Project AE86.
Aram
Locatie: n ʞuɐp 'ʞnɹʞ uɾıɯ do ƃnɹǝʇ uǝʌǝ uɐp ǝɯ ʇǝz 'uǝzǝl ʇunʞ ʇıp ǝɾ slɐ
Re: Project AE86.
Bericht door Aram » 03 jul 2011, 15:20
Ok, had a lot of delay here.
I ordered parts which were late or wrong.
And I was busy with other stuff.
Anyway, have done a few things though.
Made a start with the bucket seat, but I had no idea it was going to be such a pita!!
The ae86 is not really made for one I must conclude.
I tried to make it work with a slide but it was way to high.
Started out with reworking the Impreza frame, so I took it apart:
But it was still too high in the end, so I ditched those.
Then I cut off the side frames on the chair a bit and constructed a new frame for them:
Welded and sandblasted:
Had to remove some material from the side frame:
Now it's fixed, but the height of the chair is now as high as the stadard chair...
And this is just one side! Pffft...
Metchu
Re: Project AE86.
Bericht door Metchu » 03 jul 2011, 15:24
details details details... wat een werk ouwe!
Aram
Re: Project AE86.
Bericht door Aram » 03 jul 2011, 15:33
Ik word er soms wel wat moe van kerel. ;-)
Had some plates lasered for the front subframe, I have lowered the subframe 5mm only, the engine mount plates are 5mm also.
Now the engine has the perfect height I think:
Then another big job, the gearbox subframe.
I want it to look as something that came out of the factory in end, so I did it the hard way.
I started with cutting up the original frame and reworking the parts I needed:
Welded:
And this for both sides.
After that the middle part was to be made, so I started with a cardboard template:
Then the real thing:
And welded that up too:
Now only the 4 corner parts need to be filled up.
Aram
Re: Project AE86.
Bericht door Aram » 03 jul 2011, 15:48
So, Tuesday I was really happy because for the first time the engine and gearbox were hanging in their own frames for the first time. :)
....Unitl I looked at the next step, the steering rack.
When I was test fitting it all fitted nicely, but meanwhile I had moved the engine back 8mm and it was sitting a bit lower and tilted aswell.
Never stopped to see what it did for the rack.
So now the oilpan was in the way, more specificly, a bolt of the oilpan.
To make matters more complicated I noticed the MR2 steering rack was actually 20mm's longer than the AE86 one, so the quiafe quick rack was to short also, that is why I the steering angle looked off to the left.
Luckily I noticed in time, and luckily it needed moving the steering rack, which gave me 10mm more room with engine.
So I decided the relocate the rack mount on the subframe and rework the bolt on the oilpan.
Now it fits! And I can start removing the webbing for the rack to fit properly under the engine.
Then some new parts:
A longer stabi, have not testfitted it yet:
A new feultank lid without a lock:
New feul pump holder:
Michel P
Re: Project AE86.
Bericht door Michel P » 03 jul 2011, 18:23
Geweldig Aram, diep respect voor dit geweldige project.
Michel
Re: Project AE86.
Bericht door Niels » 03 jul 2011, 22:57
Absoluut :beer:
Re: Project AE86.
Bericht door GTRene » 03 jul 2011, 23:07
mooi gek Aram :D
wel gaaf om te zien wta je er van bakt, respect :foto:
Aram
Re: Project AE86.
Bericht door Aram » 04 jul 2011, 19:58
Dank heren. :)
I mounted the new stabi to see how it fits, and it looks great!
Re: Project AE86.
Bericht door GTRene » 04 jul 2011, 20:04
pas wel op met zo'n stabie...als je de auto opkrikt komt ie enorm omhoog voor...(denk ik tenminste)
ik heb mijne ook zo lopen bij de Hartge en dacht huh...en net voor de radiateur langs :shocking:
omdat die op het lange rechte stuk ook niet verbonden is met de carros net als die.
Nutkees
Auto: Dodge Viper
Re: Project AE86.
Bericht door Nutkees » 05 jul 2011, 15:02
@Aram,
Diep respect voor al het werk wat je erin stopt, maar hoe lang ga je nog bezig zijn? Zolang ik je ken ben je altijd bezig geweest met opknappen van je impreza, nu de AE86.. Word het niet snel tijd dat je weer eens gaat rijden?
:kikker:
Aram
Re: Project AE86.
Bericht door Aram » 06 jul 2011, 00:43
Ik wil ook wel weer is rijden, ik maak er dit jaar nog 1 af. ;)
Today I cleared the way for the steering rack.
It was alot of grinding, but it turned out ok.
Now I can weld up the subframe. :)
Re: Project AE86.
Bericht door indobesar » 06 jul 2011, 15:30
Aram, wat een vakmanschap! Diep respect.
:thumbup:
G Kolkman
Re: Project AE86.
Bericht door G Kolkman » 06 jul 2011, 19:11
Ga je dat nog weer dicht proberen te maken of denk je dat je hier mee weg gaat komen (je hapt toch een stukje uit de constructie zeg maar)?
Aram
Re: Project AE86.
Bericht door Aram » 08 jul 2011, 19:34
Thanks Indo. :)
@G,
Ik ga dat wel dichtmaken, er komt zo vuil bij de koppeling.
Ik zit alleen nog te prakizeren wat de mooiste oplossing is.
Re: Project AE86.
Bericht door GTRene » 08 jul 2011, 19:55
ik vond dit wel lache met die smilies :D
Tim R
Re: Project AE86.
Bericht door Tim R » 11 jul 2011, 14:29
Aram, ik kan begrijpen dat je er af en toe moe van wordt (ik ben met een vergelijkbaar monsterproject bezig) maar wat wordt het gaaf zeg. Echt alles tot in de puntjes gefabriceerd. Helemaal geweldig gewoon.
Joopieboy
Re: Project AE86.
Bericht door Joopieboy » 16 jul 2011, 18:27
Wat een werk zeg, alles tot in de puntjes afmaken. Keurig zeg, complimenten! :D
Stefan van Elst
Re: Project AE86.
Bericht door Stefan van Elst » 16 jul 2011, 18:42
Komt er nog een Quaife 2.5 ratio steering rack in?
Ik heb er 1 in de AW11 zitten; 1 van de beste upgrades die ik gedaan heb!
Peric
Re: Project AE86.
Bericht door Peric » 17 jul 2011, 12:42
Aram schreef:Thanks Indo. :)
@G,
Je kunt toch een plaatje aluminium op maat maken en draad tappen in de bak. Zo te zien genoeg vlees voor..
Sleufje in de bak frezen waar het plaatje dan invalt, anders komt er toch nog vuil langs..
Aram
Re: Project AE86.
Bericht door Aram » 17 jul 2011, 20:55
Stefan van Elst schreef:Komt er nog een Quaife 2.5 ratio steering rack in?
http://www.driving-fun.com/forum/viewto ... 68#p686268 :)
Peric schreef: Je kunt toch een plaatje aluminium op maat maken en draad tappen in de bak. Zo te zien genoeg vlees voor..
Er is maar 4 a 5 mm ruimte tussen het stuurhuis en de motor, als je daar een plaatje tussen stopt word het te krap.
Ik denk dat ik een paar stukjes kunstof op maat maak in de gaten en die vastzet.
Stefan van Elst
Re: Project AE86.
Bericht door Stefan van Elst » 17 jul 2011, 21:37
LOL, ik viel in herhaling, sorry.
Was het alweer vergeten :)
Aram
Re: Project AE86.
Bericht door Aram » 31 jul 2011, 17:41
Ok, had lots of work to do so not to much time for the toyo.
But i managed to finish the front subframe and do some work on the gearbox frame.
Before:
And finished:
Gearbox frame before:
Now but still not finished:
Re: Project AE86.
Bericht door Niels » 31 jul 2011, 18:33
Netjes! :D
Tommy
Re: Project AE86.
Bericht door Tommy » 31 jul 2011, 19:20
Wanneer gaan we starten? :-)
Aram
Re: Project AE86.
Bericht door Aram » 21 aug 2011, 18:11
Nog even niet starten ben ik bang. :P
Ondertussen...
Made my own battleversion...ehh version. :)
Because I have no idea how much stress is going to be on it I went for 2767 tool steel, should be strong enough.
Lathe:
Test:
Milling:
Done:
Test:
Got the tap Friday, so it will be finished monday.
Then, the engine and box go in the car for the first time!!
Off course a new hole had to be cut in the tunnel, making an entry for the gearlever.
Can cost you your wrists these drills:
Still, not so bad:
Presto!
I drilled the spotwelds and massaged the brace back a bit, I really didn't want to cut it.
But it turned out nice I think:
And here it sits in the car on it's own:
I pulled it out again and started disassembling the auxilaries for cleaning.
Next time the engine goes in, it stays in.
Gebruikers op dit forum: bleu_dust, ED35, Majestic-12 [Bot], Redis, Robbert92, Ti-Tourist (Erik) en 15 gasten
