PPP - Pure Porsche Porno
ErikMartijn
Re: PPP - Pure Porsche Porno
Bericht door ErikMartijn » 27 nov 2010, 23:42
Mark Nauta schreef:Die grijze NL GT3 RS is van een Nederlandse Porsche verzamelaarSTer.
Die ook in de Carros Porsche special stond? Die had wel meer leuke modelletjes in in ieder geval...
En op latere leeftijd was ze pas geïnteresseerd geraakt in auto's, beetje een midlifecrisis-effect op een goede manier. :D
FreudeamFahren
Bericht door FreudeamFahren » 29 nov 2010, 20:01
Kom ik weer met die ouwe meuk :angel: Wát een project! Vooral het onderstel is een huzarenstukje, inclusief ombouw naar schroefveerpoten... Überfap! :love: :love: :love:
1970 Porsche 911 RSR look FOR SALE
$68,000.00
Well sorted and cared for with roughly 3,000 miles since build completion 2 years ago, never tracked, only spirited driven a handful of times.
Lots of new and refurbished parts - $50K plus in parts alone. Below is a description and pictures of the work performed.
BODY/CHASIS
1970 911T rust-free factory non-sunroof
Completely stripped and epoxy coated
Butt-welded 930 9" and 11" steel flares
New front suspension pan with modification for large front cooler
RSR style rear shock tower reinforcement
Fiberglass duck-tail, hood, rsr front/rear bumper and carbon fiber splitter
Galvanized doors with power windows
Custom strut x-cross member
Custom center-fill gas tank
Battery boxes removed
Filled in mirror holes, antenna, gas flap and vents inside trunk
New Pilkington windshield, windows and rear glass with OEM green tint
Titanium silver paint
ENGINE/TRANSMISSION
3.2 with top-end rebuild, all new headstuds, rings, exhaust valves, head-work, etc
New 11 blade fan with single pulley
New engine fuel lines
New spark plug wires and injectors
New bosch speed/reference sensor and head-temp sensor
SSI heat exchanger with O2 sensor
M&K generation 4 sport muffler
Large front setrab oil cooler with stainless steel braided lines
Lightweight starter
K&N air filter kit
Performance DME chip
Operational backdated heat
Late model (1985) 915 transmission
New sachs clutch kit
New clutch cable
Precision shift joint (911 psj)
915 wevo shifter with standard length
New engine and transmission mounts
WHEELS/SUSPENSION/BRAKES
17x9 and 17x11 fuch insert Lindsey wheels with new Goodyear F1 eagle tires
Coil-over bilstein shocks/springs front and rear - raised/gusseted spindles
Late style (with bolt on sway bar mounts) aluminum rear control arms
Early style A-arms (with through the body sway bar mounts)
Spring plates with new rubber bushings
Elephant Racing weather sealed rear monoballs
Wevo rear swaybar mounts
Tarret Engineering front and rear swaybars
Loembofer turbo tie-rods
A-arm polibronze bearings
New hard and braided steel brake lines
New 930 cv axles
Aluminum cross-member and late model steering rack
Elephant Racing camber plates, adjustable bump steer kit
New Ball joints
Polibronze control A-arm bearings
993 calipers front/rear
930 front hubs
930 rotors front/rear
23mm master cylinder
INTERIOR
Scheel seats with 4 point Schroth harness and OEM 3 point seatbelts
Momo prototipo steering wheel
Removable custom roll-bar
RS Carpet kit and door panels
Refurbished pedal cluster
Back-seat delete
Fire-extinguisher
New black headliner
Rennline pedal set with dead-pedal, aluminum dash cover, foot-boards
All new seals, windows, doors, hood, bumpers, cowls, lights, etc
Late model gauge cluster
MISCELLANEOUS
Alarm system
Odyssey PC680 battery with rennline battery tray
New h3 headlights
Late model electrical system
Custom front/rear tow hitch
New engine sound pad
Corner balanced and aligned
Wheel caps and torsion bar covers
Custom front undercarriage protection bar
Sound deadener and carpet jute
Powdercoated many parts
Rennline aluminum fan strap
Aluminum smugglers box cover
New orange-bar hood emblem
Single mirror (driver-side)
New European lenses front/rear
Currently registered in California, clean title in hand
Mathieu
Bericht door Mathieu » 29 nov 2010, 20:12
:love:
Niels v/d burgh
Auto: Zweedse diesel
Bericht door Niels v/d burgh » 29 nov 2010, 20:16
Dan maar ouwe meuk :thumbup: :love: :thumbup: :love:
Bericht door GTRene » 29 nov 2010, 20:30
heerlijk die ouwe meuk, er nog als een kwiek groentje uit ziende :df:
911-lover
Bericht door 911-lover » 29 nov 2010, 22:27
WOOOOOOOOOW :shock: :love: :love: :love:
Bericht door Joop » 30 nov 2010, 00:21
Niels v/d burgh schreef:Dan maar ouwe meuk :thumbup: :love: :thumbup: :love:
Dat blijft toch altijd schitterend.... :clap:
Bericht door Tristan » 30 nov 2010, 09:12
:shock:
Lijkt een beetje op de gifkikker van Chris Harris.
Bericht door Macboy » 30 nov 2010, 13:00
Niet normaal !!! Alleen die stoelen en stuur hadden anders gemoeten (als bij AP design)
Bericht door Tristan » 30 nov 2010, 13:03
Macboy schreef:Niet normaal !!! Alleen die stoelen en stuur hadden anders gemoeten (als bij AP design)
Ben je helemaal gek! Dit hoor bij de tijdsgeest van de auto. Dan ga het retro vern*uken door er een modern stuur en stoelen in te zetten. :hammer:
Bericht door Xave30 » 30 nov 2010, 13:07
Tastefully executed. 8)
FreudeamFahren
Bericht door FreudeamFahren » 01 dec 2010, 20:21
Hot or not?
Bericht door Rupie » 01 dec 2010, 22:52
Tja die koplampen hè..
Als je die wegdenkt hot...
Bericht door Xave30 » 01 dec 2010, 22:55
I'll take a NOT.
SteV6
Bericht door SteV6 » 01 dec 2010, 23:03
NOT, om 2 redenen:
1. Auto staat te laag (zoals veel Porkers hier in dit draadje)
2. Uitlaat hangt scheef :bag:
(En waarom zit dat leer zo los op de stoelwang?)
Bericht door Tim N » 02 dec 2010, 14:32
1= onzin
rest +1 :wink:
911-lover
Bericht door 911-lover » 02 dec 2010, 16:23
De über 911
Bericht door GTRene » 02 dec 2010, 16:50
I want it badly :mrgreen: :df:
ik zou er wel een lightweight airco in willen....rond de 10kg extra in such hot car will be no problem me thinks.
911-lover
Bericht door 911-lover » 02 dec 2010, 16:58
Anders effe onder handen laten nemen .
Dan kan er ook nog een radiootje en GPS bij :wink:
Bericht door GTRene » 02 dec 2010, 17:49
lol :mrgreen: het kan altijd gekker :wink:
FreudeamFahren
Bericht door FreudeamFahren » 02 dec 2010, 17:53
En als extra bonus schrijft hij met zo'n aftermarket opleuk setje extra hard af. Dat zou ik dus NOOIT doen. Tegen de tijd dat die paar kg voor een airco compressor opvallen in mijn rondetijden is mijn potje talent al lang en breed leeg, los van het feit dat ik nooit rondetijden meet omdat ze me niet boeien... :wink:
Niall
Bericht door Niall » 02 dec 2010, 18:31
Grappig,
Elke keer dat ik naar een leverancier in Solingen rijd kom ik bij Wimmer voorbij, staan bijna altijd dezelfde auto's buiten. Soms staat er ook een witte E30M3, maar voornamelijk VW producten.
Stievn Poal
Bericht door Stievn Poal » 02 dec 2010, 18:56
Klant van ons rijd met een stuk of wat van deze jongens:
Ben_968CS
Bericht door Ben_968CS » 02 dec 2010, 22:33
Steven Nauta schreef: deel 2:
1.31: "Mit vollen hosen ist es gut stinken." :mrgreen:
Topfilmpje, zeker met de Porker. Vent kan sturen.
Ben_968CS
Bericht door Ben_968CS » 02 dec 2010, 22:57
steve smith schreef:Welke Nederlander loost via die Albert trouwens subtiel die 964 RS CS en die 964 RS Cup?
Je bedoelt deze (van 0.05 tot 1.58 sec, vanuit mijn POV): http://www.youtube.com/user/bosmotorspo ... oulbw6d7fc" onclick="window.open(this.href);return false;
