Project AE86.
Re: Project AE86.
Bericht door Macboy » 07 jul 2012, 12:18
Wat een project man Rambo !
Aram
Locatie: n ʞuɐp 'ʞnɹʞ uɾıɯ do ƃnɹǝʇ uǝʌǝ uɐp ǝɯ ʇǝz 'uǝzǝl ʇunʞ ʇıp ǝɾ slɐ
Re: Project AE86.
Bericht door Aram » 12 aug 2012, 17:50
Lets bring you guys up to speed on this.
Much to show so let's begin, part 1 of 4.
Needed to make some brackets for the rubbers, so I fired up Inventor:
Then a paper tester:
And then the real thing:
I always liked the ovalbox/round tip mufflers, so I needed a nice round tip:
Test:
And welded:
With attachements for the rubbers:
I also made a M18x1.5 bung for the o2 sensor on the lathe and milling machine, forgot to take pictures.
But here it is my home made exhaust, I am quite satisfied actually! :-D (crappy pic though)
Aram
Re: Project AE86.
Bericht door Aram » 12 aug 2012, 18:22
Part 2 of 4,
And 2 pics of it under the car, I didn't take any pics of the final version hence the load lashing strap around the trunk. :-)
After the brake master cilinder revision disaster I decided to buy a new one, Supra mk3:
With brake new lines:
Final touches to the fuel system, fixed up the the fuel pressure meter.
Made a stainless bracket:
Attached the last hose aswell:
And we have pressure!!
Aram
Re: Project AE86.
Bericht door Aram » 12 aug 2012, 18:34
Part 3 of 4:
Hooked up the battery, used some nice connectors:
Then I was told I needed to have the original water temp sensor for the dash in the system somewhere...
Well I decided the neatest place was near the temp sensor for the ECU.
So I made a bung on the lathe:
Milled a bit:
Fits like a glove:
Welded:
Grinded:
Like it has always been there:
Aram
Re: Project AE86.
Bericht door Aram » 12 aug 2012, 18:47
Part 4 of 4:
I needed to make a t-piece for the coolant reservoir in the system.
Back to the machines!
I used a piece of 60mm round aluminium.
And that made it time for a big step in the project, it was ready to get her engine wired up!
I have a deal with the guy from who I bought the engine that he would wire it up so I had to transport it across the country (not a big deal in Holland).
And there she is now, until the engine is running, hopefully it won't take to long.....
Next update will be when it is runniog probably. ;-)
Re: Project AE86.
Bericht door GTRene » 12 aug 2012, 18:51
strak werk Aram, gaaf die zelf gemaakte onderdelen :wave:
InjectTheVenom
Re: Project AE86.
Bericht door InjectTheVenom » 12 aug 2012, 18:55
Wat een werk weer, ik zou flink zenuwachtig worden bij zo'n belangrijke stap als deze. De kleur van de aansluitnippels op de slang om de inlaat heen vind ik een beetje storen tegenover de rest evenals de bracket aan de veertoren maar het ziet er verder netjes uit :thumbup:
Re: Project AE86.
Bericht door Joy » 12 aug 2012, 19:00
Heel mooi hoe je zelf die onderdelen maakt en tot één geheel last. Petje af :thumbup:
Re: Project AE86.
Bericht door Niels » 12 aug 2012, 22:00
F#ck wat mooi :D
Re: Project AE86.
Bericht door MartijnGizmo » 12 aug 2012, 22:53
Schitterend, wát een fraai handwerk zeg! :thumbup:
Re: Project AE86.
Bericht door Martijn M » 13 aug 2012, 00:15
Zo bruut! Echt respect voor al het werk dat je erin steekt. Hats off to you sir!
Jeroen K.
Re: Project AE86.
Bericht door Jeroen K. » 13 aug 2012, 00:39
het is absoluut geen auto die ik mooi vind, maar godskolere wat een werk maak je er van! en ook geen compromis ergens maken of wat dan ook echt heel mooi werk! hats off! wou dat ik het kon
ErikMartijn
Re: Project AE86.
Bericht door ErikMartijn » 13 aug 2012, 02:12
Mooiste project op df en een van de mooiste op het hele internet, for that matter... prachtig! :clap:
Re: Project AE86.
Bericht door Tristan » 13 aug 2012, 09:12
:wave:
Mathieu
Re: Project AE86.
Bericht door Mathieu » 13 aug 2012, 10:43
Zo gaaf als je dat allemaal zelf kunt.
Re: Project AE86.
Bericht door Downforce Hans » 13 aug 2012, 11:06
H :thumbup: elemaal super Aram........
2000USA
Re: Project AE86.
Bericht door 2000USA » 13 aug 2012, 11:33
cARAMba, wat een werk weer! :hot:
Elke update weer een feestje, keep up the good work! :thumbup:
Stefan van Elst
Re: Project AE86.
Bericht door Stefan van Elst » 13 aug 2012, 15:17
Wat een klasse project!!
Aram
Re: Project AE86.
Bericht door Aram » 13 aug 2012, 19:37
Thanks guys! :-D
Tim R
Re: Project AE86.
Bericht door Tim R » 14 aug 2012, 10:34
Helemaal briljant Aram, niet normaal gewoon. Iedere keer als je een update plaatst geniet ik weer van de perfectie en het feit dat jij laat zien dat er voor alles een mooie custom oplossing is.
Keep up the good work!
Dennis Cavallino
Re: Project AE86.
Bericht door Dennis Cavallino » 15 aug 2012, 14:15
Je zou hier zo kunnen komen werken. Draaibanken genoeg. Mooi werk man. Deden wij hier maar wat meer met automotive...
Thommy
Re: Project AE86.
Bericht door Thommy » 31 aug 2012, 12:27
Ga zo door! Ik zie het eind resultaat graag van dit project!!
Aram
Re: Project AE86.
Bericht door Aram » 02 sep 2012, 10:50
She's running! :D
The O2 sensor was not in the exhaust when I made the video, that is why it sounds a bit course.
We put it in later and the engine was running really smooth and the exhaust note was very nice.
Only minus was a fault on the throtlle position sensor, I removed the side cap for cleaning and probably put it back on wrong, not an easy fix I fear. :(
Also I couldn't let it run long because the coolant system was fitted yet, hopefully I have things sorted by next week!
Still, I'm VERY happy. :D
Aram.
Re: Project AE86.
Bericht door Niels » 02 sep 2012, 11:23
Weer een mijlpaal Aram, gaat lekker :thumbup:
Re: Project AE86.
Bericht door GTRene » 02 sep 2012, 12:25
idd, al iets dichterbij de smaak van rijden met dat ding :df:
Gebruikers op dit forum: Baidu [Spider], beske, bleu_dust, Bokkepoot, HarryC, Mark 320iS, Semrush [Bot] en 75 gasten
