Toyota FT-86 Concept
Joost
Re: Toyota FT-86 Concept
Bericht door Joost » 02 nov 2011, 23:42
Er zijn weer wat brochures gelekt vandaag:
TRD parts cataloge
Joost
Bericht door Joost » 02 nov 2011, 23:45
Scans from a training manual.
Power/weight:
HP: 147kw (200ps) / 200hp @7000rpm
Torque: 205nm (151 lb/ft) @ 6600rpm
Weight:
2662 ponds (1210kg) for base manual (~ 2580 lbs dry weight)
2706 pounds for higher trim manual
Columns:
First 2 column are for "small FR sport", column 1 is a higher spec model, column 2 is a lower spec model. 3rd column is Mx5/Miata, 4th is RX8 and last is CRZ. It's a comparison chart.
Top Section:
The top section is the dimension in mm, length width height wheelbase, ground clearance then number of seats. Next is weight.
Top spec manual is 1230kg, auto is 1250kg.
Low spec manual is 1210kg, auto is 1230kg.
Then its turning radius.
High spec rides on 17" wheels and low spec on 16.
Second Section:
This section is engine. Boxer 4 DOHC, 1998cc. Output as listed on 1st post above. Drinks premium unleaded and 50L fuel tank.
Fuel consumption base model:
13 km/l
30.58 mpg
49.21 kmg
Fuel consumption top model:
12.4 km/l
29.17 mpg
46.94 kmg
Third Section:
This section is front engine/rear drive, transmission type, suspension type, brake then tyre size.
High spec brakes: ventilated discs front and rear.
Low spec brakes: ventilated front, non ventilated rear.
Last Section:
Last section is equipment which is not that easy to understand. First thing I notice is top spec has LSD for manual and auto while low spec only has LSD on manual. I'll post more if I can read more.
More update:
Both spec have VSC, front passenger and front and rear curtain bags. Top spec has front LED, leather steering wheel, 6 speakers audio (low spec has 2 speakers), white rev counter with shift light and sport pedals. Top spec also has "smart entry and start".
MORE THINGS OF NOTE:
Strut front, double wishbone rear suspension
Base halogens, optional HIDs on base trim, standard HIDs on high trim
LSD on all MT cars
Stability control standard
Only 2 speaker audio on base car
High Spec:
Has "high-quality fabric" (上級ファブリック).
Option for leather heated seats with Alcantara inserts.
Steel door sill insert / scuff plate (ステンレス製ドアスカッフプレート)
Interior metallic door handle inserts
Carbon fiber center console trim
Door courtesy light
Knee pad on console
The "Customize Grade" at the bottom is interesting:
the "customize grade" bare bones model is 1190 kg !!
Unpainted bumper
16 steelies (says ornament-included, guessing it includes the logo)
plastic steering wheel
NO A/C (only a heater)
Power door locks
Sunvisor (no vanity mirror)
No speakers
the car in fact does require premium unleaded gas (無鉛プレミアム)
the rear seat is one piece and is foldable (一体可動式)
did anyone mention that the high spec model comes with a digital speedo and tachometer? (デジタルスピードメーター revメーター)
Here are translated charts (by our members Spaceywilly and dimension6!!)
Joost
Bericht door Joost » 02 nov 2011, 23:50
Kleuren:
Satin White Pearl
Sterling Silver Metallic
Dark Grey Metallic
Crystal Black Silica
Lightening Red
Orange Metallic
Galaxy Blue Silica
Bericht door Robin Hartog » 03 nov 2011, 03:55
Nice! Toerenteller in het midden, zoals het hoort. :)
VLA
Bericht door VLA » 03 nov 2011, 14:35
Ziet er toch erg strak uit... ben benieuwd of de achterlichten helemaal rood worden zoals bij de Subaru variant. Ben wel benieuwd naar de prijzen, de RX8 was vrij prijzig namelijk, maar de MX5 en zeker de CRZ vallen erg mee qua prijs.
Sperdy
Bericht door Sperdy » 20 dec 2011, 13:44
met rico eensch, het is natuurlijk die prut-kinderfilm: fastenfjoerius. maar ik kan mij ontzettend goed voorstellen dat dit een oto is voor jongeren (hoor opa praten :wheelchair: ) en dan heb je daar een ontzettend leuk hok aan. dat die maar 200 pk is? dat is geen probleem, ga ik je nu al zeggen. Een miniCooper of zo is ook maar 200+pk, zelfde doelgroep lijkt me. Maar dit is atmo rwd én goedkoper. Da's echt wat anders dan dat turbo-peusjoo blokkie in je Coopa'h. Als nou iets belangrijk is wat ik geleerd heb is dat het om de rijbeleving gaat, en absoluut niet om de peekaa's. Het gaat om een fun-drive. Dit wordt een topper en een uniek produkt voor een specifieke markt. Heel goed gedaan door die rijstekokers.
Gebruikers op dit forum: Geen geregistreerde gebruikers en 82 gasten
