 910 NM torque
9ff GTurbo1000: 1000HP / 940 NM torque
9ff GTurbo1200: 1200 HP / 1050 N torque
Bericht door Tom » 30 nov 2010, 12:11
Niet onder de indruk.
Is er geen tuner die hier nog iets van kan maken?
Bericht door MartijnGizmo » 30 nov 2010, 12:16
Gaaf detail, die turbodrukmeter in plaats van die domme stopwatch op het dashboard! :D
Bericht door romo » 30 nov 2010, 12:38
0-200 onder de 7 sec...........met de S1000RR.............. :mrgreen:
Ik niet nee................. :mrgreen:
Anyway; impressive specs.............
Bericht door Rupie » 30 nov 2010, 21:05
Heel gaaf. Filmpje geeft wel een aardige indruk :popcorn:
7,1 naar de 200 :drinking:
RudolfNW
Bericht door RudolfNW » 30 nov 2010, 22:39
Mooi, dit liever dan een Veyron!
911-lover
Bericht door 911-lover » 30 nov 2010, 23:34
Ben ik de eerste maal tegengekomen in dinslaken op 1 mei dit jaar .
Heb ze ook mogen horen en zien rijden .
Adembenemend .
Een tweetal weken geleden stond deze in Dortmund en nu in Essen .
Dinslaken :
Dortmund:
Essen:
Bericht door GTRene » 30 nov 2010, 23:42
die druk wat uit de uitlaten komt zal ook wel wat als een straal aandrijving werken zoveel lucht komt er uit volle pijp. :mrgreen:
Paul
Bericht door Paul » 01 dec 2010, 05:59
Lul moet zijn lampen af laten stellen ;)
Bericht door Robin » 01 dec 2010, 10:05
Kost zo'n ding in D normaal 339.000 euro en Messepreis 219000?
G*dverd*mme :evil:
Paul
Bericht door Paul » 01 dec 2010, 14:35
Robin schreef:Kost zo'n ding in D normaal 339.000 euro en Messepreis 219000?
G*dverd*mme :evil:
Robin je moet eens gaan kijken daaro, ze hebben echt hele mooie aanbiedingen soms op de beursautos, vaak voor de prijs voor een standaard model een compleet met dure set wielen,onderstel en wat mooie goodies etc..
Bericht door Robin » 01 dec 2010, 14:37
G*dverd*mme :evil:
Paul ik hoef zo'n ding niet maar voor 219000 een 1200pk 997 turbo. Man in NL zou ie nieuw 7 ton + doen denk ik BPM belasting kennende.
Noem mij karren in NL van 220.000 of erger 340.000 en vertel me hun prestaties en motortype. Da's dan toch 3x niks wat je hier krijgt voor je geld man..... :(
maarten22
Auto: Porsche 911 964 C2
Bericht door maarten22 » 01 dec 2010, 15:47
Wat heeft hij voor dingen op zijn velgen zitten?
Bericht door MartijnGizmo » 01 dec 2010, 16:16
Van die dichte aerodynamische platen...
Mark N
Bericht door Mark N » 01 dec 2010, 16:30
220K is toch wel het koopje van de week voor zo'n ding, geweldig!
Bericht door romo » 01 dec 2010, 19:51
Ja..................na elke keer even gas geven direct tanken....................dan ben je snel klaar................ :mrgreen:
Erik K.
Bericht door Erik K. » 26 dec 2010, 15:16
Bericht door romo » 26 dec 2010, 15:47
Koop toch gelijk een straaljager.................. :mrgreen:
Bericht door GTRene » 26 dec 2010, 15:49
pfff als ie 1x het gas vol inploft, gaat ie als een raket :mrgreen:
Ravin ///M
Bericht door Ravin ///M » 26 dec 2010, 19:01
Holy crap, welke banden houden dat geweld bij?
911-lover
Bericht door 911-lover » 26 dec 2010, 22:47
Brrrr , kippenvel .
Dat is beter dan Viagra
911-lover
Bericht door 911-lover » 26 dec 2010, 23:06
Dit is ook leuk spul van hun
Gijs.
Bericht door Gijs. » 26 dec 2010, 23:20
Bizar speelgoed!
Bericht door GTRene » 26 dec 2010, 23:50
en ze bouwen gewoon heel rustig op met gas geven :mrgreen:
wat zal er op zo'n auto, verschrikkelijke krachten
op los gegooid worden...niet alleen de aandrijving e.d. maar bij die snelheden de luchtbarriere die wil alles eraf rippen en overal onder komen.
de luchtgeleiding zal erg belangrijk zijn...de motor voor met grote luchthapper en gril zou niet verstandig zijn, wat dat betrefd denk goed de motor achter te hebben :mrgreen:
Gebruikers op dit forum: TLRS en 49 gasten
