Ford Focus (2018) facelift 2021 p.5
Re: Officieel: nieuwe Ford Focus (2018)
Nu ook de ST als 7 gangs automaat te verkrijgen, jammer dat de high speeds test (by experienced driver) hoofdzakelijk in 5 plaats vond.
Onlinesitechris
Die 5 is echt absurd lang. Haalt veel snelheid eruit. Toerenval is enorm groot van 4 naar 5. Topspeed is voor 280 pk dan ook niet echt indrukwekkend.
Het duurt even maar hij komt er wel( AutoTopNL filmpje)
Lange 5 inderdaad.
Ergens bij 9-10 minuten zegt hij: ...the dampers stiffen up...
Ik vond dat Nederlands klinken.
Maar een damper vs shock absorber, ze zijn uiteindelijk één en hetzelfde ding zegt deze persoon:
Lange 5 inderdaad.
Ik neem 'n koffie.Are dampers and shocks the same thing?
Yes.
If you take a coil spring and hang a weight on it, and you pull and release the weight, it will bounce up and down. The frequency will depend on the ratio of the spring stiffness and the weight.
A similar thing can happen when you drive over a bump, the tire can keep bouncing up and down for a long time. The car can also keep going up and down.
If there is a rythmic disturbance in the road, which happens often with concrete roads, the oscillations can be so violent that you can lose control.
So you need to dampen this oscillation. Damper is probably the more proper word. Maybe it’s British. But here in the USA people call them shock absorbers. They absorb the energy of the shock. Driving over a bump takes kinetic energy from the car (slows it down) and puts that energy into the up-down movement of the car. You don’t want the car to be moving up and down, hence that energy needs to be absorbed which is what a shock absorber does.
Most shocks have oil in them and small passages. Moving the vehicle up and down forces the oil through the small passages which turns the energy into heat. Shocks do actually warm up. Normally not very much , but under extreme conditions such as desert racing it can be enough to warrant a separate cooling system for the shocks.
Joris van der Veen
- Auto: Suzuki splash
Sportieve uitstraling met een stijlvolle bouw. Deze generatie is een mondiaal model, gebouwd in zowel Europa als in Azie en Verenigde Staten. Ik ben zeker benieuwd naar de rijeigenschappen, want ik overweeg om een hatchback te kopen.
Rijeigenschappen zijn in orde. Het onderstel vergt wel wat vermogen. Als je nieuw wil kopen, binnenkort komen ze met een facelift van de mk4 Focus.
Onlinesitechris
Rij-eigenschappen zijn prima. Beste in klasse. Qua interieur wel beetje mwoh, dat is keerzijde. Maar een st-line met 18 inches en ledkoplampen ziet er van buiten wel goed uit. Prijs-kwaliteit is erg goed.
Wel eens met eerder advies. De 182 pk versie wil je hebben. De 125 pk versie mist pepers en ondersrel verdient beter.
Rnd
Wat is die fake uitlaatbrom irritant zeg! Verschrikkelijk. 10 keer erger dan bij BMW. Dat zou je gewoon uit moeten kunnen zetten.
Het is alleen dat die sterkere motoren meer zuipen dan menige rockster. Is dat de betrouwbaarheid van de Ecoboost motoren dat ze zo’n slok meer lusten dan menige VAG tsi.....
- Opa
- Auto: Ford Fiesta ST
Ik vind dat wel meevallen hoor JP, in onze Fiesta ST ligt ook een 1.6l Ecoboost motor met 182 pk en gemiddeld 1 op 14 is redelijk makkelijk te doen....je moet dan natuurlijk niet op het circuit gaan rijden, of op de openbare wegconstant het onderste uit de kan willen.JP schreef: 13 feb 2021, 22:59 Het is alleen dat die sterkere motoren meer zuipen dan menige rockster. Is dat de betrouwbaarheid van de Ecoboost motoren dat ze zo’n slok meer lusten dan menige VAG tsi.....
Voordeel van onze 2016 Fiesta ST is natuurlijk wel dat ie maar 1063 kg weegt en ik weet niet wat een nieuwere Focus weegt....hoe nieuwer hoe zwaarder lijkt het wel en dat is meest ook niet bevorderlijk voor het gebruik.
Nieuwe 1.5 is geen zuinigheids wonder wat ik zoal lees.
Inderdaad, die 1.5 3 pitter doet rond de 1:12. Dat vind ik bar slecht voor 150pk.
150? 182pk bedoel je? Oh dat is de automaat... de nieuwe 8v automaat is Ford's eigen brouwsel en geeft behoorlijk wat aandrijfverlies (meer) tov bijvoorbeeld de Aisin 8v automaat die veel gekozen wordt in FWD modellen.
- Opa
Geen flauw idee wat die 3 pitters verbruiken, maar ik denk dat het in de Fiesta ST(met gewoon een handbak met 6 versnellingen) wel mee zal vallen, ik las dat ie zelfs nog een cilinder uitschakelt als je bijvoorbeeld constant 100 of 120km/h rijdt, lijkt mij dat ie dan echt zuinig loopt en die heeft dan 200pk.
Natuurlijk is die auto daar niet voor gemaakt, maar als je tegenwoordig op de snelweg komt dan is het overdag gewoon moeilijk om veel harder dan 100 km/h te rijden, dus hobbel je maar gewoon met verkeer mee en loopt je auto op dat moment heel zuinig.
Wij zijn afgelopen september nog bijna 3 weken naar Oostenrijk en Italië geweest, iets van 3500 km gereden met een gemiddeld verbruik van 1 op 15 en dan pakken wij nog zo veel mogelijk binnendoor wegen, dus minder dan de helft was op de grote weg.
Nevolution6RSII
- Auto: ex-Evo VI RS2 eigenaar :)
Wat een vreselijk lelijk interieur zeg!
Van de 20 jaar lang gebouwde Focus was er :
- Maar één model met een beetje leuk dashboard...
- Geen één zo leuk als de Escort Cosworth van vroeger!
En de dealers in de omgeving van Rotterdam bleken van de week alweer één grote ramp te zijn dus voorlopig geen Ford voor mij!
Ze hebben allemaal tegenwoordig een opgeplakte tablet. Voor mij blijft de F10/11 het mooist qua verwerken van het mediascherm.
Verder maakt een interieur mij niet zoveel uit. Je kijkt 99.9% op de weg voor je
Alle functies zoveel mogelijk bedienbaar met knoppen/schakelaars en hendels en zo min mogelijk achter een scherm zoals Tesla Volvo en nieuwste VAG producten.
Nevolution6RSII
Dat is de eerste generatie voor zover ik kan zien ?Kadett schreef: 14 feb 2021, 19:12 Ze hebben allemaal tegenwoordig een opgeplakte tablet. Voor mij blijft de F10/11 het mooist qua verwerken van het mediascherm.
Die is het lelijkst van allemaal!
Mja, voor mij is het echt een stuk autogenot!Verder maakt een interieur mij niet zoveel uit. Je kijkt 99.9% op de weg voor je![]()
De hele tijd (of in ieder geval elke keer als je instapt
Dat ben ik wel echt 110% met je eens : Opzouten met die touchscreens!Alle functies zoveel mogelijk bedienbaar met knoppen/schakelaars en hendels en zo min mogelijk achter een scherm zoals Tesla Volvo en nieuwste VAG producten.
Ik wil gewoon de verwarming/airco met draaiknoppen kunnen bedienen i.p.v. elke keer met zo'n tablet knoeien...
Re: Ford Focus (2018) facelift 2021 p.5
Nieuwe neus voor de Focus, ik zeg geslaagd.
- martn
- Auto: Ford Focus ST
Ik ben benieuwd naar die digitale interface, Ford is niet echt een ster in hele snelle functionerende software interfaces. In dit geval is het nogal belangrijk. Ik moet even wennen, maar het kon zeker slechter.
Prima idd, wel veel weg van de SEAT Leon.
DF-user-278
Idd wat Arthur zegt. Eerste wat ik dacht is, die neus lijkt best wel (veel) op die van de Leon.
- Seat-Leon-TGI-CNG-aardgas-130-pk-DSG-2021.jpg (58.48 KiB) 8267 keer bekeken
- Thomasss
- Auto: Bakfiets!
Mooi, net zo'n 24" widescreen als op kantoor!
Ik keek stiekem wat een nieuwe gefacelifte Focus ST moe(s)t gaan kosten....... € 57.150
Dat koopt toch geen hond meer ?
https://www.ford.nl/handige-links/ik-wi ... CMAA_VS-EC
Zed240
En met een paar opties ga je naar 65k voor de wagon. De ST Wagon die m'n pa had, had in 2013 een nieuwprijs van 41000 en die had op getinte ruiten na ook alle opties (bomvol!!@!11!.
+24k in 9 jaar voor een vergelijkbare auto. Pittig.
Martin*
Vanafprijs hé..met bijna alle opties ruim € 62300JP schreef: 17 mei 2022, 18:22 Ik keek stiekem wat een nieuwe gefacelifte Focus ST moe(s)t gaan kosten....... € 57.150Dat koopt toch geen hond meer ?
Kansloos in Nederland.
Ford Puma ST kost full options ruim €48000. Gaat ook nergens meer over.
In Duitsland de FoFo ST vanaf €37650, we worden genaaid of krijg je hier een warmtepomp erbij ?
Gebruikers op dit forum: ron36 en 30 gasten
