Ford Falcon ‘65 347ci stroker racecar [UPDATE]
- Martin van der Zwaard
Als het niet mag hoor ik het wel. Dan haal ik hem weer weg.
Smallblock V8 302ci stroked to 347ci balanced and blueprinted. Handgeschakelde 4-bak.
Vermogensuitdraai aanwezig. Ongeveer 425pk en 540nm op 1340kg leeggewicht.
Specs;
Oil - MOBIL 1 20W50 Synthetic
Castrol GTLMA brake fluid or equivalent
Wilwood Dynalite brake calipers front and rear - each has two bleeders
22 gallon fuel cell
Timing 36-38 deg. btdc
Valve lash - intake .018 - exhaust .020
Eagle 4340 Steel Crank/4340 Steal H Beam Connecting Rods 5.4" length
JE Pistons - 4.030 bore
Comp Camps and Lifters 248 degrees, 254 degrees
Manley severe duty valves
APR studs
Canton Oil Pan and pickup
CV products pushrods 6.850 length
Melling oil pump
Ford Motorsport internal balance harmonic dampener
AMB transponder built in
Electric cooling fan
This well-known 1965 Ford Falcon Sprint that has been set up as a race car for many decades. A rare car in and of itself (one of just 2.806 produced), it has been prepared and improved upon since the 1960's and currently sports a fresh 302 cubic-inch V8 (stroked to 347 cubic-inches, balanced and blueprinted) with all new internals built by a Wood Brothers NASCAR engine specialist in North Carolina. The engine is also fitted with a complete MSD ingnition system and an oversized custom NASCAR aluminum radiator.
This fantastic powerplant is backed up by the indestructible T-10 toploader 4-speed manual transmission and similary heavy-duty custom Ford 9" rear end with Moser axles. The engine has run only a few break-in events since that time and the rest of the driveline is competition ready including disc brakes at all four corners with Wiwood Dynalite calipers and close-ratio rack & pinion steering. Notably, quite a bit of work was done to the car just before being put up, incluidng a partial front-end rebuild.
The car rides on competition rubber mounted to Basset stock car 8x15" rims. Safety equipment includes a set of certified harnesses, a fresh fire system, 22 gallon R.J.S. fuel cell and a generously-overbuilt full roll cage.
Most recently, this car been the pride and joy of a seasoned vintage racer in the mid-Atlantic region, who also served as General Manager for Virginia International Raceway near Danville, VA for many years. As such, it conveys with SVRA and VDCA logbooks that permit this car to be run in those groups as well as VRG, HSR and many other sanctioning bodies. The vendor states that the car was also previously active in the Midwest Sports Car Club Council as well as HSR, though little documentary evidence remains from that time apart from records from the 1993 Sebring Historics.
Vr.pr. €34.950,-
Meer info op 010-2363739
Specs;
22 gallon fuel cell
APR studs
Melling oil pump
Vr.pr. €34.950,-
Laatst gewijzigd door Martin van der Zwaard op 25 okt 2020, 13:51, 9 keer totaal gewijzigd.
- Auto: Nr.50
Re: Ford Falcon ‘65 347ci stroker racecar
Echt wat voor Tom (gtr)!
- Locatie: Haringen op zuurdesem, gedoopt in een bedje van azijn, met een glaasje citroensap on the side….
Nee die zit bij het clubje bejaarden met een krokante C-10 met een koffiezakkenjute-interieur.
Leuke Ford Martin
Leuke Ford Martin
OnlineRS-Ron
Mooi ding Martin. Ik weet ook niet of het mag......... maar ik heb, als bejaarde, serieuze interesse in een soundclip.......
Gr Ron
Gr Ron
Misschien moeten verkoop topics op basis van subjectieve toelating van moderators. “I approve”
- EvdP
- Auto: Volg de Skoda rijder
Gaaf! Ik heb geen belangstelling maar wel een vraag
Wat wordt er bedoeld met "balanced and blueprinted"?Martin van der Zwaard schreef: ↑15 okt 2020, 16:40 Smallblock V8 302ci stroked to 347ci balanced and blueprinted.
- tomgtr
Oh heerlijk. Eens met soundclip en eens met approved!
Soundclip ga ik regelen
Hier staat het precies omschreven wat ze daar onder verstaan.EvdP schreef: ↑15 okt 2020, 17:43 Gaaf! Ik heb geen belangstelling maar wel een vraag
https://www.musclecardiy.com/performanc ... ne-blocks/
Onlinealt
Zal prachtig klinken de 302.
OnlineMartijn_bmw
Super gaaf Martin! Wat een ding
- Luco
Gaaf, reed deze ook de ytcc
Dat durf ik niet te zeggen Luco.
Er zitten wel documenten bij van races in Amerika.
De kooi is ook niet FIA dus die zal eerst aangepast moeten worden.
- tuurgtt
- Auto: M140i
Mucho approved!
Wat een retegaaf apparaat. Op echte Hoosiers ook nog.
Wat een gaaf hok zeg!
Kom morgen maar ff langs hier op groene platen dan schieten we wat mooie filmpjes.
Dat zal lastig worden Rody. Zit geen verlichting etc op. Komt niet goed op de weg.
- Downforce Hans
Ik heb dat ding wel zien rijden op spa volgens mij een paar jaar geleden...... Toen stond er zo`n grote Amerikaanse truck van een koeriers bedrijf waar die instond. Die andere man die er bij was reed meet ik dacht een oude Corvette....een c2 of c3 dacht ik....
Als er een chassisnummer ingeslagen staat zijn zaken als verlichting, toetertje etc toch niet zo moeilijk te installeren of denk ik te makkelijk betreffende de rdw? Geen ervaring met die gasten.Martin van der Zwaard schreef: ↑15 okt 2020, 21:19 Dat zal lastig worden Rody. Zit geen verlichting etc op. Komt niet goed op de weg.
Kabelboompje is bij zoiets simpels niet moeilijk te maken.
Imho hoort zoiets ook gewoon op de openbare weg thuis om het straatbeeld wat op te fleuren.
OnlineMartijn_bmw
Eens! Ik zou hem ook streetlegal willen makenallen schreef: ↑16 okt 2020, 08:58Als er een chassisnummer ingeslagen staat zijn zaken als verlichting, toetertje etc toch niet zo moeilijk te installeren of denk ik te makkelijk betreffende de rdw? Geen ervaring met die gasten.Martin van der Zwaard schreef: ↑15 okt 2020, 21:19 Dat zal lastig worden Rody. Zit geen verlichting etc op. Komt niet goed op de weg.
- Jeroen
Michiel Campagne waarschijnlijk. Volgens mij is deze Ford ook van hem, maar dat weet ik niet zeker.Downforce Hans schreef: ↑16 okt 2020, 08:46 Ik heb dat ding wel zien rijden op spa volgens mij een paar jaar geleden...... Toen stond er zo`n grote Amerikaanse truck van een koeriers bedrijf waar die instond. Die andere man die er bij was reed meet ik dacht een oude Corvette....een c2 of c3 dacht ik....
- Downforce Hans
Ja Jeroen ,die was het. Sky net stond volgens mij op die truck.Jeroen schreef: ↑16 okt 2020, 09:25Michiel Campagne waarschijnlijk. Volgens mij is deze Ford ook van hem, maar dat weet ik niet zeker.Downforce Hans schreef: ↑16 okt 2020, 08:46 Ik heb dat ding wel zien rijden op spa volgens mij een paar jaar geleden...... Toen stond er zo`n grote Amerikaanse truck van een koeriers bedrijf waar die instond. Die andere man die er bij was reed meet ik dacht een oude Corvette....een c2 of c3 dacht ik....
- Martijn M
Wat een kut advertentie.
1 foto, 0 informatie, hoge vraagprijs.
Zit er een oplader bij?
Ik bied 2500 en een zak snickers.
Gebruikers op dit forum: Bing [Bot], Bombadil en 5 gasten
